[GeoNode-users] GeoNode's default SRS
David Alda Fernandez de Lezea dalda at hazi.eus
Fri Nov 6 05:34:02 PST 2015
I Simone,
Thanks for your response. I've looked into what is being sent and the parameters are OK:
SRS: ESPG4326
BBOX=-3.457379,42.46302,-2.754254,43.166145
I think the problem is that the Base Layers (Goolge Maps and other layers I added) don't support the EPSG:4326 SRS.
Anyway, I'll try to find another approach.
Thanks.
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda at hazi.eus | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
*********************  LEGE OHARRA   *******************   AVISOLEGAL   *******************   DISCLAIMER   *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Enviado el: viernes, 06 de noviembre de 2015 8:04
Para: David Alda Fernandez de Lezea
CC: geonode-users at lists.osgeo.org
Asunto: Re: [GeoNode-users] GeoNode's default SRS
Hi Davi,
to investigate further take a look at the http request through the dev tools. To make sure it0s still using the 4326
2015-11-06 7:52 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
I'm trying to set GeoNode's default SRS to EPSG:4326. So far I've edited the files views.py under maps and layers folders and everything seemed to work but when I add some layers of another OWS of our organization it places them at other coordinates. Furthermore, the coordinates shown in the mouse position control aren't correct.
Any ideas what could be happening? Perhaps there's another way to achieve this.
Thanks in advance.
Regards,
Agur bero bat,
T 945 003 240 - M 627 923 170 - F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
More information about the geonode-users mailing list
