[GeoNode-users] Error accesing geonode
Simone Dalmasso simone.dalmasso at gmail.com
Mon Nov 16 00:59:40 PST 2015
Maybe apache is still pointing to the wrong wsgi file, not the original
geonode. Also try to turn on debug in your settings, you will discover if
they are actually used and in case yes where the error is.
2015-11-16 9:44 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi Simone,
> I had it working normally before I started modifying all the look and feel
> part. Indeed, I haven't changed anything to pint to sqllite.
> I also have my local_settigns.py customized and it was working fine. How
> can I point the app to my settings file ?
> By the way I forgot to put the link with the instructions I followed:
> https://geonode.readthedocs.org/en/master/tutorials/admin/customize_admin/setup_admin.html#customize-setup-admin
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y
> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
> Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 – M 627 923 170 – F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
> *********************  LEGE OHARRA   *******************   AVISOLEGAL
> *******************   DISCLAIMER   *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
> kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está
> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
> sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally
> prohibited. If you are not the intended recipient, delete it without
> resending or backing it.
> De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> Enviado el: lunes, 16 de noviembre de 2015 9:37
> Para: David Alda Fernandez de Lezea
> CC: geonode-users at lists.osgeo.org
> Asunto: Re: [GeoNode-users] Error accesing geonode
> Hi David,
> it seems that your settings file is not configured with the correct
> database. Is trying to access a file so it's likely that is configured to
> use sqllite.
> Regards
> 2015-11-16 9:25 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi list,
> I've been trying to customize the look and feel of my geonode following
> the instructions in  . After configuring several options and not achieving
> to get anything working y decide to rollback, but now while accessing my
> geonode app y get the following error:
> OperationalError at /
> unable to open database file
> Request Method: GET
> Request URL:    http://192.168.1.190/
> Django Version: 1.6.10
> Exception Type: OperationalError
> Exception Value:
> Exception Location:
>  /usr/local/lib/python2.7/dist-packages/django/db/backends/sqlite3/base.py
> in get_new_connection, line 347
> Python Executable:      /usr/bin/python
> Python Version: 2.7.3
> Python Path:
> ['/usr/lib/python2.7',
>  '/usr/lib/python2.7/plat-linux2',
>  '/usr/lib/python2.7/lib-tk',
>  '/usr/lib/python2.7/lib-old',
>  '/usr/lib/python2.7/lib-dynload',
>  '/usr/local/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages/PIL',
>  '/usr/lib/python2.7/dist-packages/gst-0.10',
>  '/usr/lib/python2.7/dist-packages/gtk-2.0',
>  '/usr/lib/pymodules/python2.7',
>  '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
>  '/usr/lib/python2.7/dist-packages/ubuntuone-client',
>  '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
>  '/usr/lib/python2.7/dist-packages/ubuntuone-couch',
>  '/usr/lib/python2.7/dist-packages/ubuntuone-installer',
>  '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
>  '/var/www']
> Server time:    Mon, 16 Nov 2015 02:16:42 -0600
> I can access GeoServer though.
> Any ideas? Thanks in advance.
> Regards,
> Agur bero bat,
> Arloa.
> T 945 003 240 - M 627 923 170 - F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
> kontserbatu gabe.
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151116/6993fcbe/attachment-0001.html>
More information about the geonode-users mailing list
