[GeoNode-users] geonode install in 12.04 in Docker fails
Gavin Fleming gavin at kartoza.com
Wed Mar 4 20:38:11 PST 2015
I've now tried it using phusion/baseimage
(https://github.com/phusion/baseimage-docker) and still get the same
errors.
Thinking the problem is the failing inits I added this to the
Dockerfile, which phusion/baseimage provides:
|	CMD ["/sbin/my_init"]|
but still get these errors during the install every time it needs to
restart apache, postgresql, tomcat etc.
            invoke-rc.d: policy-rc.d denied execution of start.
I have successfully installed geonode/testing on my 14.10 host machine
so I think the errors in Docker have something to do with the Docker
environment.
On 04/03/2015 18:40, Ariel Nunez wrote:
> Gavin, a few things:
> 1) There is no need to do "RUN paver setup", you can remove that line.
> 2) You only need to expose port 80 (Apache), there is a proxy for
> GeoServer there at host:80/geoserver/
> 3) Can you run the first 3 commands via docker and then shell into the
> docker machine and do the "apt-get install geonode" manually? That way
> we get a better error that could give us a hint.
> RUN apt-get -f -y install software-properties-common
> RUN add-apt-repository -y ppa:geonode/testing
> RUN apt-get update -y
> 4) After you have successfully installed GeoNode you need to create a
> super user and then call geonode-updateip with the right url before
> the instance is usable.
> geonode createsuperuser
> geonode-updateip <your ip>
> Good luck,
> -a
> On Wed, Mar 4, 2015 at 10:43 AM, Gavin Fleming <gavin at kartoza.com
> <mailto:gavin at kartoza.com>> wrote:
>     Hola Ariel
>     On 04/03/2015 13:56, Ariel Nunez wrote:
>>     On Wed, Mar 4, 2015 at 6:49 AM, Gavin Fleming <gavin at kartoza.com
>>     Also, is this a fresh machine or an existing one?
>     Docker (i.e. fresh)
>>     The best way to go about getting started is to use Ubuntu 14.04
>>     and GeoNode 2.4 beta (ppa:geonode/testing)
>     just tried that, getting the same error:
>     https://gist.github.com/gubuntu/c18d657a27a7780a4c20
>     Chao
>     Gavin
>     _______________________________________________
>     geonode-users mailing list
>     geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Gavin Fleming Joint MD PGP 1234
Visit http://kartoza.com <http://kartoza.com/>to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Skype: phlemingo
Kartoza = Linfiniti ∪ Afrispatial
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150305/cd4e31bb/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150305/cd4e31bb/attachment-0001.png>
More information about the geonode-users mailing list
