[GeoNode-users] Problems to change Geonode database name
Simone Dalmasso simone.dalmasso at gmail.com
Wed May 27 06:01:13 PDT 2015
There could be two reasons for this:
- the local_settings contain a syntax error and geonode is ignoring them
- the local_settings are not readable by geonode, but if you installed it
with apt-get (and you are editing /etc/geonode/local_settings.py) then is
not the case
2015-05-27 14:57 GMT+02:00 Davi Custodio <davicustodio at gmail.com>:
> Simone, how do I force Django to respect the new local_settings settings?
> On Wed, May 27, 2015 at 9:56 AM, Davi Custodio <davicustodio at gmail.com>
> wrote:
>> I forgot to put the setting of my local_settings.py:
>> DATABASE_ENGINE = 'postgresql_psycopg2'
>> DATABASE_NAME = 'cnpm_geonode'
>> DATABASE_USER = 'geonode'
>> DATABASE_PASSWORD = '*****'
>> DATABASE_HOST = 'jatoba.cnpm.embrapa.br'
>> DATABASE_PORT = '5432'
>> DATABASES = {
>>     'default': {
>>         'ENGINE': 'django.db.backends.postgresql_psycopg2',
>>         'NAME': DATABASE_NAME,
>>         'USER': DATABASE_USER,
>>         'PASSWORD': DATABASE_PASSWORD,
>>         'HOST': DATABASE_HOST,
>>         'PORT': DATABASE_PORT,
>>     'datastore': {
>>         'ENGINE': 'django.contrib.gis.db.backends.postgis',
>>         'NAME': 'cnpm_geonode_data',
>> On Wed, May 27, 2015 at 9:50 AM, Davi Custodio <davicustodio at gmail.com>
>> wrote:
>>> Hello. I have problem in GeoNode 2.4 to rename the GeoNode database. I
>>> need to change the names of "GeoNode" and "geonode_data" because I am
>>> centralizing the databases of various GeoNode servers in the same instance
>>> of PostgreSQL.
>>> I changed the names in local_settings.py, and then restarted the apache,
>>> and I received an error to Django still trying to find a database with old
>>> name "GeoNode".
>>> Besides local_settings.py, there is another location that I should
>>> change the database name?
>>> Below the full log.
>>> Davi.
>>> OperationalError at /
>>> FATAL:  database "geonode" does not exist
>>> Request Method:GETRequest URL:http://muchita.cnpm.embrapa.br/Django
>>> Version:1.6.1Exception Type:OperationalErrorException Value:
>>> Exception Location:/usr/lib/python2.7/dist-packages/psycopg2/__init__.py
>>> in connect, line 179Python Executable:/usr/bin/pythonPython Version:
>>> 2.7.6Python Path:
>>> ['/usr/lib/python2.7',
>>>  '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>>>  '/usr/lib/python2.7/lib-tk',
>>>  '/usr/lib/python2.7/lib-old',
>>>  '/usr/lib/python2.7/lib-dynload',
>>>  '/usr/local/lib/python2.7/dist-packages',
>>>  '/usr/lib/python2.7/dist-packages',
>>>  '/usr/lib/python2.7/dist-packages/PILcompat',
>>>  '/usr/lib/pymodules/python2.7',
>>>  '/var/www']
>>> Server time:Qua, 27 Mai 2015 07:36:18 -0500
>>> Traceback Switch to copy-and-paste view
>>> <http://muchita.cnpm.embrapa.br/#>
>>>    - /usr/lib/python2.7/dist-packages/django/core/handlers/base.py in
>>>    get_response
>>>    1.
>>>                       response = response.render()
>>>    ▶ Local vars <http://muchita.cnpm.embrapa.br/#>
>>>    - /usr/lib/python2.7/dist-packages/django/template/response.py in
>>>    render
>>>    1.
>>>                   self.content = self.rendered_content
>>>    rendered_content
>>>    1.
>>>               context = self.resolve_context(self.context_data)
>>>    resolve_context
>>>    1.
>>>               return RequestContext(self._request, context, current_app=self._current_app)
>>>    - /usr/lib/python2.7/dist-packages/django/template/context.py in
>>>    __init__
>>>    1.
>>>                   self.update(processor(request))
>>>    /usr/local/lib/python2.7/dist-packages/geonode/context_processors.py
>>>     in resource_urls
>>>    1.
>>>           site = Site.objects.get_current()
>>>    - /usr/lib/python2.7/dist-packages/django/contrib/sites/models.py in
>>>    get_current
>>>    1.
>>>                   current_site = self.get(pk=sid)
>>>    - /usr/lib/python2.7/dist-packages/django/db/models/manager.py in get
>>>    1.
>>>               return self.get_queryset().get(*args, **kwargs)
>>>    - /usr/lib/python2.7/dist-packages/django/db/models/query.py in get
>>>    1.
>>>               num = len(clone)
>>>    __len__
>>>    1.
>>>               self._fetch_all()
>>>    _fetch_all
>>>    1.
>>>                   self._result_cache = list(self.iterator())
>>>    iterator
>>>    1.
>>>               for row in compiler.results_iter():
>>>    - /usr/lib/python2.7/dist-packages/django/db/models/sql/compiler.py
>>>     in results_iter
>>>    1.
>>>               for rows in self.execute_sql(MULTI):
>>>     in execute_sql
>>>    1.
>>>               cursor = self.connection.cursor()
>>>    - /usr/lib/python2.7/dist-packages/django/db/backends/__init__.py in
>>>    cursor
>>>    1.
>>>                   cursor = self.make_debug_cursor(self._cursor())
>>>    _cursor
>>>    1.
>>>               self.ensure_connection()
>>>    ensure_connection
>>>    1.
>>>                       self.connect()
>>>    - /usr/lib/python2.7/dist-packages/django/db/utils.py in __exit__
>>>    1.
>>>                       six.reraise(dj_exc_type, dj_exc_value, traceback)
>>>    ensure_connection
>>>    1.
>>>                       self.connect()
>>>    connect
>>>    1.
>>>               self.connection = self.get_new_connection(conn_params)
>>>    /usr/lib/python2.7/dist-packages/django/db/backends/postgresql_psycopg2/base.py
>>>     in get_new_connection
>>>    1.
>>>               return Database.connect(**conn_params)
>>>    - /usr/lib/python2.7/dist-packages/psycopg2/__init__.py in connect
>>>    1.
>>>               connection_factory=connection_factory, async=async)
>>> Request informationGET
>>> No GET data
>>> POST
>>> No POST data
>>> FILES
>>> No FILES data
>>> COOKIESVariableValue__utmz
>>> '128008848.1432729377.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)'
>>> ys-user
>>> 'o%3Ausername%3Ds%253Aadmin%5Ename%3Ds%253Aadmin%5Esurname%3Ds%253Aadmin%5Erole%3Ds%253AAdministrator'
>>> _ga
>>> 'GA1.2.1150756117.1398259583'
>>> __gads
>>> 'ID=d961b8788d34039d:T=1413485184:S=ALNI_MaiaRd8gEEukW6akCBPz27sqFOcgQ'
>>> csrftoken
>>> 'GsCa0yBBEsMMf6hw6knF1r4qHcfafmXb'
>>> s_getNewRepeat
>>> '1423508214723-Repeat'
>>> ys-alreadyShowMessage
>>> 'b%3A1'
>>> __utma
>>> '128008848.1150756117.1398259583.1432729377.1432729377.1'
>>> __utmb
>>> '128008848.1.10.1432729377'
>>> __utmc
>>> '128008848'
>>> s_fid
>>> '691159BDD05014BE-21BD7FC62185D9C7'
>>> METAVariableValuemod_wsgi.listener_port
>>> '80'
>>> HTTP_COOKIE
>>> '__gads=ID=d961b8788d34039d:T=1413485184:S=ALNI_MaiaRd8gEEukW6akCBPz27sqFOcgQ; __utmz=237664978.1423046483.18.3.utmccn=(referral)|utmcsr=google.com.br|utmcct=/|utmcmd=referral; __utma=237664978.1207420118.1398169929.1423046483.1423244128.19; s_fid=691159BDD05014BE-21BD7FC62185D9C7; s_getNewRepeat=1423508214723-Repeat; __utma=218996109.1150756117.1398259583.1432299746.1432304989.52; __utmz=218996109.1432304989.52.23.utmcsr=chorao.cnpm.embrapa.br:9081|utmccn=(referral)|utmcmd=referral|utmcct=/; _ga=GA1.2.1150756117.1398259583; csrftoken=GsCa0yBBEsMMf6hw6knF1r4qHcfafmXb; __utma=128008848.1150756117.1398259583.1432729377.1432729377.1; __utmb=128008848.1.10.1432729377; __utmc=128008848; __utmz=128008848.1432729377.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); ys-alreadyShowMessage=b%3A1; ys-user=o%3Ausername%3Ds%253Aadmin%5Ename%3Ds%253Aadmin%5Esurname%3Ds%253Aadmin%5Erole%3Ds%253AAdministrator'
>>> mod_wsgi.listener_host
>>> CONTEXT_DOCUMENT_ROOT
>>> '/var/www'
>>> SERVER_SOFTWARE
>>> 'Apache/2.4.7 (Ubuntu)'
