[GeoNode-users] geonode updatelayers exception "non-XML	response"
    Christian Willmes
    christian.willmes at googlemail.com
    Sun Nov  8 23:49:49 PST 2015
any advice on this? How can I fix it and preserve my data, and most
important the URLs?
I considered reinstalling Geonode, by preserving the GeoServer, but I
figured, that this may break the URLs, which would be bad, because other
applications link to the Geonode resources.
Regards,
Christian
Am 05.11.2015 um 16:58 schrieb Christian Willmes:
> Hi,
> I can't run the "geonode updatelayers" command anymore, because it
> always aborts with an error like:
> >>Exception: ('GeoServer gave non-XML response for [GET
> http://localhost:8080/geoserver/rest/workspaces/geonode/datastores/datastore/featuretypes/lgm_landmask_hires.xml]:
> <featureType>\n <name>lgm_landmask_hires</name>\n
> <nativeName>lgm_landmask_hires</nativeName>\n <namespace>\n
> <name>geonode</name>\n   [...]
> I cant fix the schema in geoserver by reloading the feature type in
> the Layer edit view, but it does not work. It throws really long java
> stack trace in the "publication" tab, one line says:
> >>Caused by: java.io.IOException: Schema 'lgm_landmask_hires' does not
> exist.
> I also completely deleted another layer, that throwed this same error
> before. But its not really an option to delete all layers to be able
> to run the command again.
> I also tried with the --ignore-errors option, but got the same error /
> abort.
> How can I fix or circumvent this problem?
> Thanks and regards,
> Christian
More information about the geonode-users
