[GeoNode-users] Using GeoNode and Geoserver in an unusual URL
Paolo Corti pcorti at gmail.com
Fri May 22 01:15:29 PDT 2015
You may also need to change the site name in the sites table (you can
do it from django admin)
regards
p
On Thu, May 21, 2015 at 8:40 PM, Davi Custodio <davicustodio at gmail.com> wrote:
> Hello!
> I'm using GeoNode 2.4b24, and I'm trying to make a change in conventional
> URL: http://aguai.cnpm.embrapa.br to http://aguai.cnpm.embrapa.br/monitoring
> I edited the local_settings.py and changed the SITEURL of
> http://aguai.cnpm.embrapa.br to http://aguai.cnpm.embrapa.br/monitoring.
> I restarted the Apache, and tested:
> I realized that the page started to answer but without the layout of css
> styles. Looking at the log console I realized requisition mistakes, who
> knows django trying to make calls using the default address
> http://aguai.cnpm.embrapa.br without using the monitoring.
> My question is: would like to set the call url like:
> GeoNode http://aguai.cnpm.embrapa.br/monitoring
> Geoserver http://aguai.cnpm.embrapa.br/monitoring/geoserver
> .. And what I should do but hit it in local_settings.py?
> I do not know if that's possible, mainly because of Geoserver calls, but
> would like to ask your help in this matter.
> Another question: if it is not possible to use Geoserver in
> http://aguai.cnpm.embrapa.br/monitoring/geoserver, it would be possible to
> use Geoserver in http://aguai.cnpm.embrapa.br/geoserver?
> Thanks
> Davi de O. Custódio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
