[GeoNode-users] ppa:geonode/testing install issue
Simone Dalmasso simone.dalmasso at gmail.com
Fri May 8 00:44:41 PDT 2015
Hi, the package is geoserver-geonode as you tried already. The only thing
that make a difference from a standard 14.04 is the kernel and firmware.
Not sure how this makes a difference.
2015-05-08 0:51 GMT+02:00 Charles Cossé <ccosse at gmail.com>:
> Correction: doing an "apt-get install geoserver"  to try to fix the
> geoserver dependency gives
> E: Unable to locate package geoserver
> and same with package geoserver-geonode
> On Thu, May 7, 2015 at 4:47 PM, Charles Cossé <ccosse at gmail.com> wrote:
>> Hello All,
>> I've just tried to install geonode ~2.4 on Ubuntu 14.04.2 using:
>> deb http://ppa.launchpad.net/geonode/testing/ubuntu trusty main
>> deb-src http://ppa.launchpad.net/geonode/testing/ubuntu trusty main
>> ppa:geonode/testing
>> sudo apt-get install geonode
>> During configuration a dpkg sub-process fails with:
>> ---------8<----------
>> dpkg: error processing package geonode 99--configure):
>>  subprocess installed post-installation script returned error exit status
>> 1
>> dpkg:dependency problems prevent configuration of geonde:
>>  geonode depnds on geoserver-geonode | geoserver; however:
>>  Package geoserver-geonode is not configured yet.
>>  Package geoserver is not installed.
>>  dependency problems - leaving unconfigured
>> There may have been some other error preceeding these, but am using a
>> console so they would have scrolled-off the top.   Just doing "apt-get
>> install geonode" again only crashes at the above, i.e. not going back to
>> any previous error that may have occured.
>> The only other detail is that I'm installing to a Raspberry-Pi according
>> to here <https://wiki.ubuntu.com/ARM/RaspberryPi>, but I don't see
>> anything in the outputs to suggest that the problem is the R-Pi.
>> Thanks in advance for any help!
>> Charles
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150508/53cab9ba/attachment.html>
More information about the geonode-users mailing list
