[GeoNode-users] Cannot access GeoNode 2.4 RC1 after istalling and updating IP (500 internal server error)
Simone Dalmasso simone.dalmasso at gmail.com
Mon Nov 9 02:26:34 PST 2015
The geoserver logs may give you more information about this. You an read
them through the geoserver interface.
2015-11-09 11:03 GMT+01:00 Shah Md. Rajibul Islam <rajibul.islam at cdmp.org.bd
> Thank a lot. I can now access geonode using browser, but it gives error “An
> exception occurred loading data to PostGIS- java.io.IOException: Error
> occurred creating table” while uploading shapefiles.
> Regards
> *Shah Md. Rajibul Islam*
> *GIS Analyst*
> CDMP – II, UNDP
> Disaster Management & Relief Bhaban
> 92-93, Mohakhali C/A, Dhaka - 1212
> Tel # 989 0937; 882 1255; 882 1459, Ext - 303
> Mobile: +88 01716 027389, E-mail: rajibul.islam at cdmp.org.bd
> Web: www.cdmp.org.bd
> *From:* Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> *Sent:* 09 November 2015 15:06
> *To:* Shah Md. Rajibul Islam
> *Cc:* geonode-users at lists.osgeo.org
> *Subject:* Re: [GeoNode-users] Cannot access GeoNode 2.4 RC1 after
> There's no operations.py file in GeoNode, it is a django file and should
> not be modified.
> you can add it to /etc/geonode/local_settings.py then restart your server
> regards
> 2015-11-09 9:47 GMT+01:00 Shah Md. Rajibul Islam <
> rajibul.islam at cdmp.org.bd>:
> Do you mean to add it into operations.py or where? I am using putty to
> connect to the server, if possible could you please check my geonode using
> team viewer?
> *GIS Analyst*
> CDMP – II, UNDP
> *Sent:* 09 November 2015 13:53
> ok, you can add
> *POSTGIS_VERSION = (2,1,0)*
> to your geonode settings.
> Regards
> 2015-11-09 8:49 GMT+01:00 Shah Md. Rajibul Islam <
> Dear Ciao,
> Thank you for your reply. I found the followings-
> geonode at geonode:~$ tail -f /etc/apache2/logs/error.log
> tail: cannot open ‘/etc/apache2/logs/error.log’ for reading: No such file
> or directory
> geonode at geonode:~$ tail -f /var/log/apache2/error.log
> [Mon Nov 09 00:48:14.620992 2015] [:error] [pid 2175] [remote
> 192.168.0.42:27831]     conn = backend.DatabaseWrapper(db, alias)
> [Mon Nov 09 00:48:14.621022 2015] [:error] [pid 2175] [remote
> 192.168.0.42:27831]   File
> "/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/postgis/base.py",
> line 11, in __init__
> [Mon Nov 09 00:48:14.621065 2015] [:error] [pid 2175] [remote
> 192.168.0.42:27831]     self.ops = PostGISOperations(self)
> [Mon Nov 09 00:48:14.621095 2015] [:error] [pid 2175] [remote
> "/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/postgis/operations.py",
> line 158, in __init__
> [Mon Nov 09 00:48:14.621136 2015] [:error] [pid 2175] [remote
> 192.168.0.42:27831]     if self.spatial_version < (1, 3, 4):
> [Mon Nov 09 00:48:14.621190 2015] [:error] [pid 2175] [remote
> "/usr/lib/python2.7/dist-packages/django/utils/functional.py", line 49, in
> __get__
> [Mon Nov 09 00:48:14.621232 2015] [:error] [pid 2175] [remote
> 192.168.0.42:27831]     res = instance.__dict__[self.func.__name__] =
> self.func(instance)
> [Mon Nov 09 00:48:14.621263 2015] [:error] [pid 2175] [remote
> line 258, in spatial_version
> [Mon Nov 09 00:48:14.621306 2015] [:error] [pid 2175] [remote
> 192.168.0.42:27831]     'template?' %
> self.connection.settings_dict['NAME']
> [Mon Nov 09 00:48:14.621354 2015] [:error] [pid 2175] [remote
> 192.168.0.42:27831] ImproperlyConfigured: Cannot determine PostGIS
> version for database "geonode_data". GeoDjango requires at least PostGIS
> version 1.3. Was the database created from a spatial database template?
> Regards
> Rajib
> *GIS Analyst*
> CDMP – II, UNDP
> *Sent:* 09 November 2015 13:19
> Hi,
> you can see what specific error is by reading the apache logs
> let us know so that we can better help you.
> Ciao
> 2015-11-08 7:05 GMT+01:00 Shah Md. Rajibul Islam <
> Dear Geonode users,
> I have installed GeoNode 2.4 RC1/GeoNode version 2.4c2 on
> ubuntu-14.04-server-i386. First I have installed it in a virtual machine
> using VMware workstation and successfully installed and accessed it with
> the configured local IP. Later on, I have installed the same version of
> Geonode on the same version of Ubuntu server 14.04. I don’t have a real IP
> and hence I have configured the geonode with the local IP of the server.
> But I cannot access it through the web browser. It gives 500 internal
> server error:
> *Internal Server Error*
> The server encountered an internal error or misconfiguration and was
> unable to complete your request.
> Please contact the server administrator at webmaster at localhost to inform
> them of the time this error occurred, and the actions you performed just
> before this error.
> More information about this error may be available in the server error log.
> *Apache/2.4.7 (Ubuntu) Server at 192.168.0.101 Port 80*
> Could you please suggest if it is related with the Local IP or I need a
> real IP to access it through web browser.
> Best regards
> Rajib
> *GIS Analyst*CDMP – II, UNDP
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151109/4b328c51/attachment-0001.html>
More information about the geonode-users mailing list