>>> SCRIPT_NAME
>>> u''
>>> mod_wsgi.enable_sendfile
>>> '0'
>>> mod_wsgi.handler_script
>>> SERVER_SIGNATURE
>>> '<address>Apache/2.4.7 (Ubuntu) Server at muchita.cnpm.embrapa.br Port 80</address>\n'
>>> REQUEST_METHOD
>>> 'GET'
>>> PATH_INFO
>>> u'/'
>>> SERVER_PROTOCOL
>>> 'HTTP/1.1'
>>> QUERY_STRING
>>> HTTP_USER_AGENT
>>> 'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/43.0.2357.65 Safari/537.36'
>>> HTTP_CONNECTION
>>> 'keep-alive'
>>> SERVER_NAME
>>> 'muchita.cnpm.embrapa.br'
>>> REMOTE_ADDR
>>> '10.157.20.55'
>>> mod_wsgi.queue_start
>>> '1432730176843671'
>>> mod_wsgi.request_handler
>>> 'wsgi-script'
>>> wsgi.url_scheme
>>> 'http'
>>> PATH_TRANSLATED
>>> '/var/www/geonode/wsgi/geonode.wsgi/'
>>> SERVER_PORT
>>> '80'
>>> wsgi.multiprocess
>>> True
>>> mod_wsgi.input_chunked
>>> '0'
>>> SERVER_ADDR
>>> '192.168.10.10'
>>> DOCUMENT_ROOT
>>> '/var/www'
>>> mod_wsgi.process_group
>>> 'geonode'
>>> HTTP_PRAGMA
>>> 'no-cache'
>>> SCRIPT_FILENAME
>>> '/var/www/geonode/wsgi/geonode.wsgi'
>>> SERVER_ADMIN
>>> 'webmaster at localhost'
>>> wsgi.input
>>> <mod_wsgi.Input object at 0x7fe089acf530>
>>> HTTP_HOST
>>> CONTEXT_PREFIX
>>> wsgi.multithread
>>> True
>>> mod_wsgi.callable_object
>>> 'application'
>>> HTTP_CACHE_CONTROL
>>> 'no-cache'
>>> REQUEST_URI
>>> HTTP_ACCEPT
>>> 'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8'
>>> wsgi.version
>>> (1, 0)
>>> GATEWAY_INTERFACE
>>> 'CGI/1.1'
>>> wsgi.run_once
>>> False
>>> wsgi.errors
>>> <mod_wsgi.Log object at 0x7fe0899a1f70>
>>> REMOTE_PORT
>>> '51799'
>>> HTTP_ACCEPT_LANGUAGE
>>> 'pt-PT,pt;q=0.8,pt-BR;q=0.6,en-US;q=0.4,en;q=0.2'
>>> REQUEST_SCHEME
>>> 'http'
>>> mod_wsgi.version
>>> (3, 4)
>>> mod_wsgi.application_group
>>> 'aguai.cnpm.embrapa.br|'
>>> mod_wsgi.script_reloading
>>> '1'
>>> wsgi.file_wrapper
>>> CSRF_COOKIE
>>> u'GsCa0yBBEsMMf6hw6knF1r4qHcfafmXb'
>>> HTTP_ACCEPT_ENCODING
>>> 'gzip, deflate, sdch'
>>> SettingsUsing settings module geonode.settingsSettingValue
>>> CASCADE_WORKSPACE
>>> 'geonode'
>>> ACCOUNT_USER_DISPLAY
>>> DATABASES
>>> {'datastore': {'ATOMIC_REQUESTS': False,
>>>                'AUTOCOMMIT': True,
>>>                'CONN_MAX_AGE': 0,
>>>                'HOST': 'jatoba.cnpm.embrapa.br',
>>>                'NAME': 'geonode_data',
>>>                'OPTIONS': {},
>>>                'PASSWORD': u'********************',
>>>                'PORT': '5432',
>>>                'TEST_CHARSET': None,
>>>                'TEST_COLLATION': None,
>>>                'TEST_MIRROR': None,
>>>                'TEST_NAME': None,
>>>                'TIME_ZONE': 'America/Chicago',
>>>                'USER': 'geonode'},
>>>  'default': {'ATOMIC_REQUESTS': False,
>>>              'AUTOCOMMIT': True,
>>>              'CONN_MAX_AGE': 0,
>>>              'NAME': 'geonode',
>>>              'OPTIONS': {},
>>>              'PORT': '5432',
>>>              'TEST_NAME': None,
>>>              'USER': 'geonode'}}
>>> GOOGLE_API_KEY
>>> CELERY_CREATE_MISSING_QUEUES
>>> True
>>> CSRF_COOKIE_SECURE
>>> False
>>> CELERY_DEFAULT_QUEUE
>>> 'default'
>>> UPLOADER
>>> {'BACKEND': 'geonode.rest',
>>>  'OPTIONS': {'GEOGIG_ENABLED': False, 'TIME_ENABLED': False}}
>>> LANGUAGE_CODE
>>> 'pt-br'
>>> LICENSES
>>> {'DETAIL': 'above', 'ENABLED': True, 'METADATA': 'verbose'}
>>> MANAGERS
>>> DOWNLOAD_FORMATS_METADATA
>>> ['Atom', 'DIF', 'Dublin Core', 'ebRIM', 'FGDC', 'ISO']
>>> BROKER_URL
>>> 'django://'
>>> DEFAULT_CHARSET
>>> 'utf-8'
>>> IGNORABLE_404_URLS
>>> CELERY_DEFAULT_EXCHANGE_TYPE
>>> 'direct'
>>> SESSION_SERIALIZER
>>> 'django.contrib.sessions.serializers.PickleSerializer'
>>> DEFAULT_MAP_CENTER
>>> (0, 0)
>>> ACCOUNT_EMAIL_CONFIRMATION_EXPIRE_DAYS
>>> 3
>>> USE_THOUSAND_SEPARATOR
>>> False
>>> ACCOUNT_EMAIL_CONFIRMATION_AUTHENTICATED_REDIRECT_URL
>>> None
>>> ACCOUNT_INVITE_USER_URL
>>> u'account_invite_user'
>>> REGISTRATION_OPEN
>>> False
>>> ALLOWED_HOSTS
>>> ['muchita.cnpm.embrapa.br', 'localhost']
>>> EMAIL_HOST
>>> 'localhost'
>>> DOWNLOAD_FORMATS_RASTER
>>> ['JPEG',
>>>  'PDF',
>>>  'PNG',
>>>  'ArcGrid',
>>>  'GeoTIFF',
>>>  'Gtopo30',
>>>  'ImageMosaic',
>>>  'KML',
>>>  'View in Google Earth',
>>>  'Tiles']
>>> AUTH_EXEMPT_URLS
>>> WSGI_APPLICATION
>>> None
>>> EMAIL_SUBJECT_PREFIX
>>> '[Django] '
>>> SEND_BROKEN_LINK_EMAILS
>>> False
>>> TEMPLATE_STRING_IF_INVALID
>>> STATICFILES_FINDERS
>>> ('django.contrib.staticfiles.finders.FileSystemFinder',
>>>  'django.contrib.staticfiles.finders.AppDirectoriesFinder')
>>> NOTIFICATION_QUEUE_ALL
>>> False
>>> SESSION_CACHE_ALIAS
>>> 'default'
>>> CELERY_IMPORTS
>>> ('geonode.tasks.deletion', 'geonode.tasks.update', 'geonode.tasks.email')
>>> SESSION_COOKIE_DOMAIN
>>> None
>>> SESSION_COOKIE_NAME
>>> 'sessionid'
>>> ADMIN_FOR
>>> TIME_INPUT_FORMATS
>>> ('%H:%M:%S', '%H:%M:%S.%f', '%H:%M')
>>> ACCOUNT_USE_AUTH_AUTHENTICATE
>>> False
>>> X_FRAME_OPTIONS
>>> 'SAMEORIGIN'
>>> FILE_UPLOAD_PERMISSIONS
>>> None
>>> ACCOUNT_TIMEZONES
>>> [('Africa/Abidjan', 'Africa/Abidjan'),
>>>  ('Africa/Accra', 'Africa/Accra'),
>>>  ('Africa/Addis_Ababa', 'Africa/Addis_Ababa'),
>>>  ('Africa/Algiers', 'Africa/Algiers'),
>>>  ('Africa/Asmara', 'Africa/Asmara'),
>>>  ('Africa/Asmera', 'Africa/Asmera'),
>>>  ('Africa/Bamako', 'Africa/Bamako'),
>>>  ('Africa/Bangui', 'Africa/Bangui'),
>>>  ('Africa/Banjul', 'Africa/Banjul'),
>>>  ('Africa/Bissau', 'Africa/Bissau'),
>>>  ('Africa/Blantyre', 'Africa/Blantyre'),
>>>  ('Africa/Brazzaville', 'Africa/Brazzaville'),
>>>  ('Africa/Bujumbura', 'Africa/Bujumbura'),
>>>  ('Africa/Cairo', 'Africa/Cairo'),
>>>  ('Africa/Casablanca', 'Africa/Casablanca'),
>>>  ('Africa/Ceuta', 'Africa/Ceuta'),
>>>  ('Africa/Conakry', 'Africa/Conakry'),
>>>  ('Africa/Dakar', 'Africa/Dakar'),
>>>  ('Africa/Dar_es_Salaam', 'Africa/Dar_es_Salaam'),
>>>  ('Africa/Djibouti', 'Africa/Djibouti'),
>>>  ('Africa/Douala', 'Africa/Douala'),
>>>  ('Africa/El_Aaiun', 'Africa/El_Aaiun'),
>>>  ('Africa/Freetown', 'Africa/Freetown'),
>>>  ('Africa/Gaborone', 'Africa/Gaborone'),
>>>  ('Africa/Harare', 'Africa/Harare'),
>>>  ('Africa/Johannesburg', 'Africa/Johannesburg'),
>>>  ('Africa/Juba', 'Africa/Juba'),
>>>  ('Africa/Kampala', 'Africa/Kampala'),
>>>  ('Africa/Khartoum', 'Africa/Khartoum'),
>>>  ('Africa/Kigali', 'Africa/Kigali'),
>>>  ('Africa/Kinshasa', 'Africa/Kinshasa'),
>>>  ('Africa/Lagos', 'Africa/Lagos'),
>>>  ('Africa/Libreville', 'Africa/Libreville'),
>>>  ('Africa/Lome', 'Africa/Lome'),
>>>  ('Africa/Luanda', 'Africa/Luanda'),
>>>  ('Africa/Lubumbashi', 'Africa/Lubumbashi'),
>>>  ('Africa/Lusaka', 'Africa/Lusaka'),
>>>  ('Africa/Malabo', 'Africa/Malabo'),
>>>  ('Africa/Maputo', 'Africa/Maputo'),
>>>  ('Africa/Maseru', 'Africa/Maseru'),
>>>  ('Africa/Mbabane', 'Africa/Mbabane'),
>>>  ('Africa/Mogadishu', 'Africa/Mogadishu'),
>>>  ('Africa/Monrovia', 'Africa/Monrovia'),
>>>  ('Africa/Nairobi', 'Africa/Nairobi'),
>>>  ('Africa/Ndjamena', 'Africa/Ndjamena'),
>>>  ('Africa/Niamey', 'Africa/Niamey'),
>>>  ('Africa/Nouakchott', 'Africa/Nouakchott'),
>>>  ('Africa/Ouagadougou', 'Africa/Ouagadougou'),
>>>  ('Africa/Porto-Novo', 'Africa/Porto-Novo'),
>>>  ('Africa/Sao_Tome', 'Africa/Sao_Tome'),
>>>  ('Africa/Timbuktu', 'Africa/Timbuktu'),
>>>  ('Africa/Tripoli', 'Africa/Tripoli'),
>>>  ('Africa/Tunis', 'Africa/Tunis'),
>>>  ('Africa/Windhoek', 'Africa/Windhoek'),
>>>  ('America/Adak', 'America/Adak'),
>>>  ('America/Anchorage', 'America/Anchorage'),
>>>  ('America/Anguilla', 'America/Anguilla'),
>>>  ('America/Antigua', 'America/Antigua'),
>>>  ('America/Araguaina', 'America/Araguaina'),
