[GeoNode-users] ppa:geonode/testing install issue
Charles Cossé ccosse at gmail.com
Fri May 8 02:48:40 PDT 2015
Hi Simone,  thank you for answering.
I went ahead and provisioned a normal 14.04 server and the installation of
ppa:geonode/testing is working, so must be something weird with the
raspberry-pi image.   In fact I now found that the rpi 14.04 install also
fails on startx after installing xubuntu-desktop as per the same
instructions <https://wiki.ubuntu.com/ARM/RaspberryPi>.
Charles
On Fri, May 8, 2015 at 1:44 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi, the package is geoserver-geonode as you tried already. The only thing
> that make a difference from a standard 14.04 is the kernel and firmware.
> Not sure how this makes a difference.
> 2015-05-08 0:51 GMT+02:00 Charles Cossé <ccosse at gmail.com>:
>> Correction: doing an "apt-get install geoserver"  to try to fix the
>> geoserver dependency gives
>> E: Unable to locate package geoserver
>> and same with package geoserver-geonode
>> On Thu, May 7, 2015 at 4:47 PM, Charles Cossé <ccosse at gmail.com> wrote:
>>> Hello All,
>>> I've just tried to install geonode ~2.4 on Ubuntu 14.04.2 using:
>>> deb http://ppa.launchpad.net/geonode/testing/ubuntu trusty main
>>> deb-src http://ppa.launchpad.net/geonode/testing/ubuntu trusty main
>>> ppa:geonode/testing
>>> sudo apt-get install geonode
>>> During configuration a dpkg sub-process fails with:
>>> ---------8<----------
>>> dpkg: error processing package geonode 99--configure):
>>>  subprocess installed post-installation script returned error exit
>>> status 1
>>> dpkg:dependency problems prevent configuration of geonde:
>>>  geonode depnds on geoserver-geonode | geoserver; however:
>>>  Package geoserver-geonode is not configured yet.
>>>  Package geoserver is not installed.
>>>  dependency problems - leaving unconfigured
>>> There may have been some other error preceeding these, but am using a
>>> console so they would have scrolled-off the top.   Just doing "apt-get
>>> install geonode" again only crashes at the above, i.e. not going back to
>>> any previous error that may have occured.
>>> The only other detail is that I'm installing to a Raspberry-Pi according
>>> to here <https://wiki.ubuntu.com/ARM/RaspberryPi>, but I don't see
>>> anything in the outputs to suggest that the problem is the R-Pi.
>>> Thanks in advance for any help!
>>> Charles
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150508/3fe5e572/attachment-0001.html>
More information about the geonode-users mailing list
