[GeoNode-users] GeoNode/GeoServer update issue
Francesco Marigliano f.marigliano.it at ieee.org
Mon Nov 23 01:28:57 PST 2015
After tomcat restart it works.
Thanks
Il 23/11/2015 10:24, Simone Dalmasso ha scritto:
> Ok, consider that the communication between geoserver and geonode is
> "internal" so if geonode and geoserver are on the same server and
> geonode responds to the root of the server address "/" the localhost
> is fine because for geoserver geonode is on localhost. But if your
> server address is /mysite.it <http://mysite.it>/ and geonode responds
> to /mygeonode.mysite./it then the change you have done is fine.
> To apply the fixes you have to restart tomcat though as apache only
> deals with the geonode code.
> 2015-11-23 10:20 GMT+01:00 Francesco Marigliano
> <f.marigliano.it at ieee.org <mailto:f.marigliano.it at ieee.org>>:
>     Just changed baseUrl from/http://localhost// to
>     /http://mygeonode.mysite.it, /after apache//restart never seems to
>     change
>     Il 23/11/2015 10:16, Simone Dalmasso ha scritto:
>>     Ops sorry, I gave you wrong information :)
>>     the file is data/security/auth/geonodeAuthProvider/config.xml
>>     2015-11-23 10:12 GMT+01:00 Francesco Marigliano
>>         Il 23/11/2015 10:04, Simone Dalmasso ha scritto:
>>>         Hi Francesco, seems a communication issue between geoserver
>>>         and geonode. Can you take a look at the geoserver logs?
>>         Here you are
>>         at
>>         org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
>>             at
>>         org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
>>             at
>>         org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:313)
>>             at
>>         java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>>             at
>>         java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>>             at java.lang.Thread.run(Thread.java:745)
>>         Caused by: java.io.IOException: HTTPClient::sendGET: GeoNode
>>         communication failed, status report is: 404, Not Found,
>>         http://localhost/layers/acls
>>             at
>>         org.geonode.security.HTTPClient.sendGET(HTTPClient.java:95)
>>             at
>>         org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:185)
>>             at
>>         org.geonode.security.DefaultSecurityClient.authenticateCookie(DefaultSecurityClient.java:116)
>>             at
>>         org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:66)
>>>         in case chack that /he WEB-INF/web.xml file of geoserver
>>>         points to the correct geonode address.
>>         Did you mean "PROXY_BASE_URL" field?
>>>         2015-11-23 9:48 GMT+01:00 Francesco Marigliano
>>>             Hi all,
>>>             I recently updated GeoNode to /2.4c4, /after that if I'm
>>>             not logged into GeoServer I can't see any layer in
>>>             GeoExplorer.
>>>             Just checked /local_settings.py /it seems to be
>>>             everything ok.
>>>             Avast logo <https://www.avast.com/antivirus>
>>>             Questa e-mail è stata controllata per individuare virus
>>>             con Avast antivirus.
>>>             www.avast.com <https://www.avast.com/antivirus>
>>>             _______________________________________________
>>>             geonode-users mailing list
>>>             geonode-users at lists.osgeo.org
>>>             <mailto:geonode-users at lists.osgeo.org>
>>>             http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>         Simone
>>         Questa e-mail è stata controllata per individuare virus con
>>         Avast antivirus.
>>     Simone
>     Questa e-mail è stata controllata per individuare virus con Avast
>     antivirus.
> Simone
Questa e-mail è stata controllata per individuare virus con Avast antivirus.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151123/4484c3af/attachment.html>
More information about the geonode-users mailing list
