[GeoNode-users] Fwd: Layer styles not updatable 2.4b25
Simone Dalmasso simone.dalmasso at gmail.com
Tue May 12 04:26:39 PDT 2015
I don't see errors, I'm also trying to replicate both locally and on
demo.geonode.org but every created style works fine.
Are you using the last geonode b25 or something older?
2015-05-12 12:20 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
> Hi , all styles were created in geonode GUI, so no pattern there.
> also now errors in stacktrace
>     AXIS["Latitude", NORTH],
>     AUTHORITY["EPSG","4326"]],
>   PROJECTION["Mercator_1SP"],
>   PARAMETER["semi_minor", 6378137.0],
>   PARAMETER["latitude_of_origin", 0.0],
>   PARAMETER["central_meridian", 0.0],
>   PARAMETER["scale_factor", 1.0],
>   PARAMETER["false_easting", 0.0],
>   PARAMETER["false_northing", 0.0],
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
>   AUTHORITY["EPSG","900913"]]
> Bbox = SRSEnvelope[1056665.4788672 : 1066449.4184863, 7122708.0427344 :
> 7132491.9823535]
> RemoteOwsType = null
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> BgColor = java.awt.Color[r=255,g=255,b=255]
> Transparent = true
> SldBody = null
> ValidateSchema = false
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> BaseUrl = http://xx.x.x.x:xxxxx/geoserver/
> RawKvp = {_OLSALT=0.9492145837284625, _DC=0.7638796556275338,
> BBOX=1056665.4788672,7122708.0427344,1066449.4184863,7132491.9823535,
> SERVICE=WMS, TILED=true, HEIGHT=256, REQUEST=GetMap,
> STYLES=style1_3d7625b4, WIDTH=256, TRANSPARENT=TRUE, VERSION=1.1.1,
> FORMAT=image/png, LAYERS=geonode:layer11, SRS=EPSG:900913}
> RequestCharset = UTF-8
> Version = 1.1.1
> Request = GetMap
> 2015-05-12 10:10:25,436 INFO [geoserver.wms] -
> Request: getMap
> Exceptions = SE_XML
> Width = 256
> Height = 256
> Layers = [org.geoserver.wms.MapLayerInfo at edaec8d6]
> MaxFeatures = null
> Tiled = true
> Palette = null
> SRS = EPSG:900913
> FeatureVersion = null
> Styles = [StyleImpl[ name=style1_3d7625b4]]
> Crs = PROJCS["WGS84 / Google Mercator",
>   GEOGCS["WGS 84",
>     DATUM["World Geodetic System 1984",
>       SPHEROID["WGS 84", 6378137.0, 298.257223563,
> AUTHORITY["EPSG","7030"]],
>       AUTHORITY["EPSG","6326"]],
>     PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
>     UNIT["degree", 0.017453292519943295],
>     AXIS["Longitude", EAST],
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7103140.1634961 :
> 7112924.1031152]
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> Transparent = true
> SldBody = null
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> BBOX=1046881.539248,7103140.1634961,1056665.4788672,7112924.1031152,
> Version = 1.1.1
> Request = GetMap
> 2015-05-12 10:10:25,445 INFO [geoserver.wms] -
> Request: getServiceInfo
> 2015-05-12 10:10:25,446 INFO [geoserver.wms] -
> Request: getMap
> Exceptions = SE_XML
> Width = 256
> Height = 256
> MaxFeatures = null
> Tiled = true
> Palette = null
> SRS = EPSG:900913
>   GEOGCS["WGS 84",
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7093356.223877 :
> 7103140.1634961]
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> Transparent = true
> SldBody = null
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> BBOX=1046881.539248,7093356.223877,1056665.4788672,7103140.1634961,
> Version = 1.1.1
> Request = GetMap
> 2015-05-12 10:10:25,483 INFO [geoserver.wms] -
> 2015-05-12 10:10:25,490 INFO [geoserver.wms] -
> Request: getMap
> Exceptions = SE_XML
> Width = 256
> Height = 256
> MaxFeatures = null
> Tiled = true
> Palette = null
> SRS = EPSG:900913
>   GEOGCS["WGS 84",
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7112924.1031152 :
