[GeoNode-users] upload, WMS and permission errors
santos luis quispe choque santoslqc at gmail.com
Tue Mar 10 11:35:37 PDT 2015
Dear
Again with my questions, I tell them we are implementing a node, for that
we are installing the GeoNode 2.0.1, everything is OK except that when
Harvesting (WMS) with other nodes i get error. I can not connect what does
not happen with the 2.0.
I ask you can help me.
Beforehand thank you very much for your help
Best Regards
The error is as follows:
[image: Imágenes integradas 1]
403 FORBIDDEN
DEBUG is set to False but the host of the path provided to the proxy
service is not in the PROXY_ALLOWED_HOSTS setting.
2015-03-10 12:11 GMT-04:00 Ariel Nunez <ingenieroariel at gmail.com>:
> Gavin,
> I'll try to come up with possible explanations for the errors you are
> seeing:
> 1) This happens from time to time, especially with big files over slow
> networks. A timeout occurs and then the web page stops listening for the
> json return, even though it all went fine. The best way to deal with this
> in the future is to switch to asyncronous upload/configuration and do some
> sort of polling.
> 2) You got no error from the upload widget? Was there anything in the
> logs? We improved this for 2.4 adding a place in the django admin where you
> can go to look for failed uploads and keeps the geoserver log and the
> django log. But it is not available in 2.0
> 3) Not sure what could be going on.
> 4) Also no idea
> 5) To me, the problem could be in the geoserver-geonode-ext plugin. That
> is the plugin for geoserver that handles the authentication, and it could
> be misbehaving. potentially due to lack of resources (too little ram). What
> is your configuration?
> Something sounds bad there, but my recommendation is to run 2.4 instead,
> we are getting close to a release and I would advice against having to
> migrate in a few months. The pros of using 2.4 over 2.0 outweigh the cons
> (IMHO).
> -a
> On Tue, Mar 10, 2015 at 10:59 AM, Gavin Fleming <gavin at kartoza.com> wrote:
>> :buildings_osm_maumere
> That part should probably have been workspace:layer_name (or
> geonode:buildings_osm_maumere)
> The fact that there is no workspace indicates there could have been a
> problem.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150310/fb627623/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150310/fb627623/attachment-0001.png>
More information about the geonode-users mailing list
