[GeoNode-users] Remote Service (WMS) from MapProxy instance
Christian Willmes c.willmes at uni-koeln.de
Wed Nov 4 07:35:19 PST 2015
Hmm, it seems it is not the firewall...
On adding a service the metadata is read in correctly and according
layers are created in geonode, but the data is never loaded on the
layers map view...
Any advice on how I could debug this? I don't get anything that helps in
/var/log/apache2/error.log
On an internal test VM these (external and internal) services work as
remote services in geonode, but not on the live server instance. Both
are installed from the ubuntu packages.
Thanks and regards,
Christian
Am 04.11.2015 um 10:48 schrieb Christian Willmes:
> Indeed! Thanks! I see it on demo.geonode.org. This helps a lot, so its
> maybe something with the firewall...
> Am 04.11.2015 um 10:45 schrieb Simone Dalmasso:
>> Hi Christian, I could import the service both locally and on demo.
>> One layer is available.
>> 2015-11-04 10:31 GMT+01:00 Christian Willmes <c.willmes at uni-koeln.de
>> <mailto:c.willmes at uni-koeln.de>>:
>>     Hi,
>>     does anyone have an idea, why adding this particular WMS [1] to
>>     geonode as a remote service does not work?
>>     The metadata seems to be read correctly, but the service is never
>>     loaded in geonode. I don't see any warnings or errors in the logs.
>>     Can you maybe test to import this WMS on demo.geonode.org
>>     <http://demo.geonode.org>?
>>     As said, the WMS works on its own demo OpenLayers app [2], and
>>     also works fine in QGIS and ArcGIS.
>>     Thanks and regards,
>>     Christian
>>     [1]
>> http://geonode.crc806db.uni-koeln.de:8081/IQuaME2500/service?REQUEST=GetCapabilities
>>     [2] http://geonode.crc806db.uni-koeln.de:8081/IQuaME2500/demo/
>>     Am 02.11.2015 um 10:23 schrieb Christian Willmes:
>>         Hi,
>>         I have a problem of adding a remote WMS served by MapProxy
>>         1.8.1. The WMS works like a charm in QGIS or ArcGIS, but
>>         importing into GeoNode is a problem.
>>         This is the WMS:
>>         (It actually runs on the same server as the GeoNode instance.
>>         Only Port 8081 is open outside of our subnet.)
>>         I can add the Service to GeoNode, the Metadata is read in
>>         correctly, but the service data is not shown in GeoNode, also
>>         no thumbnail is created.
>>         I see similar problems on demo.geonode.org
>>         <http://demo.geonode.org> regarding remote services. Is this a
>>         general problem?
>>         Regards,
>>         Christian
>>     --     Christian Willmes
>>     AG GIS & Fernerkundung      | GIS & RS Group
>>     Geographisches Institut     | Institute of Geography
>>     Universität zu Köln         | University of Cologne
>>     Tel.: +49 (0)221 470 6234 <tel:%2B49%20%280%29221%20470%206234>
>> http://www.geographie.uni-koeln.de/willmes-christian.695.en.html
>>     http://www.sfb806.de
>>     http://crc806db.uni-koeln.de
>>     _______________________________________________
>>     geonode-users mailing list
>>     geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
Christian Willmes
More information about the geonode-users mailing list
