[GeoNode-users] x
Jeffrey Johnson ortelius at gmail.com
Wed May 20 20:00:43 PDT 2015
Have you tried the importlayers management command? It should pick up the
related xml files.
On Wednesday, May 20, 2015, Jesús <gesusjl at gmail.com> wrote:
> Hi list members
> We have xml metadata files we would like to attach to geonode postgis and
> raster layers. Instead of filling the geonode forms one by one, is there a
> easy way to link the xml (as happens when upload shapefiles and rasters) to
> the layer, so geoserver can serve it also through the web services
> (getCapabilities etc.)?
> We have been checking some other solutions offered in this forum, but it
> looks  they  do not fit our required workflow. As i understand we can
> upload the xml as a document and then link the file to the layer, but not
> sure how we can make that both geonode  and geoserver use them. Geoserver
> provide a way to link xml metadata files which are accesible from internet,
> but as far as  know the xml file url from geonode is not directly accesible
> to be use in geoserver.
> In short,  we are creating the xml files outside geonode using other
> metadata tools and we dont want to fill the forms again using geonode
> frontend, but use some other custom solution that can be visible in geonode
> and geoserver.
> Some batching process  solution would be nice also. :)
> Regards
> Jesús
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150520/bd5ea030/attachment.html>
More information about the geonode-users mailing list
