[GeoNode-users] upload, WMS and permission errors
Ariel Nunez ingenieroariel at gmail.com
Wed Mar 11 06:24:39 PDT 2015
There are only packages for the LTS releases.
To install 2.4 via packages you need to use ppa:geonode/testing and be
running Trusty (Ubuntu 14.04).
-a
On Wed, Mar 11, 2015 at 1:52 AM, Gavin Fleming <gavin at kartoza.com> wrote:
>  Ariel
> On 10/03/2015 18:11, Ariel Nunez wrote:
>  Gavin,
>  I'll try to come up with possible explanations for the errors you are
> seeing:
>  1) This happens from time to time, especially with big files over slow
> networks. A timeout occurs and then the web page stops listening for the
> json return, even though it all went fine. The best way to deal with this
> in the future is to switch to asyncronous upload/configuration and do some
> sort of polling.
> OK
>  2) You got no error from the upload widget? Was there anything in the
> logs? We improved this for 2.4 adding a place in the django admin where you
> can go to look for failed uploads and keeps the geoserver log and the
> django log. But it is not available in 2.0
> There are some permission errors in the logs.
> I set this up after the workshop, I wonder if it's causing any issues:
> http://docs.geonode.org/en/2.0/tutorials/admin/production.html#security-integration-optimization
>  3) Not sure what could be going on.
>  4) Also no idea
>  5) To me, the problem could be in the geoserver-geonode-ext plugin. That
> is the plugin for geoserver that handles the authentication, and it could
> be misbehaving. potentially due to lack of resources (too little ram). What
> is your configuration?
> 16GB RAM, shared with other apps. 8 x 1.6GHz processors. No disk space
> limitations.
>  Something sounds bad there, but my recommendation is to run 2.4 instead,
> we are getting close to a release and I would advice against having to
> migrate in a few months. The pros of using 2.4 over 2.0 outweigh the cons
> (IMHO).
> I'd like to. I have it running on my local 14.10. Are there 2.4 testing
> packages for precise? apt is not picking any up.
>  -a
> On Tue, Mar 10, 2015 at 10:59 AM, Gavin Fleming <gavin at kartoza.com> wrote:
>> :buildings_osm_maumere
> That part should probably have been workspace:layer_name (or
> geonode:buildings_osm_maumere)
>  The fact that there is no workspace indicates there could have been a
> problem.
> Yes it should have the workspace but geonode is not inserting the
> workspace name.
> thanks
> Gavin
>  Gavin Fleming Joint MD PGP 1234
> Visit http://kartoza.com to find out about open source:
>  * Desktop GIS programming services
>  * Geospatial web development
> * GIS Training
> * Consulting Services
>  Skype: phlemingo
> Kartoza = Linfiniti ∪ Afrispatial
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150311/84e08532/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150311/84e08532/attachment-0001.png>
More information about the geonode-users mailing list
