[GeoNode-users] shapefile size restriction
Stefan Steiniger sstein at geo.uzh.ch
Fri Oct 2 14:42:25 PDT 2015
Hey Lautaro,
this is rather a work-around than a solution:
Big shapefiles (> 100 MB) I am copying over to the server and loading
them there with the command line using "geonode importlayers". You may
also check your postgis tables: After I tried a couple of times I
noticed that I had the files actually loaded into the DB, but they were
not linked to GeoNode/GeoServer etc. So it was more or less a network
issue. Copying the data first prevented that.
cheers,
Stefan
On 10/02/2015 06:08 PM, Lautaro Silva wrote:
> Hello all
> I'm running GeoNode configured datastore in settings.py to load al the
> features into a postgis database.
> That is working almost ok, but when i am trying to upload a Shapefile
> over 100mb i get errors like:
> "An exception occurred loading data to PostGIS-
> Proxy Error
> The proxy server received an invalid response from an upstream server.
> The proxy server could not handle the request PUT
> /geoserver/rest/workspaces/geonode/datastores/datastore/file.shp.
> Reason: Error reading from remote server"
> and some times this one:
> java.lang.RuntimeException: java.io.IOException: Error occured
> calculating bounds for predios_rural"
> Had anyone experienced similar problems with big files?
> It is posible that i am doing something wrong?
> Thanks in advance
> *Lautaro Silva <http://lautarosilva.cl>*
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151002/df6d7c7f/attachment.html>
More information about the geonode-users mailing list
