[GeoNode-users] Geocoding
Paolo Corti pcorti at gmail.com
Wed May 6 02:31:35 PDT 2015
Look how @ndufrane did it here for the layer searcher, you may use the
same approach:
https://github.com/GeoNode/geonode/pull/2107/files
cheers
p
On Wed, May 6, 2015 at 11:27 AM, Annalisa Schiavon
<annalisa.schiavon at gmail.com> wrote:
> Sorry, but I didn't understand where to customize in map template ...
> The tutorial [1] says: "Navigate to the src/app/app.js in the myviewer
> directory"
> In a geonode installation (2.4b22 - I've created my template from
> https://github.com/GeoNode/geonode-project/archive/testing.zip ) where is
> the code? Or how can I override this script?
> In general, I've to customize Geoexplorer, but I haven't already found
> where!
> Annalisa
> 2015-05-05 12:58 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>> Hi Annalisa
>> I don't think anything was done in this regards. Not even sure how
>> easy would be to implement it, as we would need to recursively scan
>> all of the records of each GeoNode layer (maybe a search engine could
>> be used at this regard?)
>> If instead you need just to geocode a location and zoom to the
>> corresponding point in the map, you could add the geocoder tool [1] in
>> your map template.
>> cheers
>> p
>> [1] http://suite.opengeo.org/4.1/webapps/gxp/viewer/geocoder.html
>> On Tue, May 5, 2015 at 10:01 AM, Annalisa Schiavon
>> > Hi list!
>> > It is planned to implement geocoding functionality in geonode? I see
>> > this
>> > issue: https://github.com/GeoNode/geonode/issues/1810, I think it would
>> > be
>> > very useful.
>> > Someone has already added this functionality, any ideas, examples?
>> > Thanks a lot
>> > Annalisa
>> > _______________________________________________
>> > geonode-users mailing list
>> > geonode-users at lists.osgeo.org
>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
