[GeoNode-users] Error accesing geonode
David Alda Fernandez de Lezea dalda at hazi.eus
Wed Nov 18 02:49:36 PST 2015
Ok, so that's the problem.
So the documentation
https://geonode.readthedocs.org/en/2.0/tutorials/admin/customize_admin/setup_admin.html#customize-setup-admin
Should be corrected, because I followed the steps described there but the instructions to download pointed to a newer version. That is confusing if it remains like that.
Anyway, is there anything I can do to fix it?  Or do I have to reinstall everything..
Regards,
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda at hazi.eus | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
*********************  LEGE OHARRA   *******************   AVISOLEGAL   *******************   DISCLAIMER   *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Enviado el: miércoles, 18 de noviembre de 2015 10:37
Para: David Alda Fernandez de Lezea
CC: geonode-users at lists.osgeo.org
Asunto: Re: [GeoNode-users] Error accesing geonode
Ah! now I see.
Yes you used the wrong project. I suggest you to use the geonode from ppa:geonode/testing. It is the 2.4 rc2. We are going to release the stable in few days though.
2015-11-18 10:16 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
I don't think so, unless I've made the mistake of editing the wrong file since the beginning...
After the installation I began to edit the file local_settings.py under /etc/geonode. I changed GeServer urls, added different base layers, activated email registration and so on.
I guess is the right one.
What I'm thinking is that I installed geonode from apt-get which is 2.0.1 version and when I followed the steps for customizing the line
django-admin startproject my_geonode --template=https://github.com/GeoNode/geonode-project/archive/master.zip -epy,rst
does download the correct templates for my version? Because this is the only thing different that I've noticed.
Agur bero bat,
Enviado el: miércoles, 18 de noviembre de 2015 9:02
David,
was the PRINTNG in the local_settings?
my suspect is that the etc settings is old and comes from an older installation, is that possible?
Make sure it is similar to https://github.com/GeoNode/geonode/blob/master/geonode/local_settings.py.sample
2015-11-18 8:56 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
No way man. After doing what you said, I restarted the web server and tried to visit geonode's main page but I get 500 error. This is the output:
[Wed Nov 18 08:47:04 2015] [notice] caught SIGTERM, shutting down
[Wed Nov 18 01:47:04 2015] [error] Exception TypeError: "'NoneType' object is not callable" in <bound method LGEOS320.__del__ of <shapely.geos.LGEOS320 object at 0x7f492fa1e258>> ignored
Error opening file for reading: Permission denied
[Wed Nov 18 08:47:05 2015] [notice] Apache/2.2.22 (Ubuntu) mod_wsgi/3.3 Python/2.7.3 configured -- resuming normal operations
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] mod_wsgi (pid=11385): Exception occurred processing WSGI script '/var/www/geonode/wsgi/geonode.wsgi'.
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] Traceback (most recent call last):
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/core/handlers/wsgi.py", line 187, in __call__
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     self.load_middleware()
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py", line 47, in load_middleware
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     mw_instance = mw_class()
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/middleware/locale.py", line 24, in __init__
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     for url_pattern in get_resolver(None).url_patterns:
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/core/urlresolvers.py", line 365, in url_patterns
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     patterns = getattr(self.urlconf_module, "urlpatterns", self.urlconf_module)
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/core/urlresolvers.py", line 360, in urlconf_module
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     self._urlconf_module = import_module(self.urlconf_name)
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/utils/importlib.py", line 40, in import_module
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     __import__(name)
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/geonode/urls.py", line 30, in <module>
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     from geonode.api.urls import api
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/geonode/api/urls.py", line 3, in <module>
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     from .api import TagResource, TopicCategoryResource, ProfileResource, \\
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/geonode/api/api.py", line 188, in <module>
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     class ProfileResource(ModelResource):
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/geonode/api/api.py", line 276, in ProfileResource
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     class Meta:
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/geonode/api/api.py", line 277, in Meta
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     queryset = get_user_model().objects.exclude(username='AnonymousUser')
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/__init__.py", line 127, in get_user_model
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     user_model = get_model(app_label, model_name)
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/db/models/loading.py", line 271, in get_model
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     self._populate()
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/db/models/loading.py", line 75, in _populate
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     self.load_app(app_name, True)
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/db/models/loading.py", line 99, in load_app
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     models = import_module('%s.models' % app_name)
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/geonode/upload/models.py", line 28, in <module>
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     from geonode.geoserver.helpers import gs_uploader, ogc_server_settings
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line 1548, in <module>
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     ogc_server_settings = OGC_Servers_Handler(settings.OGC_SERVER)['default']
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line 1349, in __getitem__
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     self.ensure_valid_configuration(alias)
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line 1319, in ensure_valid_configuration
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65]     raise ImproperlyConfigured("The PRINTNG_ENABLED setting has been removed, use 'PRINT_NG_ENABLED' instead.")