>>>  ('America/Argentina/Buenos_Aires', 'America/Argentina/Buenos_Aires'),
>>>  ('America/Argentina/Catamarca', 'America/Argentina/Catamarca'),
>>>  ('America/Argentina/ComodRivadavia', 'America/Argentina/ComodRivadavia'),
>>>  ('America/Argentina/Cordoba', 'America/Argentina/Cordoba'),
>>>  ('America/Argentina/Jujuy', 'America/Argentina/Jujuy'),
>>>  ('America/Argentina/La_Rioja', 'America/Argentina/La_Rioja'),
>>>  ('America/Argentina/Mendoza', 'America/Argentina/Mendoza'),
>>>  ('America/Argentina/Rio_Gallegos', 'America/Argentina/Rio_Gallegos'),
>>>  ('America/Argentina/Salta', 'America/Argentina/Salta'),
>>>  ('America/Argentina/San_Juan', 'America/Argentina/San_Juan'),
>>>  ('America/Argentina/San_Luis', 'America/Argentina/San_Luis'),
>>>  ('America/Argentina/Tucuman', 'America/Argentina/Tucuman'),
>>>  ('America/Argentina/Ushuaia', 'America/Argentina/Ushuaia'),
>>>  ('America/Aruba', 'America/Aruba'),
>>>  ('America/Asuncion', 'America/Asuncion'),
>>>  ('America/Atikokan', 'America/Atikokan'),
>>>  ('America/Atka', 'America/Atka'),
>>>  ('America/Bahia', 'America/Bahia'),
>>>  ('America/Bahia_Banderas', 'America/Bahia_Banderas'),
>>>  ('America/Barbados', 'America/Barbados'),
>>>  ('America/Belem', 'America/Belem'),
>>>  ('America/Belize', 'America/Belize'),
>>>  ('America/Blanc-Sablon', 'America/Blanc-Sablon'),
>>>  ('America/Boa_Vista', 'America/Boa_Vista'),
>>>  ('America/Bogota', 'America/Bogota'),
>>>  ('America/Boise', 'America/Boise'),
>>>  ('America/Buenos_Aires', 'America/Buenos_Aires'),
>>>  ('America/Cambridge_Bay', 'America/Cambridge_Bay'),
>>>  ('America/Campo_Grande', 'America/Campo_Grande'),
>>>  ('America/Cancun', 'America/Cancun'),
>>>  ('America/Caracas', 'America/Caracas'),
>>>  ('America/Catamarca', 'America/Catamarca'),
>>>  ('America/Cayenne', 'America/Cayenne'),
>>>  ('America/Cayman', 'America/Cayman'),
>>>  ('America/Chicago', 'America/Chicago'),
>>>  ('America/Chihuahua', 'America/Chihuahua'),
>>>  ('America/Coral_Harbour', 'America/Coral_Harbour'),
>>>  ('America/Cordoba', 'America/Cordoba'),
>>>  ('America/Costa_Rica', 'America/Costa_Rica'),
>>>  ('America/Creston', 'America/Creston'),
>>>  ('America/Cuiaba', 'America/Cuiaba'),
>>>  ('America/Curacao', 'America/Curacao'),
>>>  ('America/Danmarkshavn', 'America/Danmarkshavn'),
>>>  ('America/Dawson', 'America/Dawson'),
>>>  ('America/Dawson_Creek', 'America/Dawson_Creek'),
>>>  ('America/Denver', 'America/Denver'),
>>>  ('America/Detroit', 'America/Detroit'),
>>>  ('America/Dominica', 'America/Dominica'),
>>>  ('America/Edmonton', 'America/Edmonton'),
>>>  ('America/Eirunepe', 'America/Eirunepe'),
>>>  ('America/El_Salvador', 'America/El_Salvador'),
>>>  ('America/Ensenada', 'America/Ensenada'),
>>>  ('America/Fort_Wayne', 'America/Fort_Wayne'),
>>>  ('America/Fortaleza', 'America/Fortaleza'),
>>>  ('America/Glace_Bay', 'America/Glace_Bay'),
>>>  ('America/Godthab', 'America/Godthab'),
>>>  ('America/Goose_Bay', 'America/Goose_Bay'),
>>>  ('America/Grand_Turk', 'America/Grand_Turk'),
>>>  ('America/Grenada', 'America/Grenada'),
>>>  ('America/Guadeloupe', 'America/Guadeloupe'),
>>>  ('America/Guatemala', 'America/Guatemala'),
>>>  ('America/Guayaquil', 'America/Guayaquil'),
>>>  ('America/Guyana', 'America/Guyana'),
>>>  ('America/Halifax', 'America/Halifax'),
>>>  ('America/Havana', 'America/Havana'),
>>>  ('America/Hermosillo', 'America/Hermosillo'),
>>>  ('America/Indiana/Indianapolis', 'America/Indiana/Indianapolis'),
>>>  ('America/Indiana/Knox', 'America/Indiana/Knox'),
>>>  ('America/Indiana/Marengo', 'America/Indiana/Marengo'),
>>>  ('America/Indiana/Petersburg', 'America/Indiana/Petersburg'),
>>>  ('America/Indiana/Tell_City', 'America/Indiana/Tell_City'),
>>>  ('America/Indiana/Vevay', 'America/Indiana/Vevay'),
>>>  ('America/Indiana/Vincennes', 'America/Indiana/Vincennes'),
>>>  ('America/Indiana/Winamac', 'America/Indiana/Winamac'),
>>>  ('America/Indianapolis', 'America/Indianapolis'),
>>>  ('America/Inuvik', 'America/Inuvik'),
>>>  ('America/Iqaluit', 'America/Iqaluit'),
>>>  ('America/Jamaica', 'America/Jamaica'),
>>>  ('America/Jujuy', 'America/Jujuy'),
>>>  ('America/Juneau', 'America/Juneau'),
>>>  ('America/Kentucky/Louisville', 'America/Kentucky/Louisville'),
>>>  ('America/Kentucky/Monticello', 'America/Kentucky/Monticello'),
>>>  ('America/Knox_IN', 'America/Knox_IN'),
>>>  ('America/Kralendijk', 'America/Kralendijk'),
>>>  ('America/La_Paz', 'America/La_Paz'),
>>>  ('America/Lima', 'America/Lima'),
>>>  ('America/Los_Angeles', 'America/Los_Angeles'),
>>>  ('America/Louisville', 'America/Louisville'),
>>>  ('America/Lower_Princes', 'America/Lower_Princes'),
>>>  ('America/Maceio', 'America/Maceio'),
>>>  ('America/Managua', 'America/Managua'),
>>>  ('America/Manaus', 'America/Manaus'),
>>>  ('America/Marigot', 'America/Marigot'),
>>>  ('America/Martinique', 'America/Martinique'),
>>>  ('America/Matamoros', 'America/Matamoros'),
>>>  ('America/Mazatlan', 'America/Mazatlan'),
>>>  ('America/Mendoza', 'America/Mendoza'),
>>>  ('America/Menominee', 'America/Menominee'),
>>>  ('America/Merida', 'America/Merida'),
>>>  ('America/Metlakatla', 'America/Metlakatla'),
>>>  ('America/Mexico_City', 'America/Mexico_City'),
>>>  ('America/Miquelon', 'America/Miquelon'),
>>>  ('America/Moncton', 'America/Moncton'),
>>>  ('America/Monterrey', 'America/Monterrey'),
>>>  ('America/Montevideo', 'America/Montevideo'),
>>>  ('America/Montreal', 'America/Montreal'),
>>>  ('America/Montserrat', 'America/Montserrat'),
>>>  ('America/Nassau', 'America/Nassau'),
>>>  ('America/New_York', 'America/New_York'),
>>>  ('America/Nipigon', 'America/Nipigon'),
>>>  ('America/Nome', 'America/Nome'),
>>>  ('America/Noronha', 'America/Noronha'),
>>>  ('America/North_Dakota/Beulah', 'America/North_Dakota/Beulah'),
>>>  ('America/North_Dakota/Center', 'America/North_Dakota/Center'),
>>>  ('America/North_Dakota/New_Salem', 'America/North_Dakota/New_Salem'),
>>>  ('America/Ojinaga', 'America/Ojinaga'),
>>>  ('America/Panama', 'America/Panama'),
>>>  ('America/Pangnirtung', 'America/Pangnirtung'),
>>>  ('America/Paramaribo', 'America/Paramaribo'),
>>>  ('America/Phoenix', 'America/Phoenix'),
>>>  ('America/Port-au-Prince', 'America/Port-au-Prince'),
>>>  ('America/Port_of_Spain', 'America/Port_of_Spain'),
>>>  ('America/Porto_Acre', 'America/Porto_Acre'),
>>>  ('America/Porto_Velho', 'America/Porto_Velho'),
>>>  ('America/Puerto_Rico', 'America/Puerto_Rico'),
>>>  ('America/Rainy_River', 'America/Rainy_River'),
>>>  ('America/Rankin_Inlet', 'America/Rankin_Inlet'),
>>>  ('America/Recife', 'America/Recife'),
>>>  ('America/Regina', 'America/Regina'),
>>>  ('America/Resolute', 'America/Resolute'),
>>>  ('America/Rio_Branco', 'America/Rio_Branco'),
>>>  ('America/Rosario', 'America/Rosario'),
>>>  ('America/Santa_Isabel', 'America/Santa_Isabel'),
>>>  ('America/Santarem', 'America/Santarem'),
>>>  ('America/Santiago', 'America/Santiago'),
>>>  ('America/Santo_Domingo', 'America/Santo_Domingo'),
>>>  ('America/Sao_Paulo', 'America/Sao_Paulo'),
>>>  ('America/Scoresbysund', 'America/Scoresbysund'),
>>>  ('America/Shiprock', 'America/Shiprock'),
>>>  ('America/Sitka', 'America/Sitka'),
>>>  ('America/St_Barthelemy', 'America/St_Barthelemy'),
>>>  ('America/St_Johns', 'America/St_Johns'),
>>>  ('America/St_Kitts', 'America/St_Kitts'),
>>>  ('America/St_Lucia', 'America/St_Lucia'),
>>>  ('America/St_Thomas', 'America/St_Thomas'),
>>>  ('America/St_Vincent', 'America/St_Vincent'),
>>>  ('America/Swift_Current', 'America/Swift_Current'),
>>>  ('America/Tegucigalpa', 'America/Tegucigalpa'),
