[GeoNode-users] Fwd: Problems with upload shapefile
Simone Dalmasso simone.dalmasso at gmail.com
Wed Nov 25 06:55:00 PST 2015
ok Can you give us more details on how you installed GeoNode?
using apt-get or manual?
Did you add any geoserver plugins?
2015-11-25 15:53 GMT+01:00 Ariel Cabezas <gerardoarielc at gmail.com>:
> Simone thanks,
> in the
> /usr/share/geoserver/data/security/auth/geonodeAuthProvider/config.xml
> already i had <baseUrl>http://server.idejujuy.gov.ar</baseUrl>
> in the
> ..../geonode/local_settings.py
> i have SITEURL='http://server.idejujuy.gov.ar/'
> in the web page http://server.idejujuy.gov.ar/geoserver/web/.....
> Option "Settings / Global"
> i have Proxy Base URL
> But the error continues
> Where else i can check this connection Geoserver/Geonode.
> and what can i check from Geoserver-side ?
> the installation is the last version of Geonode on Ubuntu 14.04,
> thanks again
> Ariel
> IDEJ
> 2015-11-25 4:16 GMT-03:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Hi, seems that geoserver is unable to connect to geonode. Make sure that
>> the file geoserver_data_dir/security/auth/geonodeAuthProvider/config.xml
>> points to the correct geonode address. Then restart tomcat
>> 2015-11-25 1:26 GMT+01:00 Ariel Cabezas <gerardoarielc at gmail.com>:
>>> Hi all, I'm trying to upload shape files
>>> and problems ...
>>> with Geonode SuperUser
>>> my host is server.idejujuy.gov.ar
>>> any help?
>>> thanks
>>> Tried to make a GET request to
>>> http://localhost:8080/geoserver/rest/workspaces/default.xml but got a
>>> 401 status code:
>>> Estado HTTP 401 - Communication with GeoNode failed
>>> (UsernamePasswordAuthenticationToken)
>>> type Informe de estado
>>> mensaje *Communication with GeoNode failed
>>> (UsernamePasswordAuthenticationToken)*
>>> descripciĆ³n *Este requerimiento requiere autenticaciĆ³n HTTP.*
>>> Apache Tomcat/7.0.52 (Ubuntu)
>>> Ariel,
>>> Administracion IDEJ
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151125/3f3edef1/attachment.html>
More information about the geonode-users mailing list