[Wed Nov 18 01:47:17 2015] [error] [client 192.168.1.65] ImproperlyConfigured: The PRINTNG_ENABLED setting has been removed, use 'PRINT_NG_ENABLED' instead.
u0899dal at Geonode:/var/log/apache2$
Then I changed  PRINTNG_ENABLED to PRINT_NG_ENABLED (I don't know why do I have to this because it was working fine after the everything started to crash down) but I get the following error:
[Wed Nov 18 08:52:48 2015] [notice] caught SIGTERM, shutting down
[Wed Nov 18 08:52:49 2015] [notice] Apache/2.2.22 (Ubuntu) mod_wsgi/3.3 Python/2.7.3 configured -- resuming normal operations
[Wed Nov 18 01:53:06 2015] [error] Internal Server Error: /
[Wed Nov 18 01:53:06 2015] [error] Traceback (most recent call last):
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py", line 137, in get_response
[Wed Nov 18 01:53:06 2015] [error]     response = response.render()
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/response.py", line 105, in render
[Wed Nov 18 01:53:06 2015] [error]     self.content = self.rendered_content
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/response.py", line 82, in rendered_content
[Wed Nov 18 01:53:06 2015] [error]     content = template.render(context)
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 140, in render
[Wed Nov 18 01:53:06 2015] [error]     return self._render(context)
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 134, in _render
[Wed Nov 18 01:53:06 2015] [error]     return self.nodelist.render(context)
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Wed Nov 18 01:53:06 2015] [error]     bit = self.render_node(node, context)
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Wed Nov 18 01:53:06 2015] [error]     return node.render(context)
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/loader_tags.py", line 123, in render
[Wed Nov 18 01:53:06 2015] [error]     return compiled_parent._render(context)
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/loader_tags.py", line 62, in render
[Wed Nov 18 01:53:06 2015] [error]     result = block.nodelist.render(context)
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 891, in render
[Wed Nov 18 01:53:06 2015] [error]     output = self.filter_expression.resolve(context)
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 585, in resolve
[Wed Nov 18 01:53:06 2015] [error]     obj = self.var.resolve(context)
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 735, in resolve
[Wed Nov 18 01:53:06 2015] [error]     value = self._resolve_lookup(context)
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 789, in _resolve_lookup
[Wed Nov 18 01:53:06 2015] [error]     current = current()
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/loader_tags.py", line 72, in super
[Wed Nov 18 01:53:06 2015] [error]     return mark_safe(self.render(self.context))
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/loader_tags.py", line 155, in render
[Wed Nov 18 01:53:06 2015] [error]     return self.render_template(self.template, context)
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/loader_tags.py", line 137, in render_template
[Wed Nov 18 01:53:06 2015] [error]     output = template.render(context)
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/template/defaulttags.py", line 304, in render
[Wed Nov 18 01:53:06 2015] [error]     if match:
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 100, in __nonzero__
[Wed Nov 18 01:53:06 2015] [error]     self._fetch_all()
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 857, in _fetch_all
[Wed Nov 18 01:53:06 2015] [error]     self._result_cache = list(self.iterator())
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py", line 220, in iterator
[Wed Nov 18 01:53:06 2015] [error]     for row in compiler.results_iter():
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py", line 713, in results_iter
[Wed Nov 18 01:53:06 2015] [error]     for rows in self.execute_sql(MULTI):
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/db/models/sql/compiler.py", line 786, in execute_sql
[Wed Nov 18 01:53:06 2015] [error]     cursor.execute(sql, params)
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/db/backends/util.py", line 53, in execute
[Wed Nov 18 01:53:06 2015] [error]     return self.cursor.execute(sql, params)
[Wed Nov 18 01:53:06 2015] [error]   File "/usr/local/lib/python2.7/dist-packages/django/db/utils.py", line 99, in __exit__
[Wed Nov 18 01:53:06 2015] [error]     six.reraise(dj_exc_type, dj_exc_value, traceback)
[Wed Nov 18 01:53:06 2015] [error] ProgrammingError: column announcements_announcement.level does not exist
[Wed Nov 18 01:53:06 2015] [error] LINE 1: ...ment"."id", "announcements_announcement"."title", "announcem...
[Wed Nov 18 01:53:06 2015] [error]                                                              ^
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65] mod_wsgi (pid=11661): Exception occurred processing WSGI script '/var/www/geonode/wsgi/geonode.wsgi'.