>>>  ('America/Thule', 'America/Thule'),
>>>  ('America/Thunder_Bay', 'America/Thunder_Bay'),
>>>  ('America/Tijuana', 'America/Tijuana'),
>>>  ('America/Toronto', 'America/Toronto'),
>>>  ('America/Tortola', 'America/Tortola'),
>>>  ('America/Vancouver', 'America/Vancouver'),
>>>  ('America/Virgin', 'America/Virgin'),
>>>  ('America/Whitehorse', 'America/Whitehorse'),
>>>  ('America/Winnipeg', 'America/Winnipeg'),
>>>  ('America/Yakutat', 'America/Yakutat'),
>>>  ('America/Yellowknife', 'America/Yellowknife'),
>>>  ('Antarctica/Casey', 'Antarctica/Casey'),
>>>  ('Antarctica/Davis', 'Antarctica/Davis'),
>>>  ('Antarctica/DumontDUrville', 'Antarctica/DumontDUrville'),
>>>  ('Antarctica/Macquarie', 'Antarctica/Macquarie'),
>>>  ('Antarctica/Mawson', 'Antarctica/Mawson'),
>>>  ('Antarctica/McMurdo', 'Antarctica/McMurdo'),
>>>  ('Antarctica/Palmer', 'Antarctica/Palmer'),
>>>  ('Antarctica/Rothera', 'Antarctica/Rothera'),
>>>  ('Antarctica/South_Pole', 'Antarctica/South_Pole'),
>>>  ('Antarctica/Syowa', 'Antarctica/Syowa'),
>>>  ('Antarctica/Vostok', 'Antarctica/Vostok'),
>>>  ('Arctic/Longyearbyen', 'Arctic/Longyearbyen'),
>>>  ('Asia/Aden', 'Asia/Aden'),
>>>  ('Asia/Almaty', 'Asia/Almaty'),
>>>  ('Asia/Amman', 'Asia/Amman'),
>>>  ('Asia/Anadyr', 'Asia/Anadyr'),
>>>  ('Asia/Aqtau', 'Asia/Aqtau'),
>>>  ('Asia/Aqtobe', 'Asia/Aqtobe'),
>>>  ('Asia/Ashgabat', 'Asia/Ashgabat'),
>>>  ('Asia/Ashkhabad', 'Asia/Ashkhabad'),
>>>  ('Asia/Baghdad', 'Asia/Baghdad'),
>>>  ('Asia/Bahrain', 'Asia/Bahrain'),
>>>  ('Asia/Baku', 'Asia/Baku'),
>>>  ('Asia/Bangkok', 'Asia/Bangkok'),
>>>  ('Asia/Beirut', 'Asia/Beirut'),
>>>  ('Asia/Bishkek', 'Asia/Bishkek'),
>>>  ('Asia/Brunei', 'Asia/Brunei'),
>>>  ('Asia/Calcutta', 'Asia/Calcutta'),
>>>  ('Asia/Choibalsan', 'Asia/Choibalsan'),
>>>  ('Asia/Chongqing', 'Asia/Chongqing'),
>>>  ('Asia/Chungking', 'Asia/Chungking'),
>>>  ('Asia/Colombo', 'Asia/Colombo'),
>>>  ('Asia/Dacca', 'Asia/Dacca'),
>>>  ('Asia/Damascus', 'Asia/Damascus'),
>>>  ('Asia/Dhaka', 'Asia/Dhaka'),
>>>  ('Asia/Dili', 'Asia/Dili'),
>>>  ('Asia/Dubai', 'Asia/Dubai'),
>>>  ('Asia/Dushanbe', 'Asia/Dushanbe'),
>>>  ('Asia/Gaza', 'Asia/Gaza'),
>>>  ('Asia/Harbin', 'Asia/Harbin'),
>>>  ('Asia/Hebron', 'Asia/Hebron'),
>>>  ('Asia/Ho_Chi_Minh', 'Asia/Ho_Chi_Minh'),
>>>  ('Asia/Hong_Kong', 'Asia/Hong_Kong'),
>>>  ('Asia/Hovd', 'Asia/Hovd'),
>>>  ('Asia/Irkutsk', 'Asia/Irkutsk'),
>>>  ('Asia/Istanbul', 'Asia/Istanbul'),
>>>  ('Asia/Jakarta', 'Asia/Jakarta'),
>>>  ('Asia/Jayapura', 'Asia/Jayapura'),
>>>  ('Asia/Jerusalem', 'Asia/Jerusalem'),
>>>  ('Asia/Kabul', 'Asia/Kabul'),
>>>  ('Asia/Kamchatka', 'Asia/Kamchatka'),
>>>  ('Asia/Karachi', 'Asia/Karachi'),
>>>  ('Asia/Kashgar', 'Asia/Kashgar'),
>>>  ('Asia/Kathmandu', 'Asia/Kathmandu'),
>>>  ('Asia/Katmandu', 'Asia/Katmandu'),
>>>  ('Asia/Kolkata', 'Asia/Kolkata'),
>>>  ('Asia/Krasnoyarsk', 'Asia/Krasnoyarsk'),
>>>  ('Asia/Kuala_Lumpur', 'Asia/Kuala_Lumpur'),
>>>  ('Asia/Kuching', 'Asia/Kuching'),
>>>  ('Asia/Kuwait', 'Asia/Kuwait'),
>>>  ('Asia/Macao', 'Asia/Macao'),
>>>  ('Asia/Macau', 'Asia/Macau'),
>>>  ('Asia/Magadan', 'Asia/Magadan'),
>>>  ('Asia/Makassar', 'Asia/Makassar'),
>>>  ('Asia/Manila', 'Asia/Manila'),
>>>  ('Asia/Muscat', 'Asia/Muscat'),
>>>  ('Asia/Nicosia', 'Asia/Nicosia'),
>>>  ('Asia/Novokuznetsk', 'Asia/Novokuznetsk'),
>>>  ('Asia/Novosibirsk', 'Asia/Novosibirsk'),
>>>  ('Asia/Omsk', 'Asia/Omsk'),
>>>  ('Asia/Oral', 'Asia/Oral'),
>>>  ('Asia/Phnom_Penh', 'Asia/Phnom_Penh'),
>>>  ('Asia/Pontianak', 'Asia/Pontianak'),
>>>  ('Asia/Pyongyang', 'Asia/Pyongyang'),
>>>  ('Asia/Qatar', 'Asia/Qatar'),
>>>  ('Asia/Qyzylorda', 'Asia/Qyzylorda'),
>>>  ('Asia/Rangoon', 'Asia/Rangoon'),
>>>  ('Asia/Riyadh', 'Asia/Riyadh'),
>>>  ('Asia/Saigon', 'Asia/Saigon'),
>>>  ('Asia/Sakhalin', 'Asia/Sakhalin'),
>>>  ('Asia/Samarkand', 'Asia/Samarkand'),
>>>  ('Asia/Seoul', 'Asia/Seoul'),
>>>  ('Asia/Shanghai', 'Asia/Shanghai'),
>>>  ('Asia/Singapore', 'Asia/Singapore'),
>>>  ('Asia/Taipei', 'Asia/Taipei'),
>>>  ('Asia/Tashkent', 'Asia/Tashkent'),
>>>  ('Asia/Tbilisi', 'Asia/Tbilisi'),
>>>  ('Asia/Tehran', 'Asia/Tehran'),
>>>  ('Asia/Tel_Aviv', 'Asia/Tel_Aviv'),
>>>  ('Asia/Thimbu', 'Asia/Thimbu'),
>>>  ('Asia/Thimphu', 'Asia/Thimphu'),
>>>  ('Asia/Tokyo', 'Asia/Tokyo'),
>>>  ('Asia/Ujung_Pandang', 'Asia/Ujung_Pandang'),
>>>  ('Asia/Ulaanbaatar', 'Asia/Ulaanbaatar'),
>>>  ('Asia/Ulan_Bator', 'Asia/Ulan_Bator'),
>>>  ('Asia/Urumqi', 'Asia/Urumqi'),
>>>  ('Asia/Vientiane', 'Asia/Vientiane'),
>>>  ('Asia/Vladivostok', 'Asia/Vladivostok'),
>>>  ('Asia/Yakutsk', 'Asia/Yakutsk'),
>>>  ('Asia/Yekaterinburg', 'Asia/Yekaterinburg'),
>>>  ('Asia/Yerevan', 'Asia/Yerevan'),
>>>  ('Atlantic/Azores', 'Atlantic/Azores'),
>>>  ('Atlantic/Bermuda', 'Atlantic/Bermuda'),
>>>  ('Atlantic/Canary', 'Atlantic/Canary'),
>>>  ('Atlantic/Cape_Verde', 'Atlantic/Cape_Verde'),
>>>  ('Atlantic/Faeroe', 'Atlantic/Faeroe'),
>>>  ('Atlantic/Faroe', 'Atlantic/Faroe'),
>>>  ('Atlantic/Jan_Mayen', 'Atlantic/Jan_Mayen'),
>>>  ('Atlantic/Madeira', 'Atlantic/Madeira'),
>>>  ('Atlantic/Reykjavik', 'Atlantic/Reykjavik'),
>>>  ('Atlantic/South_Georgia', 'Atlantic/South_Georgia'),
>>>  ('Atlantic/St_Helena', 'Atlantic/St_Helena'),
>>>  ('Atlantic/Stanley', 'Atlantic/Stanley'),
>>>  ('Australia/ACT', 'Australia/ACT'),
>>>  ('Australia/Adelaide', 'Australia/Adelaide'),
>>>  ('Australia/Brisbane', 'Australia/Brisbane'),
>>>  ('Australia/Broken_Hill', 'Australia/Broken_Hill'),
>>>  ('Australia/Canberra', 'Australia/Canberra'),
>>>  ('Australia/Currie', 'Australia/Currie'),
>>>  ('Australia/Darwin', 'Australia/Darwin'),
>>>  ('Australia/Eucla', 'Australia/Eucla'),
>>>  ('Australia/Hobart', 'Australia/Hobart'),
>>>  ('Australia/LHI', 'Australia/LHI'),
>>>  ('Australia/Lindeman', 'Australia/Lindeman'),
>>>  ('Australia/Lord_Howe', 'Australia/Lord_Howe'),
>>>  ('Australia/Melbourne', 'Australia/Melbourne'),
>>>  ('Australia/NSW', 'Australia/NSW'),
>>>  ('Australia/North', 'Australia/North'),
>>>  ('Australia/Perth', 'Australia/Perth'),
>>>  ('Australia/Queensland', 'Australia/Queensland'),
>>>  ('Australia/South', 'Australia/South'),
>>>  ('Australia/Sydney', 'Australia/Sydney'),
>>>  ('Australia/Tasmania', 'Australia/Tasmania'),
>>>  ('Australia/Victoria', 'Australia/Victoria'),
>>>  ('Australia/West', 'Australia/West'),
>>>  ('Australia/Yancowinna', 'Australia/Yancowinna'),
>>>  ('Brazil/Acre', 'Brazil/Acre'),
>>>  ('Brazil/DeNoronha', 'Brazil/DeNoronha'),
>>>  ('Brazil/East', 'Brazil/East'),
>>>  ('Brazil/West', 'Brazil/West'),
>>>  ('CET', 'CET'),
>>>  ('CST6CDT', 'CST6CDT'),
>>>  ('Canada/Atlantic', 'Canada/Atlantic'),
>>>  ('Canada/Central', 'Canada/Central'),
>>>  ('Canada/East-Saskatchewan', 'Canada/East-Saskatchewan'),
>>>  ('Canada/Eastern', 'Canada/Eastern'),
>>>  ('Canada/Mountain', 'Canada/Mountain'),
>>>  ('Canada/Newfoundland', 'Canada/Newfoundland'),
>>>  ('Canada/Pacific', 'Canada/Pacific'),
>>>  ('Canada/Saskatchewan', 'Canada/Saskatchewan'),
>>>  ('Canada/Yukon', 'Canada/Yukon'),
>>>  ('Chile/Continental', 'Chile/Continental'),
>>>  ('Chile/EasterIsland', 'Chile/EasterIsland'),
>>>  ('Cuba', 'Cuba'),
>>>  ('EET', 'EET'),
>>>  ('EST', 'EST'),
>>>  ('EST5EDT', 'EST5EDT'),
>>>  ('Egypt', 'Egypt'),
>>>  ('Eire', 'Eire'),
>>>  ('Etc/GMT', 'Etc/GMT'),
>>>  ('Etc/GMT+0', 'Etc/GMT+0'),
>>>  ('Etc/GMT+1', 'Etc/GMT+1'),
>>>  ('Etc/GMT+10', 'Etc/GMT+10'),
>>>  ('Etc/GMT+11', 'Etc/GMT+11'),
>>>  ('Etc/GMT+12', 'Etc/GMT+12'),
>>>  ('Etc/GMT+2', 'Etc/GMT+2'),
>>>  ('Etc/GMT+3', 'Etc/GMT+3'),
>>>  ('Etc/GMT+4', 'Etc/GMT+4'),
