[GeoNode-users] translation of map tools
Annalisa Schiavon annalisa.schiavon at gmail.com
Mon May 18 01:53:07 PDT 2015
Thank you all.
Jeffrey you mean geonode team to make the necessary changes or me in my
project?
I see now
https://github.com/GeoNode/geonode/blob/master/geonode/maps/templates/maps/map_geoexplorer.js#L12
that set GeoExt.Lang.set("{{ LANGUAGE_CODE }}");  like described here
http://suite.opengeo.org/4.1/webapps/gxp/viewer/locale.html
In my settings LANGUAGE_CODE  is = "it - IT".
I've just try to set  LANGUAGE_CODE = "it", but nothing has changed.
What else would I change?
Thanks
2015-05-15 20:00 GMT+02:00 Jeffrey Johnson <ortelius at gmail.com>:
> Not sure we can get boundless to pull. Maybe bart can help.
> Making the necessary changes on the geonode side should not be a problem.
> On Fri, May 15, 2015 at 10:59 AM, Francesco Bartoli
> <xbartolone at gmail.com> wrote:
> > Hi Jeffrey,
> > I created a PR for the Italian translation of geoexplorer sometime ago
> that
> > has been merged by @bartvde into master and currently OpenGeo Suite ships
> > GeoExplorer with such supported language. Anyway I see that
> https://github.com/GeoNode/geonode/blob/master/geonode/static/geonode/js/extjs/GeoNode-GeoExplorer.js
> > doesn’t inherit the original as submodule so that work cannot be
> exploited
> > automatically. Porting would impact just two files though.
> > Francesco
> > Il giorno 15/mag/2015, alle ore 15:26, Jeffrey Johnson <
> > ha scritto:
> > I think we can use this setting here
> > in here
> > Can you give that a try and see if it works?
> > On Fri, May 15, 2015 at 6:04 AM, Annalisa Schiavon
> > <annalisa.schiavon at gmail.com> wrote:
> > Hi all,
> > Tools on GeoExplorer are labeled in English. there are some settings to
> > translate them? I've already set language = Italian and geonode correctly
> > translate many texts, but non all. In the map, not at all.
> > Thanks
> > geonode-users mailing list
> > geonode-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150518/88fddfb8/attachment.html>
More information about the geonode-users mailing list
