[GeoNode-users] GeoNode/GeoServer update issue
Simone Dalmasso simone.dalmasso at gmail.com
Mon Nov 23 01:16:06 PST 2015
Ops sorry, I gave you wrong information :)
the file is data/security/auth/geonodeAuthProvider/config.xml
2015-11-23 10:12 GMT+01:00 Francesco Marigliano <f.marigliano.it at ieee.org>:
> Il 23/11/2015 10:04, Simone Dalmasso ha scritto:
> Hi Francesco, seems a communication issue between geoserver and geonode.
> Can you take a look at the geoserver logs?
> Here you are
> at
> org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
>     at
> org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
>     at
> org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:313)
>     at
> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>     at
> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>     at java.lang.Thread.run(Thread.java:745)
> Caused by: java.io.IOException: HTTPClient::sendGET: GeoNode communication
> failed, status report is: 404, Not Found, http://localhost/layers/acls
>     at org.geonode.security.HTTPClient.sendGET(HTTPClient.java:95)
>     at
> org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:185)
>     at
> org.geonode.security.DefaultSecurityClient.authenticateCookie(DefaultSecurityClient.java:116)
>     at
> org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:66)
> in case chack that /he WEB-INF/web.xml file of geoserver points to the
> correct geonode address.
> Did you mean "PROXY_BASE_URL" field?
> 2015-11-23 9:48 GMT+01:00 Francesco Marigliano <f.marigliano.it at ieee.org>:
>> Hi all,
>> I recently updated GeoNode to *2.4c4, *after that if I'm not logged into
>> GeoServer I can't see any layer in GeoExplorer.
>> Just checked *local_settings.py *it seems to be everything ok.
>> [image: Avast logo] <https://www.avast.com/antivirus>
>> Questa e-mail è stata controllata per individuare virus con Avast
>> antivirus.
>> www.avast.com <https://www.avast.com/antivirus>
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
> antivirus.
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151123/a08cce2d/attachment-0001.html>
More information about the geonode-users mailing list