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65] Traceback (most recent call last):
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/core/handlers/wsgi.py", line 206, in __call__
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]     response = self.get_response(request)
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py", line 194, in get_response
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]     response = self.handle_uncaught_exception(request, resolver, sys.exc_info())
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py", line 236, in handle_uncaught_exception
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]     return callback(request, **param_dict)
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/utils/decorators.py", line 99, in _wrapped_view
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]     response = view_func(request, *args, **kwargs)
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/views/defaults.py", line 46, in server_error
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]     return http.HttpResponseServerError(template.render(Context({})))
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 140, in render
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]     return self._render(context)
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 134, in _render
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]     return self.nodelist.render(context)
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 840, in render
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]     bit = self.render_node(node, context)
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/template/base.py", line 854, in render_node
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]     return node.render(context)
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/template/loader_tags.py", line 53, in render
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]     result = self.nodelist.render(context)
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/template/loader_tags.py", line 155, in render
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]     return self.render_template(self.template, context)
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/template/loader_tags.py", line 137, in render_template
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]     output = template.render(context)
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/announcements/templatetags/announcements_tags.py", line 24, in render
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]     request = context["request"]
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]   File "/usr/local/lib/python2.7/dist-packages/django/template/context.py", line 56, in __getitem__
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65]     raise KeyError(key)
[Wed Nov 18 01:53:06 2015] [error] [client 192.168.1.65] KeyError: 'request'
I'm running out of ideas.
Regards,
Agur bero bat,
Enviado el: miércoles, 18 de noviembre de 2015 8:35
ok then create the symlink:
$ sudo ln -sf /etc/geonode/local_settings.py /usr/local/lib/python2.7/dist-packages/geonode/local_settings.py that points to /etc/geonode/local_settings.py
restart the web server and you should be ok
2015-11-18 8:25 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
In the mentioned directory there's no "local_setttings.py" but there is a settings.py which has another GeoNode set up as I can see. Here's the content of the directory:
u0899dal at Geonode:/usr/local/lib/python2.7/dist-packages/geonode$ ls -al
total 264
drwxr-sr-x  23 root staff  4096 nov 13 14:23 .
drwxrwsr-x 107 root staff  4096 nov 13 14:20 ..
drwxr-sr-x   2 root staff  4096 nov 13 14:19 api
drwxr-sr-x   6 root staff  4096 nov 13 14:19 base
drwxr-sr-x   4 root staff  4096 nov 13 14:19 catalogue
-rw-r--r--   1 root staff   314 nov 13 14:17 celery_app.py
-rw-r--r--   1 root staff   477 nov 13 14:19 celery_app.pyc
-rw-r--r--   1 root staff  3018 nov 13 14:17 context_processors.py
-rw-r--r--   1 root staff  1874 nov 13 14:19 context_processors.pyc
drwxr-sr-x   4 root staff  4096 nov 13 14:19 contrib
drwxr-sr-x   5 root staff  4096 nov 13 14:19 documents
drwxr-sr-x   3 root staff  4096 nov 13 14:19 geoserver
drwxr-sr-x   4 root staff  4096 nov 13 14:19 groups
-rw-r--r--   1 root staff  1291 nov 13 14:17 __init__.py
-rw-r--r--   1 root staff  1195 nov 13 14:19 __init__.pyc
drwxr-sr-x   5 root staff  4096 nov 13 14:19 layers
drwxr-sr-x  38 root staff  4096 nov 13 14:19 locale
drwxr-sr-x   4 root staff  4096 nov 13 14:19 maps
-rw-r--r--   1 root staff  1192 nov 13 14:17 middleware.py
-rw-r--r--   1 root staff  1832 nov 13 14:19 middleware.pyc
drwxr-sr-x   5 root staff  4096 nov 13 14:19 people
drwxr-sr-x   2 root staff  4096 nov 13 14:19 proxy
drwxr-sr-x   3 root staff  4096 nov 13 14:19 security
drwxr-sr-x   4 root staff  4096 nov 13 14:19 services
-rw-r--r--   1 root staff 26032 nov 13 14:17 settings.py
-rw-r--r--   1 root staff 18850 nov 13 14:19 settings.pyc
-rw-r--r--   1 root staff  1218 nov 13 14:17 sitemap.py
-rw-r--r--   1 root staff  1336 nov 13 14:19 sitemap.pyc
drwxr-sr-x   4 root staff  4096 nov 13 14:19 social
drwxr-sr-x   4 root staff  4096 nov 13 14:19 static
drwxr-sr-x  21 root staff  4096 nov 13 14:23 static_root
drwxr-sr-x   2 root staff  4096 nov 13 14:19 tasks
drwxr-sr-x  13 root staff  4096 nov 13 14:19 templates
drwxr-sr-x   2 root staff  4096 nov 13 14:19 tests
drwxr-sr-x   4 root staff  4096 nov 13 14:19 upload
-rw-r--r--   1 root staff  5638 nov 13 14:17 urls.py
-rw-r--r--   1 root staff  3999 nov 13 14:19 urls.pyc
-rw-r--r--   1 root staff 21450 nov 13 14:17 utils.py
-rw-r--r--   1 root staff 21371 nov 13 14:19 utils.pyc
-rw-r--r--   1 root staff  2623 nov 13 14:17 version.py
-rw-r--r--   1 root staff  2268 nov 13 14:19 version.pyc
-rw-r--r--   1 root staff  3927 nov 13 14:17 views.py
-rw-r--r--   1 root staff  3385 nov 13 14:19 views.pyc
-rw-r--r--   1 root staff  1105 nov 13 14:17 wsgi.py
-rw-r--r--   1 root staff   362 nov 13 14:19 wsgi.pyc
Regards,
Agur bero bat,
Enviado el: martes, 17 de noviembre de 2015 18:05
there is a symlink in /usr/local/lib/python2.7/dist-packages/geonode/local_settings.py that points to /etc/geonode/local_settings.py.