>>>  ('Etc/GMT+5', 'Etc/GMT+5'),
>>>  ('Etc/GMT+6', 'Etc/GMT+6'),
>>>  ('Etc/GMT+7', 'Etc/GMT+7'),
>>>  ('Etc/GMT+8', 'Etc/GMT+8'),
>>>  ('Etc/GMT+9', 'Etc/GMT+9'),
>>>  ('Etc/GMT-0', 'Etc/GMT-0'),
>>>  ('Etc/GMT-1', 'Etc/GMT-1'),
>>>  ('Etc/GMT-10', 'Etc/GMT-10'),
>>>  ('Etc/GMT-11', 'Etc/GMT-11'),
>>>  ('Etc/GMT-12', 'Etc/GMT-12'),
>>>  ('Etc/GMT-13', 'Etc/GMT-13'),
>>>  ('Etc/GMT-14', 'Etc/GMT-14'),
>>>  ('Etc/GMT-2', 'Etc/GMT-2'),
>>>  ('Etc/GMT-3', 'Etc/GMT-3'),
>>>  ('Etc/GMT-4', 'Etc/GMT-4'),
>>>  ('Etc/GMT-5', 'Etc/GMT-5'),
>>>  ('Etc/GMT-6', 'Etc/GMT-6'),
>>>  ('Etc/GMT-7', 'Etc/GMT-7'),
>>>  ('Etc/GMT-8', 'Etc/GMT-8'),
>>>  ('Etc/GMT-9', 'Etc/GMT-9'),
>>>  ('Etc/GMT0', 'Etc/GMT0'),
>>>  ('Etc/Greenwich', 'Etc/Greenwich'),
>>>  ('Etc/UCT', 'Etc/UCT'),
>>>  ('Etc/UTC', 'Etc/UTC'),
>>>  ('Etc/Universal', 'Etc/Universal'),
>>>  ('Etc/Zulu', 'Etc/Zulu'),
>>>  ('Europe/Amsterdam', 'Europe/Amsterdam'),
>>>  ('Europe/Andorra', 'Europe/Andorra'),
>>>  ('Europe/Athens', 'Europe/Athens'),
>>>  ('Europe/Belfast', 'Europe/Belfast'),
>>>  ('Europe/Belgrade', 'Europe/Belgrade'),
>>>  ('Europe/Berlin', 'Europe/Berlin'),
>>>  ('Europe/Bratislava', 'Europe/Bratislava'),
>>>  ('Europe/Brussels', 'Europe/Brussels'),
>>>  ('Europe/Bucharest', 'Europe/Bucharest'),
>>>  ('Europe/Budapest', 'Europe/Budapest'),
>>>  ('Europe/Chisinau', 'Europe/Chisinau'),
>>>  ('Europe/Copenhagen', 'Europe/Copenhagen'),
>>>  ('Europe/Dublin', 'Europe/Dublin'),
>>>  ('Europe/Gibraltar', 'Europe/Gibraltar'),
>>>  ('Europe/Guernsey', 'Europe/Guernsey'),
>>>  ('Europe/Helsinki', 'Europe/Helsinki'),
>>>  ('Europe/Isle_of_Man', 'Europe/Isle_of_Man'),
>>>  ('Europe/Istanbul', 'Europe/Istanbul'),
>>>  ('Europe/Jersey', 'Europe/Jersey'),
>>>  ('Europe/Kaliningrad', 'Europe/Kaliningrad'),
>>>  ('Europe/Kiev', 'Europe/Kiev'),
>>>  ('Europe/Lisbon', 'Europe/Lisbon'),
>>>  ('Europe/Ljubljana', 'Europe/Ljubljana'),
>>>  ('Europe/London', 'Europe/London'),
>>>  ('Europe/Luxembourg', 'Europe/Luxembourg'),
>>>  ('Europe/Madrid', 'Europe/Madrid'),
>>>  ('Europe/Malta', 'Europe/Malta'),
>>>  ('Europe/Mariehamn', 'Europe/Mariehamn'),
>>>  ('Europe/Minsk', 'Europe/Minsk'),
>>>  ('Europe/Monaco', 'Europe/Monaco'),
>>>  ('Europe/Moscow', 'Europe/Moscow'),
>>>  ('Europe/Nicosia', 'Europe/Nicosia'),
>>>  ('Europe/Oslo', 'Europe/Oslo'),
>>>  ('Europe/Paris', 'Europe/Paris'),
>>>  ('Europe/Podgorica', 'Europe/Podgorica'),
>>>  ('Europe/Prague', 'Europe/Prague'),
>>>  ('Europe/Riga', 'Europe/Riga'),
>>>  ('Europe/Rome', 'Europe/Rome'),
>>>  ('Europe/Samara', 'Europe/Samara'),
>>>  ('Europe/San_Marino', 'Europe/San_Marino'),
>>>  ('Europe/Sarajevo', 'Europe/Sarajevo'),
>>>  ('Europe/Simferopol', 'Europe/Simferopol'),
>>>  ('Europe/Skopje', 'Europe/Skopje'),
>>>  ('Europe/Sofia', 'Europe/Sofia'),
>>>  ('Europe/Stockholm', 'Europe/Stockholm'),
>>>  ('Europe/Tallinn', 'Europe/Tallinn'),
>>>  ('Europe/Tirane', 'Europe/Tirane'),
>>>  ('Europe/Tiraspol', 'Europe/Tiraspol'),
>>>  ('Europe/Uzhgorod', 'Europe/Uzhgorod'),
>>>  ('Europe/Vaduz', 'Europe/Vaduz'),
>>>  ('Europe/Vatican', 'Europe/Vatican'),
>>>  ('Europe/Vienna', 'Europe/Vienna'),
>>>  ('Europe/Vilnius', 'Europe/Vilnius'),
>>>  ('Europe/Volgograd', 'Europe/Volgograd'),
>>>  ('Europe/Warsaw', 'Europe/Warsaw'),
>>>  ('Europe/Zagreb', 'Europe/Zagreb'),
>>>  ('Europe/Zaporozhye', 'Europe/Zaporozhye'),
>>>  ('Europe/Zurich', 'Europe/Zurich'),
>>>  ('GB', 'GB'),
>>>  ('GB-Eire', 'GB-Eire'),
>>>  ('GMT', 'GMT'),
>>>  ('GMT+0', 'GMT+0'),
>>>  ('GMT-0', 'GMT-0'),
>>>  ('GMT0', 'GMT0'),
>>>  ('Greenwich', 'Greenwich'),
>>>  ('HST', 'HST'),
>>>  ('Hongkong', 'Hongkong'),
>>>  ('Iceland', 'Iceland'),
>>>  ('Indian/Antananarivo', 'Indian/Antananarivo'),
>>>  ('Indian/Chagos', 'Indian/Chagos'),
>>>  ('Indian/Christmas', 'Indian/Christmas'),
>>>  ('Indian/Cocos', 'Indian/Cocos'),
>>>  ('Indian/Comoro', 'Indian/Comoro'),
>>>  ('Indian/Kerguelen', 'Indian/Kerguelen'),
>>>  ('Indian/Mahe', 'Indian/Mahe'),
>>>  ('Indian/Maldives', 'Indian/Maldives'),
>>>  ('Indian/Mauritius', 'Indian/Mauritius'),
>>>  ('Indian/Mayotte', 'Indian/Mayotte'),
>>>  ('Indian/Reunion', 'Indian/Reunion'),
>>>  ('Iran', 'Iran'),
>>>  ('Israel', 'Israel'),
>>>  ('Jamaica', 'Jamaica'),
>>>  ('Japan', 'Japan'),
>>>  ('Kwajalein', 'Kwajalein'),
>>>  ('Libya', 'Libya'),
>>>  ('MET', 'MET'),
>>>  ('MST', 'MST'),
>>>  ('MST7MDT', 'MST7MDT'),
>>>  ('Mexico/BajaNorte', 'Mexico/BajaNorte'),
>>>  ('Mexico/BajaSur', 'Mexico/BajaSur'),
>>>  ('Mexico/General', 'Mexico/General'),
>>>  ('NZ', 'NZ'),
>>>  ('NZ-CHAT', 'NZ-CHAT'),
>>>  ('Navajo', 'Navajo'),
>>>  ('PRC', 'PRC'),
>>>  ('PST8PDT', 'PST8PDT'),
>>>  ('Pacific/Apia', 'Pacific/Apia'),
>>>  ('Pacific/Auckland', 'Pacific/Auckland'),
>>>  ('Pacific/Chatham', 'Pacific/Chatham'),
>>>  ('Pacific/Chuuk', 'Pacific/Chuuk'),
>>>  ('Pacific/Easter', 'Pacific/Easter'),
>>>  ('Pacific/Efate', 'Pacific/Efate'),
>>>  ('Pacific/Enderbury', 'Pacific/Enderbury'),
>>>  ('Pacific/Fakaofo', 'Pacific/Fakaofo'),
>>>  ('Pacific/Fiji', 'Pacific/Fiji'),
>>>  ('Pacific/Funafuti', 'Pacific/Funafuti'),
>>>  ('Pacific/Galapagos', 'Pacific/Galapagos'),
>>>  ('Pacific/Gambier', 'Pacific/Gambier'),
>>>  ('Pacific/Guadalcanal', 'Pacific/Guadalcanal'),
>>>  ('Pacific/Guam', 'Pacific/Guam'),
>>>  ('Pacific/Honolulu', 'Pacific/Honolulu'),
>>>  ('Pacific/Johnston', 'Pacific/Johnston'),
>>>  ('Pacific/Kiritimati', 'Pacific/Kiritimati'),
>>>  ('Pacific/Kosrae', 'Pacific/Kosrae'),
>>>  ('Pacific/Kwajalein', 'Pacific/Kwajalein'),
>>>  ('Pacific/Majuro', 'Pacific/Majuro'),
>>>  ('Pacific/Marquesas', 'Pacific/Marquesas'),
>>>  ('Pacific/Midway', 'Pacific/Midway'),
>>>  ('Pacific/Nauru', 'Pacific/Nauru'),
>>>  ('Pacific/Niue', 'Pacific/Niue'),
>>>  ('Pacific/Norfolk', 'Pacific/Norfolk'),
>>>  ('Pacific/Noumea', 'Pacific/Noumea'),
>>>  ('Pacific/Pago_Pago', 'Pacific/Pago_Pago'),
>>>  ('Pacific/Palau', 'Pacific/Palau'),
>>>  ('Pacific/Pitcairn', 'Pacific/Pitcairn'),
>>>  ('Pacific/Pohnpei', 'Pacific/Pohnpei'),
>>>  ('Pacific/Ponape', 'Pacific/Ponape'),
>>>  ('Pacific/Port_Moresby', 'Pacific/Port_Moresby'),
>>>  ('Pacific/Rarotonga', 'Pacific/Rarotonga'),
>>>  ('Pacific/Saipan', 'Pacific/Saipan'),
>>>  ('Pacific/Samoa', 'Pacific/Samoa'),
>>>  ('Pacific/Tahiti', 'Pacific/Tahiti'),
>>>  ('Pacific/Tarawa', 'Pacific/Tarawa'),
>>>  ('Pacific/Tongatapu', 'Pacific/Tongatapu'),
>>>  ('Pacific/Truk', 'Pacific/Truk'),
>>>  ('Pacific/Wake', 'Pacific/Wake'),
>>>  ('Pacific/Wallis', 'Pacific/Wallis'),
>>>  ('Pacific/Yap', 'Pacific/Yap'),
>>>  ('Poland', 'Poland'),
>>>  ('Portugal', 'Portugal'),
>>>  ('ROC', 'ROC'),
>>>  ('ROK', 'ROK'),
>>>  ('Singapore', 'Singapore'),
>>>  ('Turkey', 'Turkey'),
>>>  ('UCT', 'UCT'),
>>>  ('US/Alaska', 'US/Alaska'),
>>>  ('US/Aleutian', 'US/Aleutian'),
>>>  ('US/Arizona', 'US/Arizona'),
>>>  ('US/Central', 'US/Central'),
>>>  ('US/East-Indiana', 'US/East-Indiana'),
>>>  ('US/Eastern', 'US/Eastern'),
>>>  ('US/Hawaii', 'US/Hawaii'),
>>>  ('US/Indiana-Starke', 'US/Indiana-Starke'),
>>>  ('US/Michigan', 'US/Michigan'),
>>>  ('US/Mountain', 'US/Mountain'),
>>>  ('US/Pacific', 'US/Pacific'),
>>>  ('US/Pacific-New', 'US/Pacific-New'),
>>>  ('US/Samoa', 'US/Samoa'),
>>>  ('UTC', 'UTC'),
>>>  ('Universal', 'Universal'),
>>>  ('W-SU', 'W-SU'),
>>>  ('WET', 'WET'),
>>>  ('Zulu', 'Zulu')]
>>> FILE_UPLOAD_HANDLERS
>>> ('django.core.files.uploadhandler.MemoryFileUploadHandler',
>>>  'django.core.files.uploadhandler.TemporaryFileUploadHandler')
>>> DEFAULT_CONTENT_TYPE
>>> 'text/html'
>>> DEBUG_STATIC
>>> False
>>> ACCOUNT_APPROVAL_REQUIRED
>>> False
