[GeoNode-users] Fwd: Layer styles not updatable 2.4b25
Rainer Lissewski r.lissewski at aplikate.eu
Tue May 12 03:20:36 PDT 2015
Hi , all styles were created in geonode GUI, so no pattern there.
also now errors in stacktrace
    AXIS["Latitude", NORTH],
    AUTHORITY["EPSG","4326"]],
  PROJECTION["Mercator_1SP"],
  PARAMETER["semi_minor", 6378137.0],
  PARAMETER["latitude_of_origin", 0.0],
  PARAMETER["central_meridian", 0.0],
  PARAMETER["scale_factor", 1.0],
  PARAMETER["false_easting", 0.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
  AUTHORITY["EPSG","900913"]]
Bbox = SRSEnvelope[1056665.4788672 : 1066449.4184863, 7122708.0427344 :
7132491.9823535]
RemoteOwsType = null
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
BgColor = java.awt.Color[r=255,g=255,b=255]
Transparent = true
SldBody = null
ValidateSchema = false
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
BaseUrl = http://xx.x.x.x:xxxxx/geoserver/
RawKvp = {_OLSALT=0.9492145837284625, _DC=0.7638796556275338,
BBOX=1056665.4788672,7122708.0427344,1066449.4184863,7132491.9823535,
SERVICE=WMS, TILED=true, HEIGHT=256, REQUEST=GetMap,
STYLES=style1_3d7625b4, WIDTH=256, TRANSPARENT=TRUE, VERSION=1.1.1,
FORMAT=image/png, LAYERS=geonode:layer11, SRS=EPSG:900913}
RequestCharset = UTF-8
Version = 1.1.1
Request = GetMap
2015-05-12 10:10:25,436 INFO [geoserver.wms] -
Request: getMap
Exceptions = SE_XML
Width = 256
Height = 256
Layers = [org.geoserver.wms.MapLayerInfo at edaec8d6]
MaxFeatures = null
Tiled = true
Palette = null
SRS = EPSG:900913
FeatureVersion = null
Styles = [StyleImpl[ name=style1_3d7625b4]]
Crs = PROJCS["WGS84 / Google Mercator",
  GEOGCS["WGS 84",
    DATUM["World Geodetic System 1984",
      SPHEROID["WGS 84", 6378137.0, 298.257223563,
AUTHORITY["EPSG","7030"]],
      AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
    UNIT["degree", 0.017453292519943295],
    AXIS["Longitude", EAST],
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7103140.1634961 :
7112924.1031152]
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
BBOX=1046881.539248,7103140.1634961,1056665.4788672,7112924.1031152,
Version = 1.1.1
Request = GetMap
2015-05-12 10:10:25,445 INFO [geoserver.wms] -
Request: getServiceInfo
2015-05-12 10:10:25,446 INFO [geoserver.wms] -
Request: getMap
Exceptions = SE_XML
Width = 256
Height = 256
MaxFeatures = null
Tiled = true
Palette = null
SRS = EPSG:900913
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7093356.223877 :
7103140.1634961]
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
BBOX=1046881.539248,7093356.223877,1056665.4788672,7103140.1634961,
Version = 1.1.1
Request = GetMap
2015-05-12 10:10:25,483 INFO [geoserver.wms] -
2015-05-12 10:10:25,490 INFO [geoserver.wms] -
Request: getMap
Exceptions = SE_XML
Width = 256
Height = 256
MaxFeatures = null
Tiled = true
Palette = null
SRS = EPSG:900913
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7112924.1031152 :
7122708.0427344]
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
BBOX=1046881.539248,7112924.1031152,1056665.4788672,7122708.0427344,
Version = 1.1.1
Request = GetMap
2015-05-12 10:10:25,503 INFO [geoserver.wms] -
2015-05-12 10:10:25,511 INFO [geoserver.wms] -
Request: getMap
Exceptions = SE_XML
Width = 256
Height = 256
MaxFeatures = null
Tiled = true
Palette = null
SRS = EPSG:900913
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
Bbox = SRSEnvelope[1086017.2977246 : 1095801.2373438, 7083572.2842578 :
7093356.223877]
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
BBOX=1086017.2977246,7083572.2842578,1095801.2373438,7093356.223877,
Version = 1.1.1
Request = GetMap
2015-05-12 10:10:25,515 INFO [geoserver.wms] -
2015-05-12 10:10:25,517 INFO [geoserver.wms] -
Request: getMap
Exceptions = SE_XML
Width = 256
Height = 256
MaxFeatures = null
Tiled = true
Palette = null
SRS = EPSG:900913
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
Bbox = SRSEnvelope[1086017.2977246 : 1095801.2373438, 7122708.0427344 :
