[GeoNode-users] Layer styles not updatable 2.4b25
Le Ny Conseil lenyconseil at gmail.com
Tue May 12 01:50:15 PDT 2015
You can check if the original style is stored or not in a workspace in
GeoServer. I've encountered some errors when the style is stored in a
workspace.
2015-05-12 10:43 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
> hmm. The only difference I can see is that, here,  the problem occurs with
> a point layer
> _____________________________________
> *A P L I K @ T E . E U <http://www.aplikate.eu/>*
> Linux, GIS and database developer team
> Wittmannsdorfer Str. 4
> 12053 Berlin
> Germany / Allemagne
> Tel.: +49 (0) 30 28 45 40 71
> Mobil: +49 (0) 163 681 77 34
> Fax: +49 (0)30 / 48 49 81 286
> 2015-05-12 10:33 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Rainer, I'm testing this here
>> http://demo.geonode.org/layers/geonode%3Astreams_2 but I can't replicate.
>> 2015-05-12 10:23 GMT+02:00 Rainer Lissewski <rainerlissewski at gmail.com>:
>>> Open a layer, edit layer, edit style. In the popup, select rule and
>>> edit. Change color and/or opacity. Save and close. Repeat process, the rule
>>> has reverted back to its original style.
>>> Also see https://github.com/GeoNode/geonode/issues/2146
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Simone
Pierre-André Le Ny
*Le Ny Conseil*
http://www.lenyconseil.fr
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150512/195d8a4c/attachment-0001.html>
More information about the geonode-users mailing list
