[GeoNode-users] Fwd: Problems with upload shapefile
Simone Dalmasso simone.dalmasso at gmail.com
Wed Nov 25 14:28:29 PST 2015
Ok, if you change then geoserver password then you have to update it also
in the settings. Add this block to your local_settings.py adjusting the
credentials
https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L493
2015-11-25 17:00 GMT+01:00 Ariel Cabezas <gerardoarielc at gmail.com>:
> ok,
> last version of Geonode on Ubuntu 14.04,
> using apt-get
> no any geoserver plugin
> i rememebr now
> i changed the default geoserver password from Geoserver option Seguridad /
> Users,Groups and Roles for user admin;
> and now i rewrote the passw by default
> and the message error is :
> Unable to find the server at server.idejujuy.gov.ar
> but in GeoServer Layer Preview i can see the shape upload
> 2015-11-25 11:55 GMT-03:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> ok Can you give us more details on how you installed GeoNode?
>> using apt-get or manual?
>> Did you add any geoserver plugins?
>> 2015-11-25 15:53 GMT+01:00 Ariel Cabezas <gerardoarielc at gmail.com>:
>>> Simone thanks,
>>> in the
>>> /usr/share/geoserver/data/security/auth/geonodeAuthProvider/config.xml
>>> already i had <baseUrl>http://server.idejujuy.gov.ar</baseUrl>
>>> in the
>>> ..../geonode/local_settings.py
>>> i have SITEURL='http://server.idejujuy.gov.ar/'
>>> in the web page http://server.idejujuy.gov.ar/geoserver/web/.....
>>> Option "Settings / Global"
>>> i have Proxy Base URL
>>> But the error continues
>>> Where else i can check this connection Geoserver/Geonode.
>>> and what can i check from Geoserver-side ?
>>> the installation is the last version of Geonode on Ubuntu 14.04,
>>> thanks again
>>> Ariel
>>> IDEJ
>>> 2015-11-25 4:16 GMT-03:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>> Hi, seems that geoserver is unable to connect to geonode. Make sure
>>>> that the file
>>>> geoserver_data_dir/security/auth/geonodeAuthProvider/config.xml points to
>>>> the correct geonode address. Then restart tomcat
>>>> 2015-11-25 1:26 GMT+01:00 Ariel Cabezas <gerardoarielc at gmail.com>:
>>>>> Hi all, I'm trying to upload shape files
>>>>> and problems ...
>>>>> with Geonode SuperUser
>>>>> my host is server.idejujuy.gov.ar
>>>>> any help?
>>>>> thanks
>>>>> Tried to make a GET request to
>>>>> http://localhost:8080/geoserver/rest/workspaces/default.xml but got a
>>>>> 401 status code:
>>>>> Estado HTTP 401 - Communication with GeoNode failed
>>>>> (UsernamePasswordAuthenticationToken)
>>>>> type Informe de estado
>>>>> mensaje *Communication with GeoNode failed
>>>>> (UsernamePasswordAuthenticationToken)*
>>>>> descripciĆ³n *Este requerimiento requiere autenticaciĆ³n HTTP.*
>>>>> Apache Tomcat/7.0.52 (Ubuntu)
>>>>> Ariel,
>>>>> Administracion IDEJ
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151125/eb0c0d6e/attachment.html>
More information about the geonode-users mailing list