7132491.9823535]
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
BBOX=1086017.2977246,7122708.0427344,1095801.2373438,7132491.9823535,
Version = 1.1.1
Request = GetMap
2015-05-12 10:10:25,528 INFO [geoserver.wms] -
2015-05-12 10:10:25,530 INFO [geoserver.wms] -
2015-05-12 10:10:25,538 INFO [geoserver.wms] -
2015-05-12 10:10:25,547 INFO [geoserver.wms] -
Request: getMap
Exceptions = SE_XML
Width = 512
Height = 1024
MaxFeatures = null
Tiled = false
Palette = null
SRS = EPSG:900913
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
Bbox = SRSEnvelope[1095801.237343751 : 1115369.1165820323,
7083572.284257814 : 7122708.042734373]
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
BaseUrl = http://localhost:8080/geoserver/
RawKvp =
{BBOX=1095801.237343751,7083572.284257814,1115369.1165820323,7122708.042734373,
SERVICE=WMS, HEIGHT=1024, REQUEST=GetMap, STYLES=style1_3d7625b4,
WIDTH=512, EXCEPTIONS=SE_XML, TRANSPARENT=true, VERSION=1.1.1,
FORMAT=image/png, GWC_SEED_INTERCEPT=true, LAYERS=geonode:layer11,
SRS=EPSG:900913}
Version = 1.1.1
Request = GetMap
2015-05-12 10:10:25,560 INFO [geoserver.wms] -
2015-05-12 10:10:25,580 INFO [geoserver.wms] -
Request: getMap
Exceptions = SE_XML
Width = 256
Height = 256
MaxFeatures = null
Tiled = true
Palette = null
SRS = EPSG:900913
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7093356.223877 :
7103140.1634961]
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
BBOX=1095801.2373438,7093356.223877,1105585.1769629,7103140.1634961,
Version = 1.1.1
Request = GetMap
2015-05-12 10:10:25,581 INFO [geoserver.wms] -
Request: getMap
Exceptions = SE_XML
Width = 256
Height = 256
MaxFeatures = null
Tiled = true
Palette = null
SRS = EPSG:900913
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7112924.1031152 :
7122708.0427344]
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
BBOX=1095801.2373438,7112924.1031152,1105585.1769629,7122708.0427344,
Version = 1.1.1
Request = GetMap
Request: getMap
Exceptions = SE_XML
Width = 256
Height = 256
MaxFeatures = null
Tiled = true
Palette = null
SRS = EPSG:900913
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7103140.1634961 :
7112924.1031152]
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
BBOX=1095801.2373438,7103140.1634961,1105585.1769629,7112924.1031152,
Version = 1.1.1
Request = GetMap
2015-05-12 10:10:25,762 INFO [geoserver.wms] -
2015-05-12 10:10:25,767 INFO [geoserver.wms] -
2015-05-12 10:10:25,770 INFO [geoserver.wms] -
Request: getMap
Exceptions = SE_XML
Width = 256
Height = 256
MaxFeatures = null
Tiled = true
Palette = null
SRS = EPSG:900913
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7083572.2842578 :
7093356.223877]
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
BBOX=1095801.2373438,7083572.2842578,1105585.1769629,7093356.223877,
Version = 1.1.1
Request = GetMap
2015-05-12 10:10:25,773 INFO [geoserver.wms] -
Request: getMap
Exceptions = SE_XML
Width = 256
Height = 256
MaxFeatures = null
Tiled = true
Palette = null
SRS = EPSG:900913
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7083572.2842578 :
7093356.223877]
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
BBOX=1046881.539248,7083572.2842578,1056665.4788672,7093356.223877,
Version = 1.1.1
Request = GetMap
2015-05-12 10:10:25,774 INFO [geoserver.wms] -
2015-05-12 10:10:25,785 INFO [geoserver.wms] -
Request: getMap
Exceptions = SE_XML
Width = 1024
Height = 1024
MaxFeatures = null
Tiled = false
Palette = null
SRS = EPSG:900913
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
Bbox = SRSEnvelope[1017529.7203906253 : 1056665.478867188,
7122708.042734373 : 7161843.801210936]
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
RawKvp =
{BBOX=1017529.7203906253,7122708.042734373,1056665.478867188,7161843.801210936,
WIDTH=1024, EXCEPTIONS=SE_XML, TRANSPARENT=true, VERSION=1.1.1,
SRS=EPSG:900913}
Version = 1.1.1
Request = GetMap
Request: getMap
Exceptions = SE_XML
Width = 512
Height = 1024
MaxFeatures = null
Tiled = false
