[GeoNode-users] Unable to find package geonode - Ubuntu 14.04.2LTS
Vladimiro Bellini vlasvlasvlas at gmail.com
Tue Jun 30 07:33:15 PDT 2015
I also has installation issues before.
Maybe a warning must be informed at snapshots download site & installation steps page..
-----Mensaje original-----
De: "Simone Dalmasso" <simone.dalmasso at gmail.com>
Enviado el: ‎30/‎06/‎2015 11:27 a. m.
Para: "Natalia Queiroz" <queiroz.nati at gmail.com>
CC: "geonode-users" <geonode-users at lists.osgeo.org>
Asunto: Re: [GeoNode-users] Unable to find package geonode - Ubuntu 14.04.2LTS
Natalia, please use ppa:geonode/testing on a fresh machine for the moment as snapshots has some issues.
Apologize for this.
2015-06-30 16:24 GMT+02:00 Natalia Queiroz <queiroz.nati at gmail.com>:
Hello Simone, no error during the installation.
Follow the steps done:
sudo add-apt-repository ppa:geonode/snapshots
sudo apt-get update
sudo apt-get install geonode
On Tue, Jun 30, 2015 at 11:20 AM, Simone Dalmasso <simone.dalmasso at gmail.com> wrote:
Hi Natalia,
strange error. did you see any issues during the installation?
did you install it with:
 sudo add-apt-repository ppa:geonode/testing
 sudo apt-get update
2015-06-30 16:14 GMT+02:00 Natalia Queiroz <queiroz.nati at gmail.com>:
Thanks Jeffrey.
After the installation I', facing an error when I try to create a superuser
$ geonode createsuperuser
  File "/usr/bin/django-admin", line 5, in <module>
    management.execute_from_command_line()
  File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line 399, in execute_from_command_line
    utility.execute()
  File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line 392, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line 261, in fetch_command
    commands = get_commands()
  File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line 107, in get_commands
    apps = settings.INSTALLED_APPS
  File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line 54, in __getattr__
    self._setup(name)
  File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line 49, in _setup
    self._wrapped = Settings(settings_module)
  File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line 132, in __init__
    % (self.SETTINGS_MODULE, e)
ImportError: Could not import settings 'geonode.settings' (Is it on sys.path? Is there an import error in the settings file?): No module named geonode.settings
Any idea?
On Mon, Jun 29, 2015 at 9:07 PM, Jeffrey Johnson <ortelius at gmail.com> wrote:
Do you intend to use the 2.0 release? Im guessing you are on 14.04 and
the release (2.0) is only on 12.04. You should use the snapshots ppa
(sudo add-apt-repository ppa:geonode/snapshots) and then sudo apt-get
update and sudo apt-get install geonode again.
On Mon, Jun 29, 2015 at 5:04 PM, Natalia Queiroz <queiroz.nati at gmail.com> wrote:
> Hello,
> I'm trying to follow the quick reference guide to install geonode on my
> Ubuntu 14.04.2 LTS server using ppa repository but I'm facing an E: Unable
> to find the geonode package error message after the install command (sudo
> apt-get install geonode).
> There where the steps:
> sudo apt-get install software-properties-common
> sudo add-apt-repository ppa:geonode/release
> sudo apt-get update
> Any ideia?
> Thanks
> Natália Oliveira
> geonode-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Natália Oliveira
Simone
Natália Oliveira
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150630/b45d218a/attachment-0001.html>
More information about the geonode-users mailing list
