[GeoNode-users] R: Problem to set new list of scale map in geonode
Albano Giovanni albano.giovanni at tiscali.it
Mon Nov 23 04:49:50 PST 2015
yes the ones in the map composer
Giovanni Albano
Da: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Inviato: lunedì 23 novembre 2015 13:25
A: Albano Giovanni
Cc: geonode-users at lists.osgeo.org
Oggetto: Re: [GeoNode-users] Problem to set new list of scale map in geonode
Hi what do you mean by geonode list of scales? the ones in the map composer?
2015-11-23 12:38 GMT+01:00 Albano Giovanni <albano.giovanni at tiscali.it>:
Good morning,
I have a problem with the list of map scales.
I'm trying to change the list of map scales.
I would use those in gridset: GlobalCRS84Scale
I modified the default gridset in geoserver and i reloaded the gridset using command of geoserver Seed / Truncate of the layer.
But when I open geonode list of scales refers to the old gridset. What's wrong?
Thanks for the help.
Giovanni Albano
Rispetta l’ambiente. Hai davvero bisogno di stampare questa mail?
Please consider the environment – Do you really need to print this email?
Ai sensi del D.lgs n. 196 del 30.06.03 (Codice Privacy) si precisa che le informazioni contenute in questo messaggio sono riservate e ad uso esclusivo del destinatario. Qualora il messaggio in parola Le fosse pervenuto per errore, La preghiamo di eliminarlo senza copiarlo e di non inoltrarlo a terzi, dandocene gentilmente comunicazione. Grazie
This message, for the D.lgs n. 196 / 30.06.03 (Privacy Code), may contain confidential and/or privileged information. If you are not the addressee or authorized to receive this for the addressee, you must not use, copy, disclose or take any action based on this message or any information herein. If you have received this message in error, please advise the sender immediately by reply e-mail and delete this message. Thank you for your cooperation
Da: geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] Per conto di Simone Dalmasso
Inviato: lunedì 23 novembre 2015 10:59
A: Florian Hoedt
Oggetto: Re: [GeoNode-users] How to migrate from ppa testing to ppa stable?
Hi Florian,
you are right, from testing to stable is pretty straightforward. Just add ppa:geonode/stable sudo apt-get update and sudo apt-get install geonode.
A collectstatic might also be needed. For the downstream project, we added the mapping cart (see demo http://demo.geonode.org/layers/), just check whether it fits with your templates.
2015-11-23 10:52 GMT+01:00 Florian Hoedt <florian.hoedt at hs-owl.de>:
I am happy to read that geonode 2.4 reached a stable state. I currently use Version 2.4c2 from the testing branch. How to migrate to the stable branch?
I have created some styles via:
sudo -E django-admin startproject my_geonode --template=https://github.com/GeoNode/geonode-project/archive/master.zip -epy,rst
In theory I should update the master branch and my_geonode would just work as before, since it is a template which gets loaded in addition to the main geonode.
yours
Florian
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151123/2f396293/attachment-0001.html>
More information about the geonode-users mailing list
