[GeoNode-users] Using GeoNode users to connect to Geoserver by Opengeo Suite QGIS Plugin
Francesco Bartoli xbartolone at gmail.com
Thu May 28 06:54:33 PDT 2015
Hi Davi,
unfortunately that plugin interacts directly with the users repository within geoserver. At the moment the only scenario I would expect this working is to have a centralized user repository for both GeoNode and GeoServer, for instance a LDAP directory server. But I don’t know if GeoNode supports it, django does though.
Francesco
Il giorno 28/mag/2015, alle ore 15:29, Davi Custodio <davicustodio at gmail.com> ha scritto:
> I would like to allow users GeoNode could interact and change styles of the layers using the plugin Opengeo Suite Explorer for QGIS.
> I can make the plugin to connect to the Geoserver GeoNode using the admin user (the geoserver), but using a common user GeoNode, you can not.
> Is there any solution for this, perhaps changing the stored procedure "geonode_authorize_layer"?
> Thank you.
> Davi de O. Custódio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