> 7122708.0427344]
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> Transparent = true
> SldBody = null
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> BBOX=1046881.539248,7112924.1031152,1056665.4788672,7122708.0427344,
> Version = 1.1.1
> Request = GetMap
> 2015-05-12 10:10:25,503 INFO [geoserver.wms] -
> 2015-05-12 10:10:25,511 INFO [geoserver.wms] -
> Request: getMap
> Exceptions = SE_XML
> Width = 256
> Height = 256
> MaxFeatures = null
> Tiled = true
> Palette = null
> SRS = EPSG:900913
>   GEOGCS["WGS 84",
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
> Bbox = SRSEnvelope[1086017.2977246 : 1095801.2373438, 7083572.2842578 :
> 7093356.223877]
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> Transparent = true
> SldBody = null
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> BBOX=1086017.2977246,7083572.2842578,1095801.2373438,7093356.223877,
> Version = 1.1.1
> Request = GetMap
> 2015-05-12 10:10:25,515 INFO [geoserver.wms] -
> 2015-05-12 10:10:25,517 INFO [geoserver.wms] -
> Request: getMap
> Exceptions = SE_XML
> Width = 256
> Height = 256
> MaxFeatures = null
> Tiled = true
> Palette = null
> SRS = EPSG:900913
>   GEOGCS["WGS 84",
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
> Bbox = SRSEnvelope[1086017.2977246 : 1095801.2373438, 7122708.0427344 :
> 7132491.9823535]
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> Transparent = true
> SldBody = null
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> BBOX=1086017.2977246,7122708.0427344,1095801.2373438,7132491.9823535,
> Version = 1.1.1
> Request = GetMap
> 2015-05-12 10:10:25,528 INFO [geoserver.wms] -
> 2015-05-12 10:10:25,530 INFO [geoserver.wms] -
> 2015-05-12 10:10:25,538 INFO [geoserver.wms] -
> 2015-05-12 10:10:25,547 INFO [geoserver.wms] -
> Request: getMap
> Exceptions = SE_XML
> Width = 512
> Height = 1024
> MaxFeatures = null
> Tiled = false
> Palette = null
> SRS = EPSG:900913
>   GEOGCS["WGS 84",
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
> Bbox = SRSEnvelope[1095801.237343751 : 1115369.1165820323,
> 7083572.284257814 : 7122708.042734373]
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> Transparent = true
> SldBody = null
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> BaseUrl = http://localhost:8080/geoserver/
> RawKvp =
> {BBOX=1095801.237343751,7083572.284257814,1115369.1165820323,7122708.042734373,
> SERVICE=WMS, HEIGHT=1024, REQUEST=GetMap, STYLES=style1_3d7625b4,
> WIDTH=512, EXCEPTIONS=SE_XML, TRANSPARENT=true, VERSION=1.1.1,
> FORMAT=image/png, GWC_SEED_INTERCEPT=true, LAYERS=geonode:layer11,
> SRS=EPSG:900913}
> Version = 1.1.1
> Request = GetMap
> 2015-05-12 10:10:25,560 INFO [geoserver.wms] -
> 2015-05-12 10:10:25,580 INFO [geoserver.wms] -
> Request: getMap
> Exceptions = SE_XML
> Width = 256
> Height = 256
> MaxFeatures = null
> Tiled = true
> Palette = null
> SRS = EPSG:900913
>   GEOGCS["WGS 84",
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7093356.223877 :
> 7103140.1634961]
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> Transparent = true
> SldBody = null
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> BBOX=1095801.2373438,7093356.223877,1105585.1769629,7103140.1634961,
> Version = 1.1.1
> Request = GetMap
> 2015-05-12 10:10:25,581 INFO [geoserver.wms] -
> Request: getMap
> Exceptions = SE_XML
> Width = 256
> Height = 256
> MaxFeatures = null
> Tiled = true
> Palette = null
> SRS = EPSG:900913
>   GEOGCS["WGS 84",
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7112924.1031152 :
> 7122708.0427344]
