[GeoNode-users] Exists a project template for smartphone collection and upload?
Charles Cossé ccosse at gmail.com
Wed May 13 00:01:05 PDT 2015
Thanks for all the info, Simone.  Am travelling for next week so
reduced progress here but i'm on it.  Thanks again!
Charles
On 5/13/15, Simone Dalmasso <simone.dalmasso at gmail.com> wrote:
> Hi Charles,
> here a few clarifications. The geonode_project template as per doc should
> be used when you install geonode using apt-get (it's also possible to use
> it with geonode in dev mode or in manual installation with some more
> tricks). If you install geonode 2.4 (ppa/testing) then you have to use the
> branch 2.4 of the geonode_project. $ django-admin startproject my_geonode
> --template=https://github.com/GeoNode/geonode-project/archive/2.4.zip
> -epy,rst. We will migrate this branch to master when geonode 2.4 will be
> released as final.
> The project should not be installed in /var/www because that is the apache
> public directory and the /geonode folder that you see in there is for
> public files such as thumbnails. So use the geonode project in any
> directory you want but /var/www.
> The geonode_project will read the system geonode settings so you won't have
> to define those parameters.
> If you follow the guide https://github.com/GeoNode/geonode-project/tree/2.4
> as
> it is, then it should work fine. And you can edit/customize the geonode
> settings using the settings.py file that you fine in the geonode_project
> because the geonode settings and the geonode_project settings are linked
> together.
> Hope this helps.
> 2015-05-12 20:18 GMT+02:00 Charles Cossé <ccosse at gmail.com>:
>> When I installed ppa:geonode/testing it created /var/www/geonode, and
>> /etc/apache2/sites-available/geonode.conf corectly refers to the layout
>> of
>> the /var/www/geonode directory.
>> When I go to /var/www and do:
>>     $ django-admin startproject my_geonode --template=
>> https://github.com/GeoNode/geonode-project/archive/master.zip -epy,rst
>>     $ sudo pip install -e my_geonode
>> ... it creates /var/www/my_geonode, which has the familiar dango layout,
>> but I cannot get it to work.  I am particularly confused by the
>> difference
>> in the layouts of the two directories, /var/www/geonode and
>> /var/www/my_geonode.  I changed /etc/apache2/sites-available/geonode.conf
>> to correspond to the familiar django layout installed by geonode-project,
>> and proceeded to fight with it a little ...
>> Initially it threw up some real errors, which I began fixing
>> (geonode-project installed settings.py with undefined STATICFILES_DIRS,
>> TEMPLATE_DIRS, SECRET_KEY, ANONYMOUS_USER_ID) ... but after defining
>> those,
>> now the errors are auth-related and I think it's time to ask for more
>> help.
>> Here is the latest, ultimate error from the apache2/error.log:
>> [Tue May 12 12:47:41.126096 2015] [:error] [pid 3536:tid 140473235220224]
>> [remote 70.210.228.122:40065]   File
>> "/usr/lib/python2.7/dist-packages/tastypie/authentication.py", line 13,
>> in
>> <module>
>> [Tue May 12 12:47:41.126141 2015] [:error] [pid 3536:tid 140473235220224]
>> [remote 70.210.228.122:40065]     from tastypie.compat import User,
>> username_field
>> [Tue May 12 12:47:41.126201 2015] [:error] [pid 3536:tid 140473235220224]
>> [remote 70.210.228.122:40065] ImportError: cannot import name
>> username_field
>> Thank you in advance!
>> Charles
>> On Mon, May 11, 2015 at 1:22 PM, Ariel Nunez <ingenieroariel at gmail.com>
>> wrote:
>>> 14.04 and 2.4b25
>>> -a
>>> On Mon, May 11, 2015 at 10:53 AM, Simone Dalmasso <
>>>> geonode 2.4 is the way to go :)
>>>> 2015-05-11 17:32 GMT+02:00 Charles Cossé <ccosse at gmail.com>:
>>>>> Sorry, I forgot to ask one more question.  I have 2 servers:
>>>>>    1. Ubuntu 12.04 w/ 2.4.dev20150428072710
>>>>>    2. Ubuntu 14.04 w/ 2.4b25  (dev?)
>>>>> I need to reclaim (cancel) one of these servers ... I'm not sure if
>>>>> the
>>>>> 14.04 installation was a "developer's installation" or not?  The only
>>>>> reason I thought that it might be is just for the fact that it is still
>>>>> in
>>>>> development, so what other type install would there be?  But it doesn't
>>>>> use
>>>>> any of the virtual environment stuff like the 12.04 instance ... so I
>>>>> don't
>>>>> know ...which should I keep for developing the above?
>>>>> On Mon, May 11, 2015 at 8:52 AM, Charles Cossé <ccosse at gmail.com>
>>>>> wrote:
>>>>>> On Mon, May 11, 2015 at 8:13 AM, Simone Dalmasso <
>>>>>>> Well is your repo... :)
>>>>>> Okay, just checking in case use of personal repo could discourage
>>>>>> collaboration or something ... idk
>>>>>>> To link your app with GeoNode I suggest you to take a look at
>>>>>> Only that is for a website template (django-project), and I'm talking
>>>>>> about a web-app template (django-app) ... but yes, otherwise there
>>>>>> should
>>>>>> be much guidance within the code ...
>>>> Simone
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
More information about the geonode-users mailing list
