[GeoNode-users] Problems after Upgrade
Christian Willmes christian.willmes at googlemail.com
Tue Mar 17 02:28:57 PDT 2015
thanks! That solved the PostGIS problem.
I now need to add my server to ALLOWED_HOSTS:
[Tue Mar 17 04:24:02.116194 2015] [:error] [pid 1224:tid
140153217300224] Invalid HTTP_HOST header: 'localhost'.You may need to
add u'localhost' to ALLOWED_HOSTS.
I did set the SITEURL in local_settings.py as before the update.
Where is that to configure?
Thanks,
Christian
Am 17.03.2015 um 10:09 schrieb Le Ny Conseil:
> Hello Christian,
> Add this line in your geonode local_settings
> POSTGIS_VERSION = (2,1,0)
> 2015-03-17 10:03 GMT+01:00 Christian Willmes
> <christian.willmes at googlemail.com
> <mailto:christian.willmes at googlemail.com>>:
>     Hi,
>     im running a geonode 2.4beta from the testing Ubuntu ppa.
>     After a apt-get update/upgrade this morning, I can't get geonode
>     to restart.
>     I have this (scary) message in my logs:
>     [Tue Mar 17 03:59:59.676955 2015] [:error] [pid 1671:tid
>     139799543056128] [remote 127.0.0.1:60324 <http://127.0.0.1:60324>]
>     ImproperlyConfigured: Cannot determine PostGIS version for
>     database "geonode_data". GeoDjango requires at least PostGIS
>     version 1.3. Was the database created from a spatial database
>     template?
>     Any hints, how to solve this?
>     Interesting though, that on commandline 'geonode updatelayers'
>     seems to execute without errors. But it dit not solve the above
>     problem.
>     Thanks,
>     Christian
>     _______________________________________________
>     geonode-users mailing list
>     geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Pierre-André Le Ny
> *Le Ny Conseil*
> http://www.lenyconseil.fr
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150317/5ca0b535/attachment.html>
More information about the geonode-users mailing list