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> Transparent = true
> SldBody = null
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> BBOX=1095801.2373438,7112924.1031152,1105585.1769629,7122708.0427344,
> Version = 1.1.1
> Request = GetMap
> Request: getMap
> Exceptions = SE_XML
> Width = 256
> Height = 256
> MaxFeatures = null
> Tiled = true
> Palette = null
> SRS = EPSG:900913
>   GEOGCS["WGS 84",
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7103140.1634961 :
> 7112924.1031152]
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> Transparent = true
> SldBody = null
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> BBOX=1095801.2373438,7103140.1634961,1105585.1769629,7112924.1031152,
> Version = 1.1.1
> Request = GetMap
> 2015-05-12 10:10:25,762 INFO [geoserver.wms] -
> 2015-05-12 10:10:25,767 INFO [geoserver.wms] -
> 2015-05-12 10:10:25,770 INFO [geoserver.wms] -
> Request: getMap
> Exceptions = SE_XML
> Width = 256
> Height = 256
> MaxFeatures = null
> Tiled = true
> Palette = null
> SRS = EPSG:900913
>   GEOGCS["WGS 84",
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7083572.2842578 :
> 7093356.223877]
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> Transparent = true
> SldBody = null
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> BBOX=1095801.2373438,7083572.2842578,1105585.1769629,7093356.223877,
> Version = 1.1.1
> Request = GetMap
> 2015-05-12 10:10:25,773 INFO [geoserver.wms] -
> Request: getMap
> Exceptions = SE_XML
> Width = 256
> Height = 256
> MaxFeatures = null
> Tiled = true
> Palette = null
> SRS = EPSG:900913
>   GEOGCS["WGS 84",
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7083572.2842578 :
> 7093356.223877]
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> Transparent = true
> SldBody = null
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> BBOX=1046881.539248,7083572.2842578,1056665.4788672,7093356.223877,
> Version = 1.1.1
> Request = GetMap
> 2015-05-12 10:10:25,774 INFO [geoserver.wms] -
> 2015-05-12 10:10:25,785 INFO [geoserver.wms] -
> Request: getMap
> Exceptions = SE_XML
> Width = 1024
> Height = 1024
> MaxFeatures = null
> Tiled = false
> Palette = null
> SRS = EPSG:900913
>   GEOGCS["WGS 84",
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
> Bbox = SRSEnvelope[1017529.7203906253 : 1056665.478867188,
> 7122708.042734373 : 7161843.801210936]
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> Transparent = true
> SldBody = null
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> RawKvp = {BBOX=1017529.7203906253,7122708.042734373,1056665.478867188,7161843.801210936,
> WIDTH=1024, EXCEPTIONS=SE_XML, TRANSPARENT=true, VERSION=1.1.1,
> SRS=EPSG:900913}
> Version = 1.1.1
> Request = GetMap
> Request: getMap
> Exceptions = SE_XML
> Width = 512
> Height = 1024
> MaxFeatures = null
> Tiled = false
> Palette = null
> SRS = EPSG:900913
>   GEOGCS["WGS 84",
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> Transparent = true
> SldBody = null
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> RawKvp =
> {BBOX=1095801.237343751,7122708.042734373,1115369.1165820323,7161843.801210936,
> SRS=EPSG:900913}
> Version = 1.1.1
> Request = GetMap
> 2015-05-12 10:10:25,804 INFO [geoserver.wms] -
> Request: getMap
> Exceptions = SE_XML
> Width = 256
> Height = 256
> MaxFeatures = null
> Tiled = true
> Palette = null
> SRS = EPSG:900913
>   GEOGCS["WGS 84",
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7122708.0427344 :
> 7132491.9823535]
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> Transparent = true
> SldBody = null
