[GeoNode-users] theming geonode fails with connection refused error
Florian Hoedt florian.hoedt at hs-owl.de
Fri Oct 2 06:15:39 PDT 2015
Hi Jeffrey,
tackled it with your help, thanks.
For the list it was a proxy error. You are able to work around it with:
sudo update-ca-certificates
export http_proxy=http://<proxy>:<port>
export https_proxy=http://<proxy>:<port>
sudo -E django-admin startproject my_geonode --template=https://github.com/GeoNode/geonode-project/archive/master.zip -epy,rst
Seems like the environmental variable for https proxy was lost between my putty-ssh sessions.
mit freundlichen Grüßen
Florian Hoedt
B.Sc. Florian Hoedt
Hochschule Ostwestfalen-Lippe / Campus Höxter
FB 9 Landschaftsarchitektur und Umweltplanung
An der Wilhelmshöhe 44
37671 Höxter
Tel.: 05271-687-7478
E-Mail: florian.hoedt at hs-owl.de
www.hs-owl.de/fb9
-----Ursprüngliche Nachricht-----
Von: Jeffrey Johnson [mailto:ortelius at gmail.com]
Gesendet: Freitag, 2. Oktober 2015 15:07
An: Florian Hoedt
Cc: geonode-users at lists.osgeo.org
Betreff: Re: [GeoNode-users] theming geonode fails with connection refused error
There is some network issue on your side. The command works fine for me.
On Fri, Oct 2, 2015 at 9:03 AM, Florian Hoedt <florian.hoedt at hs-owl.de> wrote:
> Hi,
> I´ve installed latest geonode on a Ubutu 14.04 LTS:
> sudo add-apt-repository ppa:geonode/testing
> And want to theme my geonode and tried to follow these instructions:
> http://docs.geonode.org/en/latest/tutorials/admin/customize_admin/setu
> p_admin.html
> But this command fails:
> --template=https://github.com/geonode/geonode-project/archive/master.z
> ip -epy,rst
>>> CommandError: couldn't download URL
>>> https://github.com/geonode/geonode-project/archive/master.zip to
>>> master.zip: [Errno socket error] [Errno 111] Connection refused
> Thought it could be a proxy related issue and tried:
> ip -epy,rst
> with identical error message.
> What is wrong?
> Regards,
> Florian Hoedt
> B.Sc. Florian Hoedt
> Hochschule Ostwestfalen-Lippe / Campus Höxter FB 9
> Landschaftsarchitektur und Umweltplanung An der Wilhelmshöhe 44
> 37671 Höxter
> www.hs-owl.de/fb9
> geonode-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
