[GeoNode-users] Unable to find package geonode - Ubuntu 14.04.2 LTS
Simone Dalmasso simone.dalmasso at gmail.com
Tue Jun 30 07:27:22 PDT 2015
Natalia, please use ppa:geonode/testing on a fresh machine for the moment
as snapshots has some issues.
Apologize for this.
2015-06-30 16:24 GMT+02:00 Natalia Queiroz <queiroz.nati at gmail.com>:
> Hello Simone, no error during the installation.
> Follow the steps done:
> sudo add-apt-repository ppa:geonode/snapshots
> sudo apt-get update
> sudo apt-get install geonode
> On Tue, Jun 30, 2015 at 11:20 AM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Hi Natalia,
>> strange error. did you see any issues during the installation?
>> did you install it with:
>>  sudo add-apt-repository ppa:geonode/testing
>>  sudo apt-get update
>> 2015-06-30 16:14 GMT+02:00 Natalia Queiroz <queiroz.nati at gmail.com>:
>>> Thanks Jeffrey.
>>> After the installation I', facing an error when I try to create a
>>> superuser
>>> $ geonode createsuperuser
>>> Traceback (most recent call last):
>>>   File "/usr/bin/django-admin", line 5, in <module>
>>>     management.execute_from_command_line()
>>>   File
>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>>> 399, in execute_from_command_line
>>>     utility.execute()
>>>   File
>>> 392, in execute
>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>   File
>>> 261, in fetch_command
>>>     commands = get_commands()
>>>   File
>>> 107, in get_commands
>>>     apps = settings.INSTALLED_APPS
>>>   File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line
>>> 54, in __getattr__
>>>     self._setup(name)
>>> 49, in _setup
>>>     self._wrapped = Settings(settings_module)
>>> 132, in __init__
>>>     % (self.SETTINGS_MODULE, e)
>>> ImportError: Could not import settings 'geonode.settings' (Is it on
>>> sys.path? Is there an import error in the settings file?): No module named
>>> geonode.settings
>>> Any idea?
>>> On Mon, Jun 29, 2015 at 9:07 PM, Jeffrey Johnson <ortelius at gmail.com>
>>> wrote:
>>>> Do you intend to use the 2.0 release? Im guessing you are on 14.04 and
>>>> the release (2.0) is only on 12.04. You should use the snapshots ppa
>>>> (sudo add-apt-repository ppa:geonode/snapshots) and then sudo apt-get
>>>> update and sudo apt-get install geonode again.
>>>> On Mon, Jun 29, 2015 at 5:04 PM, Natalia Queiroz <
>>>> queiroz.nati at gmail.com> wrote:
>>>> > Hello,
>>>> > I'm trying to follow the quick reference guide to install geonode on
>>>> my
>>>> > Ubuntu 14.04.2 LTS server using ppa repository but I'm facing an E:
>>>> Unable
>>>> > to find the geonode package error message after the install command
>>>> (sudo
>>>> > apt-get install geonode).
>>>> > There where the steps:
>>>> > sudo apt-get install software-properties-common
>>>> > sudo add-apt-repository ppa:geonode/release
>>>> > sudo apt-get update
>>>> > Any ideia?
>>>> > Thanks
>>>> > Natália Oliveira
>>>> > _______________________________________________
>>>> > geonode-users mailing list
>>>> > geonode-users at lists.osgeo.org
>>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>> Natália Oliveira
>> Simone
> Natália Oliveira
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150630/7d81bce0/attachment.html>
More information about the geonode-users mailing list