>>> APPEND_SLASH
>>> True
>>> FIRST_DAY_OF_WEEK
>>> 0
>>> DATABASE_ROUTERS
>>> DEFAULT_TABLESPACE
>>> YEAR_MONTH_FORMAT
>>> 'F Y'
>>> STATICFILES_STORAGE
>>> 'django.contrib.staticfiles.storage.StaticFilesStorage'
>>> CACHES
>>> {'default': {'BACKEND': 'django.core.cache.backends.dummy.DummyCache'}}
>>> DEFAULT_ANONYMOUS_DOWNLOAD_PERMISSION
>>> True
>>> CKAN_ORIGINS
>>> [{'css_class': 'hdx',
>>>   'label': 'Humanitarian Data Exchange (HDX)',
>>>   'url': 'https://data.hdx.rwlabs.org/dataset/new?title={name}&dataset_date={date}&notes={abstract}&caveats={caveats}'}]
>>> ACCOUNT_EMAIL_CONFIRMATION_EMAIL
>>> False
>>> SERVER_EMAIL
>>> 'root at localhost'
>>> SESSION_COOKIE_PATH
>>> USE_X_FORWARDED_HOST
>>> False
>>> ACCOUNT_OPEN_SIGNUP
>>> True
>>> ROOT_URLCONF
>>> 'geonode.urls'
>>> CATALOGUE
>>> {'default': {'ENGINE': 'geonode.catalogue.backends.pycsw_local',
>>>              'URL': 'http://muchita.cnpm.embrapa.br/catalogue/csw'}}
>>> MISSING_THUMBNAIL
>>> 'geonode/img/missing_thumb.png'
>>> FILE_UPLOAD_TEMP_DIR
>>> None
>>> MIDDLEWARE_CLASSES
>>> ('django.middleware.common.CommonMiddleware',
>>>  'django.contrib.sessions.middleware.SessionMiddleware',
>>>  'django.contrib.messages.middleware.MessageMiddleware',
>>>  'django.middleware.locale.LocaleMiddleware',
>>>  'pagination.middleware.PaginationMiddleware',
>>>  'django.middleware.csrf.CsrfViewMiddleware',
>>>  'django.contrib.auth.middleware.AuthenticationMiddleware',
>>>  'django.middleware.clickjacking.XFrameOptionsMiddleware')
>>> USE_I18N
>>> True
>>> THOUSAND_SEPARATOR
>>> SECRET_KEY
>>> MODELTRANSLATION_FALLBACK_LANGUAGES
>>> ('en',)
>>> LANGUAGE_COOKIE_NAME
>>> 'django_language'
>>> ACCOUNT_REMEMBER_ME_EXPIRY
>>> 315360000
>>> ACCOUNT_PASSWORD_CHANGE_REDIRECT_URL
>>> ACCOUNT_EMAIL_UNIQUE
>>> True
>>> TRANSACTIONS_MANAGED
>>> False
>>> LOGGING_CONFIG
>>> 'django.utils.log.dictConfig'
>>> TEMPLATE_LOADERS
>>> ('django.template.loaders.filesystem.Loader',
>>>  'django.template.loaders.app_directories.Loader')
>>> FORCE_SCRIPT_NAME
>>> None
>>> TASTYPIE_DEFAULT_FORMATS
>>> ['json']
>>> TEMPLATE_DEBUG
>>> True
>>> AUTO_GENERATE_AVATAR_SIZES
>>> (20, 32, 80, 100, 140, 200)
>>> CSRF_COOKIE_NAME
>>> 'csrftoken'
>>> 'default'
>>> CELERY_DEFAULT_ROUTING_KEY
>>> ACCOUNT_LOGIN_REDIRECT_URL
>>> u'/'
>>> CELERY_ALWAYS_EAGER
>>> True
>>> MODIFY_TOPICCATEGORY
>>> False
>>> SIGNING_BACKEND
>>> 'django.core.signing.TimestampSigner'
>>> SESSION_COOKIE_SECURE
>>> False
>>> ACCOUNT_LOGIN_URL
>>> u'account_login'
>>> CACHE_TIME
>>> 0
>>> PYCSW
>>> {'CONFIGURATION': {'metadata:inspire': {'conformity_service': 'notEvaluated',
>>>                                         'contact_email': 'Email Address',
>>>                                         'contact_name': 'Organization Name',
>>>                                         'date': 'YYYY-MM-DD',
>>>                                         'default_language': 'eng',
>>>                                         'enabled': 'true',
>>>                                         'gemet_keywords': 'Utility and governmental services',
>>>                                         'languages_supported': 'eng,gre',
>>>                                         'temp_extent': 'YYYY-MM-DD/YYYY-MM-DD'},
>>>                    'metadata:main': {'contact_address': 'Mailing Address',
>>>                                      'contact_city': 'City',
>>>                                      'contact_country': 'Country',
>>>                                      'contact_fax': '+xx-xxx-xxx-xxxx',
>>>                                      'contact_hours': 'Hours of Service',
>>>                                      'contact_instructions': 'During hours of service. Off on weekends.',
>>>                                      'contact_name': 'Lastname, Firstname',
>>>                                      'contact_phone': '+xx-xxx-xxx-xxxx',
>>>                                      'contact_position': 'Position Title',
>>>                                      'contact_postalcode': 'Zip or Postal Code',
>>>                                      'contact_role': 'pointOfContact',
>>>                                      'contact_stateorprovince': 'Administrative Area',
>>>                                      'contact_url': 'Contact URL',
>>>                                      'identification_abstract': 'GeoNode is an open source platform that facilitates the creation, sharing,              and collaborative use of geospatial data',
>>>                                      'identification_accessconstraints': 'None',
>>>                                      'identification_fees': 'None',
>>>                                      'identification_keywords': 'sdi,catalogue,discovery,metadata,GeoNode',
>>>                                      'identification_keywords_type': 'theme',
>>>                                      'identification_title': 'GeoNode Catalogue',
>>>                                      'provider_name': 'Organization Name',
>>>                                      'provider_url': 'http://localhost:8000/'}}}
>>> CSRF_COOKIE_DOMAIN
>>> None
>>> FILE_CHARSET
>>> 'utf-8'
>>> DEBUG
>>> True
>>> SESSION_FILE_PATH
>>> None
>>> DEFAULT_FILE_STORAGE
>>> 'django.core.files.storage.FileSystemStorage'
>>> INSTALLED_APPS
>>> ('django.contrib.auth',
>>>  'django.contrib.contenttypes',
>>>  'django.contrib.sessions',
>>>  'django.contrib.sites',
>>>  'django.contrib.admin',
>>>  'django.contrib.sitemaps',
>>>  'django.contrib.staticfiles',
>>>  'django.contrib.messages',
>>>  'django.contrib.humanize',
>>>  'django.contrib.gis',
>>>  'pagination',
>>>  'taggit',
>>>  'friendlytagloader',
>>>  'geoexplorer',
>>>  'leaflet',
>>>  'django_extensions',
>>>  'autocomplete_light',
>>>  'mptt',
>>>  'modeltranslation',
>>>  'djcelery',
>>>  'pinax_theme_bootstrap_account',
>>>  'pinax_theme_bootstrap',
>>>  'django_forms_bootstrap',
>>>  'account',
>>>  'avatar',
>>>  'dialogos',
>>>  'agon_ratings',
>>>  'announcements',
>>>  'actstream',
>>>  'user_messages',
>>>  'tastypie',
>>>  'polymorphic',
>>>  'guardian',
>>>  'geonode.people',
>>>  'geonode.base',
>>>  'geonode.layers',
>>>  'geonode.maps',
>>>  'geonode.proxy',
>>>  'geonode.security',
>>>  'geonode.social',
>>>  'geonode.catalogue',
>>>  'geonode.documents',
>>>  'geonode.api',
>>>  'geonode.groups',
>>>  'geonode.services',
>>>  'geonode.geoserver',
>>>  'geonode.upload',
>>>  'geonode.tasks')
>>> LANGUAGES_BIDI
>>> ('he', 'ar', 'fa', 'ur')
>>> USE_L10N
>>> False
>>> DATABASE_ENGINE
>>> STATIC_ROOT
>>> '/var/www/geonode/static/'
>>> STATICFILES_DIRS
>>> ['/etc/geonode/media', '/usr/local/lib/python2.7/dist-packages/geonode/static']
>>> DATABASE_NAME
>>> 'geonode'
>>> LEAFLET_CONFIG
>>> {'PLUGINS': {u'ALL': {u'css': [u'/static/leaflet/draw/leaflet.draw.css',
>>>                                '/static/lib/css/leaflet.fullscreen.css'],
>>>                       u'js': [u'/static/leaflet/draw/leaflet.draw.js',
>>>                               u'/static/leaflet/leaflet.extras.js',
>>>                               u'/static/leaflet/leaflet.forms.js',
>>>                               '/static/lib/js/Leaflet.fullscreen.min.js',
>>>                               '/static/lib/js/esri-leaflet.js']},
>>>              u'__default__': {u'css': ['/static/lib/css/leaflet.fullscreen.css'],
>>>                               u'js': ['/static/lib/js/Leaflet.fullscreen.min.js',
>>>              u'__is_normalized__': True,
>>>              'esri-leaflet': {'auto-include': True,
>>>                               u'css': [],
