[GeoNode-users] Add Custom Metadata Fields
Jonáš Veselka jonas.veselka at gisat.cz
Thu Nov 5 08:14:54 PST 2015
Tom,
do You mean to add that fields by ourself in our instance of Geonode or we
could do that with Your help to be in next release?
Jonáš
2015-11-05 3:45 GMT+01:00 Tom Kralidis <tomkralidis at gmail.com>:
> Hi Jonáš: most of the INSPIRE required fields are supported by
> GeoNode. A quick scan indicates that, of the outstanding fields, some
> we can add easily in the code base, and some require deeper discussion
> (INSPIRE codelist values, GEMET keywords).
> I'm not aware of any options for custom fields/profiles for GeoNode
> resource models, though other devs/users may have suggestions.  This
> is also a great opportunity to use INSPIRE as an example to implement
> a generic approach to this feature.
> ..Tom
> On Wed, Nov 4, 2015 at 12:04 PM, Jonáš Veselka <jonas.veselka at gisat.cz>
> wrote:
> > Hi,
> > we are preparing the GeoNode for a project, where we need metadata
> fields to
> > be INSPIRE compliant.
> > Specifically we need these fields:
> > Resource title
> > Resource abstract
> > Resource type
> > Resource locator
> > Spatial data service type
> > Keyword value
> > Originating controlled vocabulary
> > Geographic bounding box
> > Temporal extent
> > Date of creation
> > Specification
> > Degree
> > Conditions applying to access and use
> > Responsible party
> > Responsible party role
> > Metadata point of contact
> > Metadata date
> > Metadata language
> > Based on this documentation
> http://docs.geonode.org/en/master/reference/developers/settings.html#pycsw
> > we found that metadata:inspire['enabled'] is already set to true in our
> > Geonode, but fields are different to INSPIRE standard:
> https://www.dropbox.com/s/znn4fvxvka0j5bm/geonode-metadata-fields.png?dl=0
> > Is there any option to manage available metadata fields?
> > Regards,
> > Jonáš
> > geonode-users mailing list
> > geonode-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151105/d1f8d102/attachment.html>
More information about the geonode-users mailing list
