[GeoNode-users] Error accesing geonode
Simone Dalmasso simone.dalmasso at gmail.com
Tue Nov 17 09:05:08 PST 2015
there is a symlink in
/usr/local/lib/python2.7/dist-packages/geonode/local_settings.py that
points to /etc/geonode/local_settings.py.
2015-11-17 9:27 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi again,
> In theory, the local_settigns.py does not have errors as it was working
> before the change.. Where is referenced from python the file
> /etc/geonode/local_settings.py??
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y
> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
> Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 – M 627 923 170 – F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
> *********************  LEGE OHARRA   *******************   AVISOLEGAL
> *******************   DISCLAIMER   *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
> kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está
> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
> sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally
> prohibited. If you are not the intended recipient, delete it without
> resending or backing it.
> De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> Enviado el: lunes, 16 de noviembre de 2015 10:47
> Para: David Alda Fernandez de Lezea
> CC: geonode-users at lists.osgeo.org
> Asunto: Re: [GeoNode-users] Error accesing geonode
> Ok then the /etc/geonode/local_settings.py file is not read correctly.
> The customization process that you used does not modify at all the geonode
> installation and to revert to a vanilla geonode it's enough to just point
> apache to the correct wsgi. So it must be something with the settings. Also
> a syntax erro in the local_settings could be the cause.
> 2015-11-16 10:40 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> I think I'm pointing to the right one:
> /etc/apache2/sites-available/geonode
> WSGIProcessGroup geonode
>     WSGIPassAuthorization On
>     WSGIScriptAlias / /var/www/geonode/wsgi/geonode.wsgi
>     <Directory "/var/www/geonode/">
>        Order allow,deny
>         Options Indexes FollowSymLinks
>         Allow from all
>         IndexOptions FancyIndexing
>     </Directory>
> Still getting the same error.
> Agur bero bat,
> Arloa.
> kontserbatu gabe.
> Enviado el: lunes, 16 de noviembre de 2015 10:00
> Maybe apache is still pointing to the wrong wsgi file, not the original
> geonode. Also try to turn on debug in your settings, you will discover if
> they are actually used and in case yes where the error is.
> 2015-11-16 9:44 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi Simone,
> I had it working normally before I started modifying all the look and feel
> part. Indeed, I haven't changed anything to pint to sqllite.
> I also have my local_settigns.py customized and it was working fine. How
> can I point the app to my settings file ?
> By the way I forgot to put the link with the instructions I followed:
> https://geonode.readthedocs.org/en/master/tutorials/admin/customize_admin/setup_admin.html#customize-setup-admin
> Agur bero bat,
> Arloa.
> kontserbatu gabe.
> Enviado el: lunes, 16 de noviembre de 2015 9:37
> Hi David,
> it seems that your settings file is not configured with the correct
> database. Is trying to access a file so it's likely that is configured to
> use sqllite.
> Regards
> 2015-11-16 9:25 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi list,
> I've been trying to customize the look and feel of my geonode following
> the instructions in  . After configuring several options and not achieving
> to get anything working y decide to rollback, but now while accessing my
> geonode app y get the following error:
> OperationalError at /
> unable to open database file
> Request Method: GET
> Request URL:    http://192.168.1.190/
> Django Version: 1.6.10
> Exception Type: OperationalError
> Exception Value:
> Exception Location:
>  /usr/local/lib/python2.7/dist-packages/django/db/backends/sqlite3/base.py
> in get_new_connection, line 347
> Python Executable:      /usr/bin/python
> Python Version: 2.7.3
> Python Path:
> ['/usr/lib/python2.7',
>  '/usr/lib/python2.7/plat-linux2',
>  '/usr/lib/python2.7/lib-tk',
>  '/usr/lib/python2.7/lib-old',
>  '/usr/lib/python2.7/lib-dynload',
>  '/usr/local/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages/PIL',
>  '/usr/lib/python2.7/dist-packages/gst-0.10',
>  '/usr/lib/python2.7/dist-packages/gtk-2.0',
>  '/usr/lib/pymodules/python2.7',
>  '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
>  '/usr/lib/python2.7/dist-packages/ubuntuone-client',
>  '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
>  '/usr/lib/python2.7/dist-packages/ubuntuone-couch',
>  '/usr/lib/python2.7/dist-packages/ubuntuone-installer',
>  '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
>  '/var/www']
> Server time:    Mon, 16 Nov 2015 02:16:42 -0600
> I can access GeoServer though.
> Any ideas? Thanks in advance.
> Regards,
> Agur bero bat,
> Arloa.
> T 945 003 240 - M 627 923 170 - F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
> kontserbatu gabe.
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151117/f2c35764/attachment-0001.html>
More information about the geonode-users mailing list
