[GeoNode-users] Error al instalar Geonode en ubuntu 14.04 // Error installing GeoNode on ubuntu 14.04
Simone Dalmasso simone.dalmasso at gmail.com
Wed May 27 23:06:39 PDT 2015
Hi Leopoldo,
could you be behind a proxy? Take a look at this thread
http://askubuntu.com/questions/452595/cannot-add-ppa-behind-proxy-ubuntu-14-04
Also, on ubuntu 14.04 the ppa:geonode/release is not available yet until we
finalize the version 2.4 so go for ppa:geonode/testing.
Regards
2015-05-27 18:27 GMT+02:00 LEOPOLDO JAVIER NUNEZ DE SANTIAGO . <
lnunezde at guanajuato.gob.mx>:
> Saludos, estoy por realizar una nueva instalación para Geonode en un
> servidor con Ubuntu 14.04, para finalmente poner el servicio de mapas en
> línea.
> Trate de instalar desde:
> sudo add-apt-repository ppa:geonode/release
> sudo apt-get update
> sudo apt-get install geonode
> Recibi el siguiente error:
> Cannot add PPA: 'ppa:geonode/release'.
> Please check that the PPA name or format is correct.
> Investigando encontre que puedo instalarlo desde esta linea de commandos:
> sudo add-apt-repository ppa:geonode/testing
> Me mando el mismo error, como puedo instalar Geonode en 14.04
> Cannot add PPA: 'ppa:geonode/testing'.
> Gracias
> Greetings, I am about to perform a new installation for GeoNode on a
> server with Ubuntu 14.04, finally put the service online maps.
> Try installing from:
> sudo apt-get update
> I received the following error:
> Investigating I found that I can install it from this line of commandos:
> I received the same error.
> As I can install Geonode en  Ubuntu 14.04
> Gracias
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150528/89fb234a/attachment.html>
More information about the geonode-users mailing list