Palette = null
SRS = EPSG:900913
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
RawKvp =
{BBOX=1095801.237343751,7122708.042734373,1115369.1165820323,7161843.801210936,
SRS=EPSG:900913}
Version = 1.1.1
Request = GetMap
2015-05-12 10:10:25,804 INFO [geoserver.wms] -
Request: getMap
Exceptions = SE_XML
Width = 256
Height = 256
MaxFeatures = null
Tiled = true
Palette = null
SRS = EPSG:900913
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7122708.0427344 :
7132491.9823535]
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
BBOX=1095801.2373438,7122708.0427344,1105585.1769629,7132491.9823535,
Version = 1.1.1
Request = GetMap
2015-05-12 10:10:25,825 INFO [geoserver.wms] -
Request: getMap
Exceptions = SE_XML
Width = 256
Height = 256
MaxFeatures = null
Tiled = true
Palette = null
SRS = EPSG:900913
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
  AXIS["x", EAST],
  AXIS["y", NORTH],
Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7122708.0427344 :
7132491.9823535]
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = null
Elevation = []
FeatureId = null
StartIndex = null
ViewParams = null
Transparent = true
SldBody = null
Sld = null
SldVersion = null
TilesOrigin = null
Buffer = 0
Format = image/png
Time = []
Filter = null
Filters = null
Get = true
BBOX=1046881.539248,7122708.0427344,1056665.4788672,7132491.9823535,
Version = 1.1.1
Request = GetMap
_____________________________________
*A P L I K @ T E . E U <http://www.aplikate.eu/>*
Linux, GIS and database developer team
Wittmannsdorfer Str. 4
12053 Berlin
Germany / Allemagne
Tel.: +49 (0) 30 28 45 40 71
Mobil: +49 (0) 163 681 77 34
Fax: +49 (0)30 / 48 49 81 286
2015-05-12 11:55 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> that is indeed strange, it doesn't look at a permission bug. They ones
> with no (none) might have a space instead. Do you have more information on
> how you created those styles?
> 2015-05-12 11:47 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>> okay I found a pattern now:
>> in /admin/layers/style/
>> [image: Inline-Bild 1]
>> -The styles that have  "(None)" entry in the Workspace column  can be
>> edited via geonode style editor
>> -The styles that have no "(None)" entry entry in the Workspace column
>>  canot be edited via geonode style editor
>> How ever if i open a particular style in  /admin/layers/style/ , the
>> workspace field is empty for all stlyes, wether they have a "(None)" entry
>> in the Workspace column or not.
>> Is this a bug with the django permissions system?
>> 12053 Berlin
>> Germany / Allemagne
>> 2015-05-12 11:27 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>> I have unticked the option "Automatic caching for non-standard styles" in
>>> /geoserver/web/?wicket:bookmarkablePage=:org.geoserver.gwc.web.GWCSettingsPage
>>> That resolved the issue for a number of layers but not for all. The
>>> style for one point layer n my installation is still only editable in
>>> geoserver via SLD, not via geonode gui.
>>> 2015-05-12 10:43 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>>> hmm. The only difference I can see is that, here,  the problem occurs
>>>> with a point layer
>>>> 12053 Berlin
>>>> Germany / Allemagne
>>>> 2015-05-12 10:33 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>>> Rainer, I'm testing this here
>>>>> http://demo.geonode.org/layers/geonode%3Astreams_2 but I can't
>>>>> replicate.
>>>>> 2015-05-12 10:23 GMT+02:00 Rainer Lissewski <rainerlissewski at gmail.com
>>>>>> Open a layer, edit layer, edit style. In the popup, select rule and
>>>>>> edit. Change color and/or opacity. Save and close. Repeat process, the rule
>>>>>> has reverted back to its original style.
>>>>>> Also see https://github.com/GeoNode/geonode/issues/2146
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150512/ef40d568/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150512/ef40d568/attachment-0001.png>
More information about the geonode-users mailing list