>>>                               'js': ['/static/lib/js/esri-leaflet.js']},
>>>              u'forms': {u'auto-include': False,
>>>                         u'css': [u'/static/leaflet/draw/leaflet.draw.css'],
>>>                                 u'/static/leaflet/leaflet.forms.js']},
>>>              'leaflet-fullscreen': {'auto-include': True,
>>>                                     'js': ['/static/lib/js/Leaflet.fullscreen.min.js']}},
>>>  'TILES': [('Watercolor',
>>>             'http://{s}.tile.stamen.com/watercolor/{z}/{x}/{y}.png <http://tile.stamen.com/watercolor/%7Bz%7D/%7Bx%7D/%7By%7D.png>',
>>>             'Map tiles by <a href="http://stamen.com">Stamen Design</a>,          <a href="http://creativecommons.org/licenses/by/3.0">CC BY 3.0</a> — Map data ©          <a href="http://openstreetmap.org">OpenStreetMap</a> contributors,          <a href="http://creativecommons.org/licenses/by-sa/2.0/">CC-BY-SA</a>'),
>>>            ('Toner Lite',
>>>             'http://{s}.tile.stamen.com/toner-lite/{z}/{x}/{y}.png <http://tile.stamen.com/toner-lite/%7Bz%7D/%7Bx%7D/%7By%7D.png>',
>>>             'Map tiles by <a href="http://stamen.com">Stamen Design</a>,          <a href="http://creativecommons.org/licenses/by/3.0">CC BY 3.0</a> — Map data ©          <a href="http://openstreetmap.org">OpenStreetMap</a> contributors,          <a href="http://creativecommons.org/licenses/by-sa/2.0/">CC-BY-SA</a>')]}
>>> DOWNLOAD_FORMATS_VECTOR
>>> ['JPEG',
>>>  'PDF',
>>>  'PNG',
>>>  'Zipped Shapefile',
>>>  'GML 2.0',
>>>  'GML 3.1.1',
>>>  'CSV',
>>>  'Excel',
>>>  'GeoJSON',
>>>  'KML',
>>>  'Tiles']
>>> PREPEND_WWW
>>> False
>>> SECURE_PROXY_SSL_HEADER
>>> None
>>> SOCIAL_ORIGINS
>>> [{'css_class': 'email',
>>>   'label': 'Email',
>>>   'url': 'mailto:?subject={name}&body={url}'},
>>>  {'css_class': 'fb',
>>>   'label': 'Facebook',
>>>   'url': 'http://www.facebook.com/sharer.php?u={url}'},
>>>  {'css_class': 'tw',
>>>   'label': 'Twitter',
>>>   'url': 'https://twitter.com/share?url={url}'},
>>>  {'css_class': 'gp',
>>>   'label': 'Google +',
>>>   'url': 'https://plus.google.com/share?url={url}'}]
>>> ACCOUNT_PASSWORD_RESET_REDIRECT_URL
>>> SESSION_COOKIE_HTTPONLY
>>> True
>>> DATABASE_PORT
>>> '5432'
>>> DEBUG_PROPAGATE_EXCEPTIONS
>>> False
>>> DEFAULT_ANONYMOUS_VIEW_PERMISSION
>>> True
>>> MEDIA_URL
>>> '/uploaded/'
>>> MONTH_DAY_FORMAT
>>> 'F j'
>>> ACCOUNT_EMAIL_CONFIRMATION_ANONYMOUS_REDIRECT_URL
>>> u'account_login'
>>> LOGIN_URL
>>> '/account/login/'
>>> SESSION_EXPIRE_AT_BROWSER_CLOSE
>>> False
>>> OGP_URL
>>> 'http://geodata.tufts.edu/solr/select'
>>> CELERY_EAGER_PROPAGATES_EXCEPTIONS
>>> True
>>> TIME_FORMAT
>>> 'P'
>>> CELERY_IGNORE_RESULT
>>> True
>>> SERVICE_UPDATE_INTERVAL
>>> 0
>>> AUTH_USER_MODEL
>>> 'people.Profile'
>>> DATE_INPUT_FORMATS
>>> ('%Y-%m-%d',
>>>  '%m/%d/%Y',
>>>  '%m/%d/%y',
>>>  '%b %d %Y',
>>>  '%b %d, %Y',
>>>  '%d %b %Y',
>>>  '%d %b, %Y',
>>>  '%B %d %Y',
>>>  '%B %d, %Y',
>>>  '%d %B %Y',
>>>  '%d %B, %Y')
>>> ACCOUNT_LOGOUT_REDIRECT_URL
>>> u'/'
>>> HAYSTACK_SEARCH
>>> False
>>> AUTHENTICATION_BACKENDS
>>> ('django.contrib.auth.backends.ModelBackend',
>>>  'guardian.backends.ObjectPermissionBackend')
>>> EMAIL_HOST_PASSWORD
>>> CELERY_DISABLE_RATE_LIMITS
>>> True
>>> PASSWORD_RESET_TIMEOUT_DAYS
>>> CACHE_MIDDLEWARE_ALIAS
>>> 'default'
>>> SESSION_SAVE_EVERY_REQUEST
>>> False
>>> NUMBER_GROUPING
>>> 0
>>> SHORT_DATETIME_FORMAT
>>> 'm/d/Y P'
>>> SESSION_ENGINE
>>> 'django.contrib.sessions.backends.db'
>>> CELERY_RESULT_BACKEND
>>> None
>>> ACCOUNT_DELETION_MARK_CALLBACK
>>> CSRF_COOKIE_PATH
>>> LOGIN_REDIRECT_URL
>>> '/accounts/profile/'
>>> SITEURL
>>> 'http://muchita.cnpm.embrapa.br/'
>>> PROJECT_ROOT
>>> '/usr/local/lib/python2.7/dist-packages/geonode'
>>> ACCOUNT_DELETION_EXPUNGE_HOURS
>>> 48
>>> GEONODE_ROOT
>>> DECIMAL_SEPARATOR
>>> CSRF_FAILURE_VIEW
>>> 'django.views.csrf.csrf_failure'
>>> CELERY_SEND_EVENTS
>>> False
>>> NOSE_ARGS
>>> ['--nocapture', '--detailed-errors']
>>> LOCALE_PATHS
>>> ('/usr/local/lib/python2.7/dist-packages/geonode/locale',)
>>> THEME_ACCOUNT_CONTACT_EMAIL
>>> 'admin at example.com'
>>> PASSWORD_HASHERS
>>> PROXY_ALLOWED_HOSTS
>>> MESSAGE_STORAGE
>>> 'django.contrib.messages.storage.fallback.FallbackStorage'
>>> USE_QUEUE
>>> False
>>> COMMENTS_ALLOW_PROFANITIES
>>> False
>>> LOGOUT_URL
>>> '/account/logout/'
>>> MAP_BASELAYERS
>>> [{'source': {'ptype': 'gxp_wmscsource',
>>>              'restUrl': '/gs/rest',
>>>              'url': 'http://muchita.cnpm.embrapa.br/geoserver/wms'}},
>>>  {'args': ['No background'],
>>>   'fixed': True,
>>>   'group': 'background',
>>>   'source': {'ptype': 'gxp_olsource'},
>>>   'type': 'OpenLayers.Layer',
>>>   'visibility': False},
>>>  {'args': ['OpenStreetMap'],
>>>   'fixed': True,
>>>   'type': 'OpenLayers.Layer.OSM',
>>>  {'group': 'background',
>>>   'name': 'osm',
>>>   'source': {'ptype': 'gxp_mapquestsource'},
>>>   'visibility': True},
>>>   'name': 'naip',
>>>  {'fixed': True,
>>>   'name': 'AerialWithLabels',
>>>   'source': {'ptype': 'gxp_bingsource'},
>>>  {'source': {'ptype': 'gxp_mapboxsource'}}]
>>> EMAIL_USE_TLS
>>> False
>>> ACCOUNT_LANGUAGES
>>> [('en', u'English'),
>>>  ('es', u'espa\xf1ol'),
>>>  ('it', u'italiano'),
>>>  ('fr', u'fran\xe7ais'),
>>>  ('de', u'Deutsch'),
>>>  ('el', u'\u0395\u03bb\u03bb\u03b7\u03bd\u03b9\u03ba\u03ac'),
>>>  ('id', u'Bahasa Indonesia'),
>>>  ('zh-cn', u'\u7b80\u4f53\u4e2d\u6587'),
>>>  ('ja', u'\u65e5\u672c\u8a9e'),
>>>  ('fa', u'\u0641\u0627\u0631\u0633\u06cc'),
>>>  ('ar', u'\u0627\u0644\u0639\u0631\u0628\u064a\u0651\u0629'),
>>>  ('bn', u'\u09ac\u09be\u0982\u09b2\u09be'),
>>>  ('ne', u'\u0928\u0947\u092a\u093e\u0932\u0940'),
>>>  ('sq', u'shqip'),
>>>  ('af', u'Afrikaans'),
>>>  ('sw', u'Kiswahili'),
>>>  ('pt', u'Portugu\xeas'),
>>>  ('pt-br', u'Portugu\xeas Brasileiro'),
>>>  ('ru', u'\u0420\u0443\u0441\u0441\u043a\u0438\u0439'),
>>>  ('vi', u'Ti\xea\u0301ng Vi\xea\u0323t'),
>>>  ('ko', u'\ud55c\uad6d\uc5b4'),
>>>  ('am', 'Amharic'),
>>>  ('km', u'Khmer'),
>>>  ('pl', u'polski'),
>>>  ('sv', u'svenska'),
>>>  ('th', u'\u0e20\u0e32\u0e29\u0e32\u0e44\u0e17\u0e22'),
>>>  ('uk', u'\u0423\u043a\u0440\u0430\u0457\u043d\u0441\u044c\u043a\u0430'),
>>>  ('si', 'sinhala'),
>>>  ('ta', u'tamil'),
>>>  ('tl', 'tagalog')]
>>> FIXTURE_DIRS
>>> ABSOLUTE_URL_OVERRIDES
>>> DATE_FORMAT
>>> 'N j, Y'
>>> OGC_SERVER
>>> {'default': {'BACKEND': 'geonode.geoserver',
>>>              'BACKEND_WRITE_ENABLED': True,
>>>              'DATASTORE': 'datastore',
>>>              'GEOGIG_DATASTORE_DIR': '',
>>>              'GEONODE_SECURITY_ENABLED': True,
>>>              'LOCATION': 'http://localhost:8080/geoserver/',
>>>              'LOG_FILE': '/usr/share/geoserver/data/logs/geoserver.log',
>>>              'MAPFISH_PRINT_ENABLED': True,
>>>              'PRINT_NG_ENABLED': True,
>>>              'PUBLIC_LOCATION': 'http://muchita.cnpm.embrapa.br/geoserver/',
>>>              'USER': 'admin',
>>>              'WMST_ENABLED': False,
>>>              'WPS_ENABLED': True}}
>>> SKIP_PERMS_FILTER
>>> False
>>> ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE
>>> MEDIA_ROOT
>>> '/var/www/geonode/uploaded'
>>> AGON_RATINGS_CATEGORY_CHOICES
>>> {'documents.Document': {'document': 'How good is this document?'},
>>>  'layers.Layer': {'layer': 'How good is this layer?'},
>>>  'maps.Map': {'map': 'How good is this map?'}}
>>> DATABASE_HOST
>>> DEFAULT_EXCEPTION_REPORTER_FILTER
>>> 'django.views.debug.SafeExceptionReporterFilter'
>>> ADMINS
>>> FORMAT_MODULE_PATH
>>> None