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> BBOX=1095801.2373438,7122708.0427344,1105585.1769629,7132491.9823535,
> Version = 1.1.1
> Request = GetMap
> 2015-05-12 10:10:25,825 INFO [geoserver.wms] -
> Request: getMap
> Exceptions = SE_XML
> Width = 256
> Height = 256
> MaxFeatures = null
> Tiled = true
> Palette = null
> SRS = EPSG:900913
>   GEOGCS["WGS 84",
>   UNIT["m", 1.0],
>   AXIS["x", EAST],
>   AXIS["y", NORTH],
> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7122708.0427344 :
> 7132491.9823535]
> RemoteOwsURL = null
> Env = {}
> FormatOptions = {}
> Angle = 0.0
> CQLFilter = null
> Elevation = []
> FeatureId = null
> StartIndex = null
> ViewParams = null
> Transparent = true
> SldBody = null
> Sld = null
> SldVersion = null
> TilesOrigin = null
> Buffer = 0
> Format = image/png
> Time = []
> Filter = null
> Filters = null
> Get = true
> BBOX=1046881.539248,7122708.0427344,1056665.4788672,7132491.9823535,
> Version = 1.1.1
> Request = GetMap
> _____________________________________
> *A P L I K @ T E . E U <http://www.aplikate.eu/>*
> Linux, GIS and database developer team
> Wittmannsdorfer Str. 4
> 12053 Berlin
> Germany / Allemagne
> Tel.: +49 (0) 30 28 45 40 71
> Mobil: +49 (0) 163 681 77 34
> Fax: +49 (0)30 / 48 49 81 286
> 2015-05-12 11:55 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> that is indeed strange, it doesn't look at a permission bug. They ones
>> with no (none) might have a space instead. Do you have more information on
>> how you created those styles?
>> 2015-05-12 11:47 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>> okay I found a pattern now:
>>> in /admin/layers/style/
>>> [image: Inline-Bild 1]
>>> -The styles that have  "(None)" entry in the Workspace column  can be
>>> edited via geonode style editor
>>> -The styles that have no "(None)" entry entry in the Workspace column
>>>  canot be edited via geonode style editor
>>> How ever if i open a particular style in  /admin/layers/style/ , the
>>> workspace field is empty for all stlyes, wether they have a "(None)" entry
>>> in the Workspace column or not.
>>> Is this a bug with the django permissions system?
>>> 12053 Berlin
>>> Germany / Allemagne
>>> 2015-05-12 11:27 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>>> I have unticked the option "Automatic caching for non-standard styles"
>>>> in
>>>> /geoserver/web/?wicket:bookmarkablePage=:org.geoserver.gwc.web.GWCSettingsPage
>>>> That resolved the issue for a number of layers but not for all. The
>>>> style for one point layer n my installation is still only editable in
>>>> geoserver via SLD, not via geonode gui.
>>>> 2015-05-12 10:43 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>>>> hmm. The only difference I can see is that, here,  the problem occurs
>>>>> with a point layer
>>>>> 12053 Berlin
>>>>> Germany / Allemagne
>>>>> 2015-05-12 10:33 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>>> Rainer, I'm testing this here
>>>>>> http://demo.geonode.org/layers/geonode%3Astreams_2 but I can't
>>>>>> replicate.
>>>>>> 2015-05-12 10:23 GMT+02:00 Rainer Lissewski <
>>>>>> rainerlissewski at gmail.com>:
>>>>>>> Open a layer, edit layer, edit style. In the popup, select rule and
>>>>>>> edit. Change color and/or opacity. Save and close. Repeat process, the rule
>>>>>>> has reverted back to its original style.
>>>>>>> Also see https://github.com/GeoNode/geonode/issues/2146
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150512/2a800e60/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150512/2a800e60/attachment-0001.png>
More information about the geonode-users mailing list
