[GeoNode-users] Cant upload and register remote services after update
Christian Willmes c.willmes at uni-koeln.de
Mon Nov 2 01:15:44 PST 2015
I now tryed with Chrome, and upload works fine. Thanks! But adding a
remote WMS does not work... I write another mail regarding this, because
its a different problem.
Regards,
Christian
Am 30.10.2015 um 16:58 schrieb Simone Dalmasso:
> On demo.geonode.org <http://demo.geonode.org> I don't see issues on
> upload. Christian, this time there hasn't been any data model change
> so it's only a template + javascript + python code. An upgrade and
> apache restart should be sufficient....not sure what's wrong there.
> 2015-10-30 16:48 GMT+01:00 Charles Cossé <ccosse at gmail.com
> <mailto:ccosse at gmail.com>>:
>     This commit looks like an attempt to clean-up but doesn't work b/c
>     category form not being transmitted as needed:
>     0c3c1395dffb879d4dab10c77610008778d13bd7
>     <https://github.com/GeoNode/geonode/commit/0c3c1395dffb879d4dab10c77610008778d13bd7#diff-36bc05580e37aef61b66c480db47cc38>
>     On Fri, Oct 30, 2015 at 11:36 AM, Charles Cossé <ccosse at gmail.com
>     <mailto:ccosse at gmail.com>> wrote:
>         Hi, I may be somewhat implicated in this.  This is what I have
>         in my layers/views.py around the Line#154 in your error
>         message.  It is different than what's in git at the moment,
>         and I'm not sure why.   The below is a hack, for sure, which
>         was awaiting more insight into getting the category_form
>         returned from layers_upload.html ... nonetheless, if you
>         replace the topic_id retrieval section in your views.py I
>         suspect it will work. Meanwhile the views.py on github appears
>         that it cannot work as-is ... will look into it more later.
>         (what might have happened was a revert b/c multiple categories
>         not handled, but reverted to previous broken version, ie. not
>         far enough back).
>                     try:
>                         # Moved this inside the try/except block
>         because it can raise
>                         # exceptions when unicode characters are present.
>                         # This should be followed up in upstream Django.
>                         tempdir, base_file = form.write_files()
>                         logging.debug(request)
>                         topic_id = request.META.get("HTTP_COOKIE")
>                         topic_id = string.split(topic_id, " ")[0]
>                         topic_id = string.split(topic_id, ":")[1]
>                         topic_id = string.split(topic_id, ";")[0]
>                         logging.debug(topic_id)
>                         topic_category = TopicCategory.objects.get(
>                             id=topic_id
>                         saved_layer = file_upload(
>                             base_file,
>                             name=name,
>                             user=request.user,
>                             overwrite=False,
>         charset=form.cleaned_data["charset"],
>         abstract=form.cleaned_data["abstract"],
>         title=form.cleaned_data["layer_title"],
>         Layer.objects.filter(name=name).update(
>                             category=topic_category
>                     except Exception as e:
>                         exception_type, error, tb = sys.exc_info()
>         On Fri, Oct 30, 2015 at 10:59 AM, Christian Willmes
>         <christian.willmes at googlemail.com
>         <mailto:christian.willmes at googlemail.com>> wrote:
>             just to clarify, I tried the upload and register of remote
>             service again after running "geonode collectstatic".
>             I also made sure to select a category from the GUI, but
>             for testing also tryed to upload without selecting a
>             category, both resulting in the exact same errors in the logs.
>             Any Ideas?
>             Thanks,
>             Christian
>             Am 30.10.2015 um 15:02 schrieb Christian Willmes:
>                 Hi,
>                 thanks, but it did not help. I did:
>                 ~$ geonode collectstatic
>                 You have requested to collect static files at the
>                 destination
>                 location as specified in your settings.
>                 This will overwrite existing files!
>                 Are you sure you want to do this?
>                 Type 'yes' to continue, or 'no' to cancel: yes
>                 0 static files copied, 880 unmodified.
>                 Errors in logs look exactly same, as posted in the
>                 mail before.
>                 Regards,
>                 Christian
>                 Am 30.10.2015 um 14:57 schrieb Simone Dalmasso:
>                     Christian. A geonode collectstatic may fix. Let us
>                     know
>                     Il venerdì 30 ottobre 2015, Christian Willmes
>                     <mailto:christian.willmes at googlemail.com>>> ha
>                     scritto:
>                         Hi,
>                         I run a GeoNode /version 2.4c2 /from the
>                     ubuntu packages./
>                         /After an "apt-get update / upgrade"
>                     yesterday, I can't upload new
>                         layers or register remote services on GeoNode
>                     anymore.