>>> DEFAULT_FROM_EMAIL
>>> GEONODE_APPS
>>> ('geonode.people',
>>>  'geonode.base',
>>>  'geonode.layers',
>>>  'geonode.maps',
>>>  'geonode.proxy',
>>>  'geonode.security',
>>>  'geonode.social',
>>>  'geonode.api',
>>>  'geonode.groups',
>>>  'geonode.services',
>>>  'geonode.upload',
>>>  'geonode.tasks')
>>> GEOSERVER_URL
>>> DATETIME_FORMAT
>>> 'N j, Y, P'
>>> TEMPLATE_DIRS
>>> ('/etc/geonode/templates',
>>>  '/usr/local/lib/python2.7/dist-packages/geonode/templates')
>>> ALLOWED_DOCUMENT_TYPES
>>> ['doc',
>>>  'docx',
>>>  'gif',
>>>  'jpg',
>>>  'jpeg',
>>>  'ods',
>>>  'odt',
>>>  'odp',
>>>  'pdf',
>>>  'png',
>>>  'ppt',
>>>  'pptx',
>>>  'rar',
>>>  'tif',
>>>  'tiff',
>>>  'txt',
>>>  'xls',
>>>  'xlsx',
>>>  'xml',
>>>  'zip',
>>>  'gz']
>>> NOTIFICATION_LANGUAGE_MODULE
>>> 'account.Account'
>>> ACCOUNT_DELETION_EXPUNGE_CALLBACK
>>> RESOURCE_PUBLISHING
>>> False
>>> ACCOUNT_HOOKSET
>>> <account.hooks.AccountDefaultHookSet object at 0x7fe06f67d210>
>>> PROXY_URL
>>> '/proxy/?url='
>>> SITE_ID
>>> 1
>>> DISALLOWED_USER_AGENTS
>>> ALLOWED_INCLUDE_ROOTS
>>> API_LIMIT_PER_PAGE
>>> ACCOUNT_SETTINGS_REDIRECT_URL
>>> u'account_settings'
>>> EXTRA_LANG_INFO
>>> {'am': {'bidi': False,
>>>         'code': 'am',
>>>         'name': 'Amharic',
>>>         'name_local': 'Amharic'},
>>>  'si': {'bidi': False,
>>>         'code': 'si',
>>>         'name': 'Sinhala',
>>>         'name_local': 'sinhala'},
>>>  'ta': {'bidi': False, 'code': 'ta', 'name': 'Tamil', 'name_local': u'tamil'},
>>>  'tl': {'bidi': False,
>>>         'code': 'tl',
>>>         'name': 'Tagalog',
>>>         'name_local': 'tagalog'}}
>>> LOGGING
>>> {'disable_existing_loggers': True,
>>>  'filters': {'require_debug_false': {'()': 'django.utils.log.RequireDebugFalse'}},
>>>  'formatters': {'simple': {'format': '%(message)s'},
>>>                 'verbose': {'format': '%(levelname)s %(asctime)s %(module)s %(process)d %(thread)d %(message)s'}},
>>>  'handlers': {'console': {'class': 'logging.StreamHandler',
>>>                           'formatter': 'simple',
>>>                           'level': 'ERROR'},
>>>               'mail_admins': {'class': 'django.utils.log.AdminEmailHandler',
>>>                               'filters': ['require_debug_false'],
>>>                               'level': 'ERROR'},
>>>               'null': {'class': 'django.utils.log.NullHandler',
>>>                        'level': 'ERROR'}},
>>>  'loggers': {'django': {'handlers': ['console'], 'level': 'ERROR'},
>>>              'geonode': {'handlers': ['console'], 'level': 'ERROR'},
>>>              'gsconfig.catalog': {'handlers': ['console'], 'level': 'ERROR'},
>>>              'owslib': {'handlers': ['console'], 'level': 'ERROR'},
>>>              'pycsw': {'handlers': ['console'], 'level': 'ERROR'}},
>>>  'version': 1}
>>> SHORT_DATE_FORMAT
>>> 'm/d/Y'
>>> DATABASE_USER
>>> 'geonode'
>>> TEST_RUNNER
>>> 'django_nose.NoseTestSuiteRunner'
>>> ACTSTREAM_SETTINGS
>>> {'FETCH_RELATIONS': True,
>>>  'GFK_FETCH_DEPTH': 1,
>>>  'MODELS': ('people.Profile',
>>>             'layers.layer',
>>>             'maps.map',
>>>             'dialogos.comment',
>>>             'documents.document',
>>>             'services.service'),
>>>  'USE_JSONFIELD': True,
>>>  'USE_PREFETCH': False}
>>> MODELTRANSLATION_LANGUAGES
>>> ['en']
>>> HAYSTACK_FACET_COUNTS
>>> False
>>> CACHE_MIDDLEWARE_KEY_PREFIX
>>> DEFAULT_WORKSPACE
>>> 'geonode'
>>> TIME_ZONE
>>> 'America/Chicago'
>>> FILE_UPLOAD_MAX_MEMORY_SIZE
>>> 2621440
>>> LOCAL_GEOSERVER
>>> EMAIL_BACKEND
>>> 'django.core.mail.backends.smtp.EmailBackend'
>>> ANONYMOUS_USER_ID
>>> -1
>>> POSTGIS_VERSION
>>> (2, 1, 0)
>>> DEFAULT_MAP_ZOOM
>>> 0
>>> TEMPLATE_CONTEXT_PROCESSORS
>>> ('django.contrib.auth.context_processors.auth',
>>>  'django.core.context_processors.debug',
>>>  'django.core.context_processors.i18n',
>>>  'django.core.context_processors.tz',
>>>  'django.core.context_processors.media',
>>>  'django.core.context_processors.static',
>>>  'django.core.context_processors.request',
>>>  'django.contrib.messages.context_processors.messages',
>>>  'account.context_processors.account',
>>>  'geonode.context_processors.resource_urls',
>>>  'geonode.geoserver.context_processors.geoserver_urls')
>>> CELERY_QUEUES
>>> [<unbound Queue 'default' -> <unbound Exchange ''(direct)> -> default>,
>>>  <unbound Queue 'cleanup' -> <unbound Exchange ''(direct)> -> cleanup>,
>>>  <unbound Queue 'update' -> <unbound Exchange ''(direct)> -> update>,
>>>  <unbound Queue 'email' -> <unbound Exchange ''(direct)> -> email>]
>>> LOCKDOWN_GEONODE
>>> False
>>> SESSION_COOKIE_AGE
>>> 1209600
>>> SETTINGS_MODULE
>>> 'geonode.settings'
>>> GUARDIAN_GET_INIT_ANONYMOUS_USER
>>> 'geonode.people.models.get_anonymous_user_instance'
>>> USE_ETAGS
>>> False
>>> SOCIAL_BUTTONS
>>> True
>>> LANGUAGES
>>> (('en', 'English'),
>>>  ('es', 'Espa\xc3\xb1ol'),
>>>  ('it', 'Italiano'),
>>>  ('fr', 'Fran\xc3\xa7ais'),
>>>  ('de', 'Deutsch'),
>>>  ('el', '\xce\x95\xce\xbb\xce\xbb\xce\xb7\xce\xbd\xce\xb9\xce\xba\xce\xac'),
>>>  ('id', 'Bahasa Indonesia'),
>>>  ('zh-cn', '\xe4\xb8\xad\xe6\x96\x87'),
>>>  ('ja', '\xe6\x97\xa5\xe6\x9c\xac\xe8\xaa\x9e'),
>>>  ('fa', 'Persian'),
>>>  ('ar', 'Arabic'),
>>>  ('bn', 'Bengali'),
>>>  ('ne', 'Nepali'),
>>>  ('sq', 'Albanian'),
>>>  ('af', 'Afrikaans'),
>>>  ('sw', 'Swahili'),
>>>  ('pt', 'Portuguese'),
>>>  ('pt-br', 'Portugu\xc3\xaas Brasil'),
>>>  ('ru', 'Russian'),
>>>  ('vi', 'Vietnamese'),
>>>  ('ko', '\xed\x95\x9c\xea\xb5\xad\xec\x96\xb4'),
>>>  ('am', 'Amharic'),
>>>  ('km', 'Khmer'),
>>>  ('pl', 'Polish'),
>>>  ('sv', 'Swedish'),
>>>  ('th', 'Thai'),
>>>  ('uk', 'Ukranian'),
>>>  ('si', 'Sinhala'),
>>>  ('ta', 'Tamil'),
>>>  ('tl', 'Tagalog'))
>>> CELERY_TASK_RESULT_EXPIRES
>>> 1
>>> DEFAULT_INDEX_TABLESPACE
>>> INTERNAL_IPS
>>> STATIC_URL
>>> '/static/'
>>> EMAIL_PORT
>>> 25
>>> LAYER_PREVIEW_LIBRARY
>>> 'geoext'
>>> USE_TZ
>>> False
>>> DEFAULT_SEARCH_SIZE
>>> 10
>>> CLIENT_RESULTS_LIMIT
>>> 100
>>> MODELTRANSLATION_DEFAULT_LANGUAGE
>>> 'en'
>>> ACCOUNT_SIGNUP_REDIRECT_URL
>>> u'/'
>>> DOCUMENT_TYPE_MAP
>>> {'doc': 'text',
>>>  'docx': 'text',
>>>  'gif': 'image',
>>>  'gz': 'archive',
>>>  'jpeg': 'image',
>>>  'jpg': 'image',
>>>  'log': 'text',
>>>  'odp': 'presentation',
>>>  'ods': 'text',
>>>  'odt': 'text',
>>>  'pdf': 'presentation',
>>>  'png': 'image',
>>>  'ppt': 'presentation',
>>>  'pptx': 'presentation',
>>>  'rar': 'archive',
>>>  'tif': 'image',
>>>  'tiff': 'image',
>>>  'txt': 'text',
>>>  'xls': 'text',
>>>  'xlsx': 'text',
>>>  'xml': 'text',
>>>  'zip': 'archive'}
>>> CACHE_MIDDLEWARE_SECONDS
>>> 600
>>> SITENAME
>>> 'GeoNode'
>>> ACCOUNT_CREATE_ON_SAVE
>>> True
>>> CSRF_COOKIE_HTTPONLY
>>> False
>>> DATETIME_INPUT_FORMATS
>>> ('%Y-%m-%d %H:%M:%S',
>>>  '%Y-%m-%d %H:%M:%S.%f',
>>>  '%Y-%m-%d %H:%M',
>>>  '%Y-%m-%d',
>>>  '%m/%d/%Y %H:%M:%S',
>>>  '%m/%d/%Y %H:%M:%S.%f',
>>>  '%m/%d/%Y %H:%M',
>>>  '%m/%d/%Y',
>>>  '%m/%d/%y %H:%M:%S',
>>>  '%m/%d/%y %H:%M:%S.%f',
>>>  '%m/%d/%y %H:%M',
>>>  '%m/%d/%y')
>>> ACCOUNT_EMAIL_CONFIRMATION_REQUIRED
>>> False
>>> DATABASE_PASSWORD
>>> PROFANITIES_LIST
>>> EMAIL_HOST_USER
>>> MAX_DOCUMENT_SIZE
>>> 2
>>> You're seeing this error because you have DEBUG = True in your Django
>>> settings file. Change that to False, and Django will display a standard
>>> 500 page.
>>> Davi de O. Custódio
>> Davi de O. Custódio
> Davi de O. Custódio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150527/e1bada8f/attachment-0001.html>
More information about the geonode-users mailing list
