[GeoNode-users] Exists a project template for smartphone collection and upload?
    Charles Cossé
    ccosse at gmail.com
    Mon May 11 07:08:44 PDT 2015
Hi Simone,
On Mon, May 11, 2015 at 6:59 AM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi Charles,
> at the moment there's no such working tool (apart from a very draft I made
> some years ago that uses formhub + epicollect + geonode) but the interest
> around it is increasing and I'm sure there are other people in the list
> that are willing to work on this.
Well, I was starting to work on such a thing when I stopped to ask .... so
I guess I'll just keep on going with the idea ...
> We encourage potential stakeholders to come in!
That's cool.  I just created:  https://github.com/ccosse/geoplate  Is that
a reasonable name and location?  It's empty still, so easily changed.  I
have an  android gps app that I will upload after cleaning-up.   Beyond
that, I've used django a lot but not geonode, and done GIS but not like
this ... so that's where I'm coming from.   And what I'm after here is a
template which takes care of the common plumbing between smartphone
collection and online presentation, via geonode.  I'm also thinking of
storing uploads as PickledDataObjects, performing serialization and
de-serialization via android and javascript, respectively.
> About your questions:
> - you can add google as an optional background in the settings here
> https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L617 using
> this doc http://gxp.opengeo.org/master/doc/lib/plugins/GoogleSource.html
Thank you
> - you will have to customize the code of the mapping library which is
> based on Geoexplorer http://suite.opengeo.org/opengeo-docs/geoexplorer/.
> But here others may help you more than me. :)
Thank you
> Ciao
Ciao!
> 2015-05-11 13:32 GMT+02:00 Charles Cossé <ccosse at gmail.com>:
>> Hi All,
>> I am getting up-to-speed with GeoNode and GIS in general.   I need to
>> implement the same general workflow model in several  different contexts.
>> The workflow is:
>>    1. offline collection of arbitrary data via smartphone (tracks,
>>    photos, notes, forms)
>>    2. sync arbitrary, serialized blob data to server
>>    3. handle and store arbitrary serialized blob data in GeoNode (some
>>    sub-app)
>>    4. webapp interface template to explore / utilize data
>> This seems like it would make a good project template ... pull everything
>> into a django-app under your geonode instance, including the smartphone app
>> template code, and just customize from there.
>> Does such a project already exist?  If not, then would it be a good thing?
>> I like these apps from MISIN <http://www.misin.msu.edu/tools/apps/#>,
>> but they don't allow for use outside of a hard-coded range.  Otherwise,
>> that's exactly the system / workflow I'm after.  I haven't checked if their
>> code is free.  ArcGIS Collector would be the similar Esri product.
>> I have a couple other questions while here:
>>    - why google earth but no google maps?
>>    - what is best way (api?) to capture map clicks?
>> Thanks!
>> Charles
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150511/3cd4c1dc/attachment.html>
More information about the geonode-users
