[GeoNode-users] geonode 2.4 dev layers not displayed: CLIENT_RESULTS_LIMIT = ;
Jesus gesusjl at gmail.com
Mon May 4 07:15:50 PDT 2015
Hi Simone.
As you say I need to figure out if there's any interfering template or
app causing the problem. in the meanwhile i remove the
{{CLIENT_RESULTS_LIMIT}} template tag from search_scripts.html in
"production server" and substitute with a numeric value. Not doing so
makes javascript break (not default value is provided)
I will let you know if i find out the cause of the problem.
Thanks!
Jesús
On 05/04/2015 12:38 AM, Simone Dalmasso wrote:
> Hi Jesus, I cannot replicate this.
> The CLIENT_RESULTS_LIMIT is defined in the settings as you said but
> also is passed from the context_processor to the client see
> https://github.com/GeoNode/geonode/blob/master/geonode/context_processors.py#L62 that
> defaults it to 10 if not found in settings. And is used here
> https://github.com/GeoNode/geonode/blob/master/geonode/templates/search/search_scripts.html#L26.
> All this is done server side so it should not be a javascript error.
> Did you by the way changed in the template? Seems that the server is
> not interpreting the {{ CLIENT_RESULTS_LIMIT }} and this could be
> caused by the presence of a {% verbatim %} block around it.
> 2015-05-03 20:21 GMT+02:00 Jesus <gesusjl at gmail.com
> <mailto:gesusjl at gmail.com>>:
>     Hi all,
>     Layers and maps not appear in geonode 2.4 dev.. firebug console
>     raise an javascript error
>     SyntaxError: expected expression, got ';'
>     I tried uploading local_settings.py with
>     CLIENT_RESULTS_LIMIT = 100
>     but no result. Maybe a javascript bug or something else to check
>     around?
>     No apache errors
>     Thank you,
>     Jesús
>     _______________________________________________
>     geonode-users mailing list
>     geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>     http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150504/c4b63cca/attachment.html>
More information about the geonode-users mailing list