2015-11-17 9:27 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
Hi again,
In theory, the local_settigns.py does not have errors as it was working before the change.. Where is referenced from python the file /etc/geonode/local_settings.py??
Agur bero bat,
Enviado el: lunes, 16 de noviembre de 2015 10:47
Ok then the /etc/geonode/local_settings.py file is not read correctly.
The customization process that you used does not modify at all the geonode installation and to revert to a vanilla geonode it's enough to just point apache to the correct wsgi. So it must be something with the settings. Also a syntax erro in the local_settings could be the cause.
2015-11-16 10:40 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
I think I'm pointing to the right one:
/etc/apache2/sites-available/geonode
WSGIProcessGroup geonode
    WSGIPassAuthorization On
    WSGIScriptAlias / /var/www/geonode/wsgi/geonode.wsgi
    <Directory "/var/www/geonode/">
       Order allow,deny
        Options Indexes FollowSymLinks
        Allow from all
        IndexOptions FancyIndexing
    </Directory>
Still getting the same error.
Agur bero bat,
Enviado el: lunes, 16 de noviembre de 2015 10:00
Maybe apache is still pointing to the wrong wsgi file, not the original geonode. Also try to turn on debug in your settings, you will discover if they are actually used and in case yes where the error is.
2015-11-16 9:44 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
Hi Simone,
I had it working normally before I started modifying all the look and feel part. Indeed, I haven't changed anything to pint to sqllite.
I also have my local_settigns.py customized and it was working fine. How can I point the app to my settings file ?
By the way I forgot to put the link with the instructions I followed: https://geonode.readthedocs.org/en/master/tutorials/admin/customize_admin/setup_admin.html#customize-setup-admin
Agur bero bat,
Enviado el: lunes, 16 de noviembre de 2015 9:37
Hi David,
it seems that your settings file is not configured with the correct database. Is trying to access a file so it's likely that is configured to use sqllite.
Regards
2015-11-16 9:25 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
Hi list,
I've been trying to customize the look and feel of my geonode following the instructions in  . After configuring several options and not achieving to get anything working y decide to rollback, but now while accessing my geonode app y get the following error:
OperationalError at /
unable to open database file
Request Method: GET
Request URL:    http://192.168.1.190/
Django Version: 1.6.10
Exception Type: OperationalError
Exception Value:
Exception Location:     /usr/local/lib/python2.7/dist-packages/django/db/backends/sqlite3/base.py in get_new_connection, line 347
Python Executable:      /usr/bin/python
Python Version: 2.7.3
Python Path:
['/usr/lib/python2.7',
 '/usr/lib/python2.7/plat-linux2',
 '/usr/lib/python2.7/lib-tk',
 '/usr/lib/python2.7/lib-old',
 '/usr/lib/python2.7/lib-dynload',
 '/usr/local/lib/python2.7/dist-packages',
 '/usr/lib/python2.7/dist-packages',
 '/usr/lib/python2.7/dist-packages/PIL',
 '/usr/lib/python2.7/dist-packages/gst-0.10',
 '/usr/lib/python2.7/dist-packages/gtk-2.0',
 '/usr/lib/pymodules/python2.7',
 '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
 '/usr/lib/python2.7/dist-packages/ubuntuone-client',
 '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
 '/usr/lib/python2.7/dist-packages/ubuntuone-couch',
 '/usr/lib/python2.7/dist-packages/ubuntuone-installer',
 '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
 '/var/www']
Server time:    Mon, 16 Nov 2015 02:16:42 -0600
I can access GeoServer though.
Any ideas? Thanks in advance.
Regards,
Agur bero bat,
T 945 003 240 - M 627 923 170 - F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
Simone
Simone
Simone
Simone
Simone
Simone
More information about the geonode-users mailing list
