[GeoNode-users] Customizing a geonode 2.4 project
Simone Dalmasso simone.dalmasso at gmail.com
Tue Mar 24 23:40:50 PDT 2015
Hi, my 2 cents. The Geonode project should be used whenever you want to
customize a Geonode. For Geonode 2.0 use the master branch of the
geonode_project. For Geonode 2.4 use the 2.4 branch. The
geonode_project local_settings is actually unnecessary ( we removed it in
the 2.4 branch) because it will always read the geonode's setting so you
can keep using the geonode's local_settings.
Hope this helps.
Il mercoledì 25 marzo 2015, John Jediny <john.jediny at gmail.com> ha scritto:
> If you have any need to customize Geonode (install a 3rd party app or even
> modify CSS HTML) you still want to use the Geonode project. As everytime
> you update/upgrade Geonode using the ppa or merging/pull git you'll always
> have to redo your work or resolve the conflict...
> Two things to try for those still having probelms... 1.Remove your
> existing installation if it is not within a python virtualenv.. I would
> also suggest using virtualenvwrapper if you plan to install multiple 3rd
> party apps creating a new wrapper env for each. Virtualenv will avoid new
> apps from upgrading/downgrading the Python libraries that other apps or
> Geonode depend on... Wrapper allows you to manage multiple virtualenvs
> one for each Python app.
> 2. Make sure you use apache2's new permissions
> See halfway through this thread for what I mean -
> https://github.com/ckan/ckan/issues/1651. About require all granted...
> If neither works open a new terminal and use it watch apache log $ sudo su
> $ tail -f /var/log/geonode/apache.log
> If your seeing permission denied then you need to use chown and/or chmod
> 700 for the www-data user and group of whatever file or dir Apache can't
> access
> On Tuesday, March 24, 2015, Francesco Bartoli <xbartolone at gmail.com
> <javascript:_e(%7B%7D,'cvml','xbartolone at gmail.com');>> wrote:
>> In this case you have to edit the local_settings.py under /etc/geonode.
>> Il giorno 24/mar/2015, alle ore 23:17, Le Ny Conseil <
>> lenyconseil at gmail.com> ha scritto:
>> Sorry, i'm a little bit lost.
>> I've installed geonode on ubuntu 14.04 with apt and the ppa:testing
>> package repository.
>> Version 2.4b22.
>> I didn't create virtualenv (I didn't follow this step : Installed
>> Geonode_Project template for Isolation and Customization in
>> Virtualenvironment). Maybe, it is the reason ?
>> I haven't got found this local_settings.py.sample.
>> I'm a disappointed now on this look&feel customization.
>> Thanks for your suggestions.
>> 2015-03-24 22:50 GMT+01:00 Francesco Bartoli <xbartolone at gmail.com>:
>>> I mean the local_settings.sample that comes with geonode source. I
>>> installed from that into an ubuntu 12.04 box. If you want just to customize
>>> a plain geonode you shouldn’t have the need of the geonode_project
>>> template. This should be used for adding a new geonode based application
>>> like the zinnia blog explained in the documentation.
>>> Hope this clarifies.
>>> Ciao
>>> F.
>>> Il giorno 24/mar/2015, alle ore 22:40, GC-54 <nepanode at gmail.com> ha
>>> scritto:
>>> the local_settings.sample that comes with geonode_project shouldn't be
>>> used... instead you want to copy the local_settings.py from the newly
>>> installed geonode.
>>> to find it run
>>> $ sudo updatedb
>>> $ sudo locate local_settings
>>> ... (should find it in the .../python2.7/dist-packages/... dir)
>>> On Tue, Mar 24, 2015 at 5:32 PM, Francesco Bartoli <xbartolone at gmail.com
>>> > wrote:
>>>> I did it yesterday and I can confirm that you find the local_settings
>>>> sample file to be edited. I downloaded the beta22 tag from github.
>>>> Francesco Bartoli
>>>> Il giorno 24/mar/2015, alle ore 21:18, Le Ny Conseil <
>>>> Thank you for notes.
>>>> But it doesn't work. Following the procedure, only thing disturb me. I
>>>> haven't got a local_settings.py.sample file so i cant' do that : Rename the
>>>> local_settings.py.sample to local_settings.py and edit it's content by
>>>> setting the SITEURL and SITENAME
>>>> My site displays a 404 error.
>>>> Any idea ?
>>>> 2015-03-24 6:04 GMT+01:00 GC-54 <nepanode at gmail.com>:
>>>>> The documentation for running a django project wrapper/skeleton hasn't
>>>>> been updated for use with 2.4 but after doing it realized it comes down to
>>>>> using an upstream version tag for the geonode-project github repo ... as an
>>>>> interim I took some notes on what I did to get Geonode 2.4b20+ running and
>>>>> customized on Ubuntu 14.04. Hope this helps, if there are any gaps let me
>>>>> know:
>>>>> https://github.com/DOE-NEPA/NEPAnode/wiki/Migrating-Current-NEPAnode-Site
>>>>> On Mon, Mar 23, 2015 at 8:08 AM, Le Ny Conseil <lenyconseil at gmail.com>
>>>>> wrote:
>>>>>> Hello Annalisa and dear list members,
>>>>>> I'm particulary interested in this topic because i've tried few weeks
>>>>>> ago to customize the look&feel of Geonode 2.4b22 without success.
>>>>>> Not sure that the documentation be up to date.
>>>>>> I have tried to replace my_geonode by a new template name, a new
>>>>>> folder was created in my home folder but i've never succeed to visualize my
>>>>>> geonode with the new templates.
>>>>>> Is there here a committer who could tell us more about this important
>>>>>> point ?
>>>>>> Thanks,
>>>>>> Happy spring day to everybody.
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>> Pierre-André Le Ny
>>>> *Le Ny Conseil*
>>>> http://www.lenyconseil.fr
>> Pierre-André Le Ny
>> *Le Ny Conseil*
> Cell: 973-931-0580
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150325/100fe065/attachment-0001.html>
More information about the geonode-users mailing list