>                         /On registering remote services the logs say:
>                         [Fri Oct 30 13:24:41.857736 2015] [core:error]
>                     [pid 24951:tid
>                         140094098888448] [client 134.95.126.26:38719
>                     <http://134.95.126.26:38719>
>                         <http://134.95.126.26:38719>] End of script
>                     output before headers:
>                         geonode.wsgi
>                         [Fri Oct 30 13:24:41.857932 2015] [core:error]
>                     [pid 25013:tid
>                         140094014961408] [client 134.95.126.26:38714
>                     <http://134.95.126.26:38714>
>                         <http://134.95.126.26:38714>] End of script
>                         geonode.wsgi
>                         [Fri Oct 30 13:24:41.858108 2015] [core:error]
>                     [pid 24951:tid
>                         140094090495744] [client 127.0.0.1:36688
>                     <http://127.0.0.1:36688> <http://127.0.0.1:36688>]
>                         End of script output before headers: geonode.wsgi
>                         [Fri Oct 30 13:24:41.858290 2015] [core:error]
>                     [pid 24951:tid
>                         140094073710336] [client 134.95.126.26:38467
>                     <http://134.95.126.26:38467>
>                         <http://134.95.126.26:38467>] End of script
>                         geonode.wsgi
>                         [Fri Oct 30 13:24:41.858455 2015] [core:error]
>                     [pid 24951:tid
>                         140094006568704] [client 134.95.126.26:38447
>                     <http://134.95.126.26:38447>
>                         <http://134.95.126.26:38447>] End of script
>                         geonode.wsgi
>                         [Fri Oct 30 13:24:41.858625 2015] [core:error]
>                     [pid 25013:tid
>                         140094115673856] [client 134.95.126.26:38399
>                     <http://134.95.126.26:38399>
>                         <http://134.95.126.26:38399>] End of script
>                         geonode.wsgi
>                         [Fri Oct 30 13:24:41.858788 2015] [core:error]
>                     [pid 25013:tid
>                         140093914248960] [client 134.95.126.26:38411
>                     <http://134.95.126.26:38411>
>                         <http://134.95.126.26:38411>] End of script
>                         geonode.wsgi
>                         [Fri Oct 30 13:24:41.858963 2015] [core:error]
>                     [pid 25013:tid
>                         140093939427072] [client 134.95.126.26:38433
>                     <http://134.95.126.26:38433>
>                         <http://134.95.126.26:38433>] End of script
>                         geonode.wsgi
>                         [Fri Oct 30 13:24:41.859267 2015] [core:error]
>                     [pid 25013:tid
>                         140093964605184] [client 134.95.126.26:38350
>                     <http://134.95.126.26:38350>
>                         <http://134.95.126.26:38350>] End of script
>                         geonode.wsgi
>                         [Fri Oct 30 13:24:41.859403 2015] [core:error]
>                     [pid 24951:tid
>                         140093922641664] [client 134.95.150.136:37065
>                     <http://134.95.150.136:37065>
>                         <http://134.95.150.136:37065>] End of script
>                     output before
>                         headers: geonode.wsgi, referer:
>                     http://geonode.crc806db.uni-koeln.de/services/register/
>                         On upload via the web gui, the logs say:
>                         [Fri Oct 30 07:50:58.506998 2015] [:error]
>                     [pid 1277:tid
>                         139701666780928] "'category'"
>                         [Fri Oct 30 07:50:58.507085 2015] [:error]
>                     [pid 1277:tid
>                         139701666780928] Traceback (most recent call
>                     last):
>                         [Fri Oct 30 07:50:58.507097 2015] [:error]
>                     [pid 1277:tid
>                         139701666780928]   File
>                     "/usr/local/lib/python2.7/dist-packages/geonode/layers/views.py",
>                         line 154, in layer_upload
>                         [Fri Oct 30 07:50:58.507106 2015] [:error]
>                     [pid 1277:tid
>                         139701666780928]     topic_id =
>                     request.POST['category']
>                         [Fri Oct 30 07:50:58.507115 2015] [:error]
>                     [pid 1277:tid
>                     "/usr/lib/python2.7/dist-packages/django/utils/datastructures.py",
>                         line 301, in __getitem__
>                         [Fri Oct 30 07:50:58.507126 2015] [:error]
>                     [pid 1277:tid
>                         139701666780928]     raise
>                     MultiValueDictKeyError(repr(key))
>                         [Fri Oct 30 07:50:58.507139 2015] [:error]
>                     [pid 1277:tid
>                         139701666780928] MultiValueDictKeyError:
>                     "'category'"
>                         Is there any step I need to do manually after
>                     an package upgrade?
>                         I remember similar problems after the last
>                     update, then it was a
>                         problem with "uploadsession" not "category"
>                     during upload layers.
>                         Thanks and regards,
>                         Christian
>                     _______________________________________________
>                         geonode-users mailing list
>                     geonode-users at lists.osgeo.org
>                     <mailto:geonode-users at lists.osgeo.org>
>                     http://lists.osgeo.org/mailman/listinfo/geonode-users
>                     Simone
>     geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
> Simone
Christian Willmes
AG GIS & Fernerkundung      | GIS & RS Group
Geographisches Institut     | Institute of Geography
Universität zu Köln         | University of Cologne
Tel.: +49 (0)221 470 6234
http://www.geographie.uni-koeln.de/willmes-christian.695.en.html
http://www.sfb806.de
http://crc806db.uni-koeln.de
More information about the geonode-users mailing list
