[GeoNode-users] Geocoding
Paolo Corti pcorti at gmail.com
Wed May 6 03:06:25 PDT 2015
The best practice if you need to customize things is to create and
deploy a GeoNode project [1].
Alternatively you may modify the code on the server, but this is not
recommended as it will be difficult to keep your changes under git and
to sync from the geonode master.
p
[1] http://geonode.readthedocs.org/en/latest/tutorials/devel/projects/index.html#customize-projects
On Wed, May 6, 2015 at 11:49 AM, Annalisa Schiavon
<annalisa.schiavon at gmail.com> wrote:
> But I need to install Geonode in "developer mode"? I've already installed
> geonode using apt-get install, refer to testing ver.
> 2015-05-06 11:31 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>> Look how @ndufrane did it here for the layer searcher, you may use the
>> same approach:
>> https://github.com/GeoNode/geonode/pull/2107/files
>> cheers
>> p
>> On Wed, May 6, 2015 at 11:27 AM, Annalisa Schiavon
>> > Sorry, but I didn't understand where to customize in map template ...
>> > The tutorial [1] says: "Navigate to the src/app/app.js in the myviewer
>> > directory"
>> > In a geonode installation (2.4b22 - I've created my template from
>> > https://github.com/GeoNode/geonode-project/archive/testing.zip ) where
>> > is
>> > the code? Or how can I override this script?
>> > In general, I've to customize Geoexplorer, but I haven't already found
>> > where!
>> > Annalisa
>> > 2015-05-05 12:58 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>> >> Hi Annalisa
>> >> I don't think anything was done in this regards. Not even sure how
>> >> easy would be to implement it, as we would need to recursively scan
>> >> all of the records of each GeoNode layer (maybe a search engine could
>> >> be used at this regard?)
>> >> If instead you need just to geocode a location and zoom to the
>> >> corresponding point in the map, you could add the geocoder tool [1] in
>> >> your map template.
>> >> cheers
>> >> p
>> >> [1] http://suite.opengeo.org/4.1/webapps/gxp/viewer/geocoder.html
>> >> On Tue, May 5, 2015 at 10:01 AM, Annalisa Schiavon
>> >> > Hi list!
>> >> > It is planned to implement geocoding functionality in geonode? I see
>> >> > this
>> >> > issue: https://github.com/GeoNode/geonode/issues/1810, I think it
>> >> > would
>> >> > be
>> >> > very useful.
>> >> > Someone has already added this functionality, any ideas, examples?
>> >> > Thanks a lot
>> >> > Annalisa
>> >> > _______________________________________________
>> >> > geonode-users mailing list
>> >> > geonode-users at lists.osgeo.org
>> >> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> >> Paolo Corti
>> >> Geospatial software developer
>> >> web: http://www.paolocorti.net
>> >> twitter: @capooti
>> >> skype: capooti
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
