[GeoNode-users] translation of map tools
Francesco Bartoli xbartolone at gmail.com
Fri May 15 10:59:03 PDT 2015
Hi Jeffrey,
I created a PR for the Italian translation of geoexplorer sometime ago that has been merged by @bartvde into master and currently OpenGeo Suite ships GeoExplorer with such supported language. Anyway I see that https://github.com/GeoNode/geonode/blob/master/geonode/static/geonode/js/extjs/GeoNode-GeoExplorer.js doesn’t inherit the original as submodule so that work cannot be exploited automatically. Porting would impact just two files though.
Francesco
Il giorno 15/mag/2015, alle ore 15:26, Jeffrey Johnson <ortelius at gmail.com> ha scritto:
> I think we can use this setting here
> http://suite.opengeo.org/4.1/webapps/gxp/viewer/locale.html
> in here https://github.com/GeoNode/geonode/blob/master/geonode/maps/templates/maps/map_geoexplorer.js
> Can you give that a try and see if it works?
> On Fri, May 15, 2015 at 6:04 AM, Annalisa Schiavon
> <annalisa.schiavon at gmail.com> wrote:
>> Hi all,
>> Tools on GeoExplorer are labeled in English. there are some settings to
>> translate them? I've already set language = Italian and geonode correctly
>> translate many texts, but non all. In the map, not at all.
>> Thanks
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150515/b385aa43/attachment.html>
More information about the geonode-users mailing list
