[GeoNode-users] Customizing a geonode 2.4 project
GC-54 nepanode at gmail.com
Tue Mar 24 14:40:46 PDT 2015
the local_settings.sample that comes with geonode_project shouldn't be
used... instead you want to copy the local_settings.py from the newly
installed geonode.
to find it run
$ sudo updatedb
$ sudo locate local_settings
... (should find it in the .../python2.7/dist-packages/... dir)
On Tue, Mar 24, 2015 at 5:32 PM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> I did it yesterday and I can confirm that you find the local_settings
> sample file to be edited. I downloaded the beta22 tag from github.
> Francesco Bartoli
> Il giorno 24/mar/2015, alle ore 21:18, Le Ny Conseil <
> lenyconseil at gmail.com> ha scritto:
> Thank you for notes.
> But it doesn't work. Following the procedure, only thing disturb me. I
> haven't got a local_settings.py.sample file so i cant' do that : Rename the
> local_settings.py.sample to local_settings.py and edit it's content by
> setting the SITEURL and SITENAME
> My site displays a 404 error.
> Any idea ?
> 2015-03-24 6:04 GMT+01:00 GC-54 <nepanode at gmail.com>:
>> The documentation for running a django project wrapper/skeleton hasn't
>> been updated for use with 2.4 but after doing it realized it comes down to
>> using an upstream version tag for the geonode-project github repo ... as an
>> interim I took some notes on what I did to get Geonode 2.4b20+ running and
>> customized on Ubuntu 14.04. Hope this helps, if there are any gaps let me
>> know:
>> https://github.com/DOE-NEPA/NEPAnode/wiki/Migrating-Current-NEPAnode-Site
>> On Mon, Mar 23, 2015 at 8:08 AM, Le Ny Conseil <lenyconseil at gmail.com>
>> wrote:
>>> Hello Annalisa and dear list members,
>>> I'm particulary interested in this topic because i've tried few weeks
>>> ago to customize the look&feel of Geonode 2.4b22 without success.
>>> Not sure that the documentation be up to date.
>>> I have tried to replace my_geonode by a new template name, a new folder
>>> was created in my home folder but i've never succeed to visualize my
>>> geonode with the new templates.
>>> Is there here a committer who could tell us more about this important
>>> point ?
>>> Thanks,
>>> Happy spring day to everybody.
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Pierre-André Le Ny
> *Le Ny Conseil*
> http://www.lenyconseil.fr
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150324/1f79fcaa/attachment.html>
More information about the geonode-users mailing list
