[GeoNode-users] Add values to "Add Layers ComboBox"
David Alda Fernandez de Lezea dalda at hazi.eus
Thu Nov 5 22:46:43 PST 2015
Hi Ariel,
I managed to add some remote servers by editing the settings file.
Thanks.
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda at hazi.eus | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
*********************  LEGE OHARRA   *******************   AVISOLEGAL   *******************   DISCLAIMER   *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
De: Ariel Nunez [mailto:ingenieroariel at gmail.com]
Enviado el: martes, 03 de noviembre de 2015 12:44
Para: David Alda Fernandez de Lezea
CC: geonode-users at lists.osgeo.org
Asunto: RE: [GeoNode-users] Add values to "Add Layers ComboBox"
If it is an entire OWS, you could try replicating the entry for your local geoserver but using the remote ip.
If you installed via packages, just open /etc/geonode/local_settings.py and start from there looking at MAP_BASELAYERS.
On Nov 3, 2015 3:20 AM, "David Alda Fernandez de Lezea" <dalda at hazi.eus> wrote:
Hi Ariel,
Thanks for your response. I want to add some other organization's ows to the combobox so I suppose I'll have to go to GeoExplorer customization. Can you point me to the right file? I'm really confused about all the directories and javascript files.
Thanks in advance.
Agur bero bat,
Enviado el: lunes, 02 de noviembre de 2015 14:26
Asunto: Re: [GeoNode-users] Add values to "Add Layers ComboBox"
This will point you in the right direction:
http://docs.geonode.org/en/master/tutorials/admin/production.html#adding-layers-from-google-bing-and-other-providers
For other sources you may have to read about GeoExt sources to be able to customize that file.
-a
2015-11-02 8:15 GMT-05:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
Hi list,
How can I add some other url's to the combo in the map composer-> add Layers panel?
There appear "My GeoServer WMS", "MapQuest Layers", "Google Layers"...
Thanks in advance,
Agur bero bat,
T 945 003 240 - M 627 923 170 - F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
