[GeoNode-users] Permissions on GeoNode deployment
Simone Dalmasso simone.dalmasso at gmail.com
Tue Oct 6 23:24:57 PDT 2015
Melvin,
the docs to deploy it with a custom installation is actually this one that
you followed.
http://docs.geonode.org/en/master/tutorials/admin/install/custom_install.html#custom-install,
I use those steps when I need to deploy a new GeoNode with custom
installation.
The errors that you are encountering seems to me due to what I wrote
previously, incorrect SITE_URL settings and Geoserver misconfiguration.
2015-10-07 1:04 GMT+02:00 Melvin Ramos <melvin.ramos1991 at gmail.com>:
> Hi Simone,
> I already did everything written in that webpage. Nothing so far. I've
> spending several days trying to find out what is wrong but nothing so far.
> So I propose the following if it's possible of course. I'm thinking on
> creating a new deployment. Since there is no documentation regarding
> deployment on live servers (
> http://geonode.readthedocs.org/en/master/tutorials/admin/deploy/index.html#deploy
> is empty), according to your experience (anyone is invited to contribute),
> which are the steps to follow, regarding permissions, in order to deploy
> GeoNode correctly?
> Thanks in advance,
> Melvin
> Enviado con MailTrack
> <https://mailtrack.io/install?source=signature&lang=es&referral=melvin.ramos1991@gmail.com&idSignature=23>
> 2015-09-30 1:40 GMT-04:30 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Hi Melvin, there may be more than one errors here:
>> - first seems that you did not set the SITE_URL properly in the settings
>> as the client is requesting the static content over localhost:8000 so maybe
>> you have also to turn odd DEBUG and do a collectstatic (check also the
>> settings for static_root and apache ownership there).
>> - second geoserver may be unable to access GeoNode for authentication
>> purposes because is looking for it on port 8000, for this you should refer
>> to the docs here
>> hope this helps
>> 2015-09-29 23:51 GMT+02:00 Melvin Ramos <melvin.ramos1991 at gmail.com>:
>>> Hello community,
>>> I made a deployment of GeoNode (using the GitHub way, meaning the
>>> version is 2.4bSomething) in a VPS server, and at first I had trouble
>>> because I couldn't upload files. I changed the ownership of the uploaded
>>> folder from root to www-data to fix this.
>>> Although everything works fine regarding the uploading, once uploaded
>>> the file, the system can't show the layers in the map viewer (both the
>>> layer detail and the viewer alone), and also if you set up the thumbnail,
>>> it creates the thumb file, but it doesn't show it. It gives this error:
>>> Failed to load resource: net::ERR_NETWORK_ACCESS_DENIED
>>> http://localhost:8000/uploaded/thumbs/layer-1886cbce-4162-11e5-92a1-f23c91e4f95f-thumb.png
>>> Any ideas what I am missing?
>>> Thanks in advance
>>> Melvin David Ramos Macías
>>> 07-41408
>>> Ingeniería de Computación
>>> Universidad Simón Bolívar
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Simone
> 07-41408
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151007/bb78a1e9/attachment.html>
More information about the geonode-users mailing list
