[GeoNode-users] migrate geonode 2.4 to another server
Paolo Corti pcorti at gmail.com
Tue Mar 31 04:54:01 PDT 2015
It looks to me to be a bug, could you file a ticket?
Thanks
Meanwhile what you can do is to manually update the base_links table
with something like (not tested):
update base_link
set url = replace(url, 'old_ip', 'new_ip')
p
On Tue, Mar 31, 2015 at 1:16 PM, Alessandro Burastero
<alessandro at acrotec.it> wrote:
> i've truncated the base_link table and then i've run the geonode
> updatelayers command (and also updatelayerid)... but the base_link table
> remains empty
> Alessandro
> On 31/03/15 11:39, Paolo Corti wrote:
>> I have no way to test this right now but I believe that truncating the
>> base_links table and running the updatelayers command should fix this.
>> Before doing this action do a backup and try it on just one layer
>> (removing the links related to only that layer from the base_links
>> table)
>> You may also need to run the updatemaplayerip command.
>> p
>> On Tue, Mar 31, 2015 at 11:08 AM, Alessandro Burastero
>>> Hi guys
>>> i need to migrate my geonode 2.4b22 to another server (same os: ubuntu
>>> 14-04
>>> and same geonode version)...
>>> I tried doing it in this way:
>>>   - copy the geoserver data, styles and workspace directory in the new
>>> server
>>>   - domp via pg_dump and restore via psql the geonode database
>>> the result is that geonode recognize all layers but it cannot view them
>>> because all links in the layer metadata contains the old server
>>> address...
>>> haw can i solve it?
>>> thanks in advance
>>>      Alessandro
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
