[GeoNode-users] Possible to save a GeoRSS feed to a map?
Luiz Vital luiz.vital at gmail.com
Fri May 8 06:35:44 PDT 2015
Hi Charles,
I've noticed this problem a time ago, and posted a possible solution to the
code in  GeoExplorer, but had no feedback from the list.
https://groups.google.com/a/opengeo.org/forum/#!searchin/geonode-dev/georss/geonode-dev/0QGzFgkudy4/oQJ4tvOgvHQJ
Here goes a copy of the message in case you don't want to register
geonode-dev list
Date: Thu, 15 Jan 2015 08:47:53 -0800 (PST)
To: geonode-dev at opengeo.org
Subject: GeoExplorer preventing saving GeoRSS feeds in a Map
Hi all.
Does anyone knows if there's some special use case for not saving Feed
Sources (GeoRSS) added in a map in GeoExplorer?
It's explicitly prevented by this line
https://github.com/boundlessgeo/gxp/blob/0faa5c1aae2ba50eff7ba31e07749aeacaab3776/src/script/widgets/Viewer.js#L727
when excluding Vector Layers from the returned state
After just leaving the displayInLayerSwitcher check I was able to save it
on the Map.
How harmful can it be letting Vector Layers be included in the return state?
Thanks,
Luiz Vital
Luiz Fernando Barbosa Vital
ZNC Sistemas
On Fri, May 8, 2015 at 10:21 AM, Charles Cossé <ccosse at gmail.com> wrote:
> I wrote a view that serves a GeoRSS feed, which plots to a map but it
> doesn't save along with the map as I expected.  I tried in several versions
> of GeoNode, so I guess I'm missing something basic ... could someone set me
> straight on this please?  Thanks!
> Charles
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150508/8e3bbcac/attachment.html>
More information about the geonode-users mailing list
