[GeoNode-users] Fwd: [GeoNode-devel] bing api request denied
Davi Custodio davicustodio at gmail.com
Thu Oct 8 11:52:09 PDT 2015
---------- Forwarded message ----------
Date: Thu, Oct 8, 2015 at 11:16 AM
Subject: Re: [GeoNode-users] [GeoNode-devel] bing api request denied
To: Paolo Corti <pcorti at gmail.com>
Simone and Paolo,
started happening some strange things in all my GeoNode servers after the
problem with Bing began to happen:
1 - When performing "geonode updatelayers" no thumb file is generated in
the /var/www/geonode/uploaded/thumbs
2 - When you access a layer and force the thumb generation in the "set"
button, the thumb is usually generated for some layers and your file too,
but for most, the thumb generated shows only the background map (Mapquest
OpenStreetMap) without showing the contents of the layer of geoserver.
Tested in both situations: taking and keeping bing in the local_settings.py.
Any idea what might be going on?
On Thu, Oct 8, 2015 at 11:06 AM, Paolo Corti <pcorti at gmail.com> wrote:
> It works perfectly, thanks Simone!
> For people not confident with the django shell, the same result can be
> accomplished running the following SQL (not tested but should work):
> DELETE FROM maps_maplayer WHERE NAME = 'AerialWithLabels'
> p
> On Thu, Oct 8, 2015 at 2:34 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> Here the two commands that you can type in a "geonode shell" (for a
>> standard geonode installation) to remove bing from existing maps.
>> >>> from geonode.maps.models import MapLayer
>> >>> MapLayer.objects.filter(name=u'AerialWithLabels').delete()
>> Hope this helps
>> 2015-10-07 16:06 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Paolo that's right :(
>>> 2015-10-07 15:57 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>>>> Thanks to both
>>>> for system in productions containing existing maps I think the only way
>>>> is to follow Bart's suggestion or running a script able to remove the Bing
>>>> map baselayer from any existing map.
>>>> cheers
>>>> p
>>>> On Wed, Oct 7, 2015 at 3:51 PM, Simone Dalmasso <
>>>> simone.dalmasso at gmail.com> wrote:
>>>>> Thanks Bart,
>>>>> then is good to keep it disabled by default and add instructions on
>>>>> how to properly add it.
>>>>> 2015-10-07 15:50 GMT+02:00 Bart van den Eijnden <
>>>>> bartvde at boundlessgeo.com>:
>>>>>> Ideally you would have requested your own API key for your site on
>>>>>> https://www.bingmapsportal.com
>>>>>> And then configure the gxp Bing source with the apiKey property /
>>>>>> config.
>>>>>> Best regards,
>>>>>> Bart
>>>>>> Front End Software Engineer | Boundless <http://boundlessgeo.com/>
>>>>>> 1-877-673-6436 <917-460-7207>
>>>>>> @boundlessgeo <http://twitter.com/boundlessgeo/>
>>>>>> <http://boundlessgeo.com>
>>>>>> On 07 Oct 2015, at 15:41, Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>>> wrote:
>>>>>> Dears,
>>>>>> from yesterday the bing maps api that are used by default in every
>>>>>> GeoNode map are not working anymore due to a request denied. The effect is
>>>>>> that every map in GeoNode cannot be zoomed properly anymore.
>>>>>> While we try to figure out what is the cause of this we suggest a
>>>>>> quick fix,
>>>>>> open your GeoNode settings  (/etc/geonode/local_settings.py for a
>>>>>> standard apt-get installation) and comment the following lines like we
>>>>>> already did on master
>>>>>> https://github.com/GeoNode/geonode/commit/f2707e64e78931b31a06016a3e04f1ba76021b66 then
>>>>>> restart the web server.
>>>>>> We appreciate any comment and feedback.
>>>>>> Simone
>>>>>> _______________________________________________
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>>>>> Simone
>>>> Paolo Corti
>>>> Geospatial software developer
>>>> web: http://www.paolocorti.net
>>>> twitter: @capooti
>>>> skype: capooti
>>> Simone
>> Simone
> Paolo Corti
> twitter: @capooti
> skype: capooti
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Davi de O. Custódio
Davi de O. Custódio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151008/84346fe2/attachment-0001.html>
More information about the geonode-users mailing list
