[GeoNode-users] Fwd: [GeoNode-devel] bing api request denied
Simone Dalmasso simone.dalmasso at gmail.com
Fri Oct 9 01:37:39 PDT 2015
Davi, the thumbnail generation "should" be unrelated to the presence of
bing in the layers list. The absence of the layer in the thumb let me
suspect a geoserver issue, check the logs.
2015-10-08 20:52 GMT+02:00 Davi Custodio <davicustodio at gmail.com>:
> ---------- Forwarded message ----------
> From: Davi Custodio <davicustodio at gmail.com>
> Date: Thu, Oct 8, 2015 at 11:16 AM
> Subject: Re: [GeoNode-users] [GeoNode-devel] bing api request denied
> To: Paolo Corti <pcorti at gmail.com>
> Simone and Paolo,
> started happening some strange things in all my GeoNode servers after the
> problem with Bing began to happen:
> 1 - When performing "geonode updatelayers" no thumb file is generated in
> the /var/www/geonode/uploaded/thumbs
> 2 - When you access a layer and force the thumb generation in the "set"
> button, the thumb is usually generated for some layers and your file too,
> but for most, the thumb generated shows only the background map (Mapquest
> OpenStreetMap) without showing the contents of the layer of geoserver.
> Tested in both situations: taking and keeping bing in the
> local_settings.py.
> Any idea what might be going on?
> On Thu, Oct 8, 2015 at 11:06 AM, Paolo Corti <pcorti at gmail.com> wrote:
>> It works perfectly, thanks Simone!
>> For people not confident with the django shell, the same result can be
>> accomplished running the following SQL (not tested but should work):
>> DELETE FROM maps_maplayer WHERE NAME = 'AerialWithLabels'
>> p
>> On Thu, Oct 8, 2015 at 2:34 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Here the two commands that you can type in a "geonode shell" (for a
>>> standard geonode installation) to remove bing from existing maps.
>>> >>> from geonode.maps.models import MapLayer
>>> >>> MapLayer.objects.filter(name=u'AerialWithLabels').delete()
>>> Hope this helps
>>> 2015-10-07 16:06 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>> Paolo that's right :(
>>>> 2015-10-07 15:57 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>>>>> Thanks to both
>>>>> for system in productions containing existing maps I think the only
>>>>> way is to follow Bart's suggestion or running a script able to remove the
>>>>> Bing map baselayer from any existing map.
>>>>> cheers
>>>>> p
>>>>> On Wed, Oct 7, 2015 at 3:51 PM, Simone Dalmasso <
>>>>>> Thanks Bart,
>>>>>> then is good to keep it disabled by default and add instructions on
>>>>>> how to properly add it.
>>>>>> 2015-10-07 15:50 GMT+02:00 Bart van den Eijnden <
>>>>>> bartvde at boundlessgeo.com>:
>>>>>>> Ideally you would have requested your own API key for your site on
>>>>>>> https://www.bingmapsportal.com
>>>>>>> And then configure the gxp Bing source with the apiKey property /
>>>>>>> config.
>>>>>>> Best regards,
>>>>>>> Bart
>>>>>>> Front End Software Engineer | Boundless <http://boundlessgeo.com/>
>>>>>>> 1-877-673-6436 <917-460-7207>
>>>>>>> @boundlessgeo <http://twitter.com/boundlessgeo/>
>>>>>>> <http://boundlessgeo.com>
>>>>>>> On 07 Oct 2015, at 15:41, Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>>>> wrote:
>>>>>>> Dears,
>>>>>>> from yesterday the bing maps api that are used by default in every
>>>>>>> GeoNode map are not working anymore due to a request denied. The effect is
>>>>>>> that every map in GeoNode cannot be zoomed properly anymore.
>>>>>>> While we try to figure out what is the cause of this we suggest a
>>>>>>> quick fix,
>>>>>>> open your GeoNode settings  (/etc/geonode/local_settings.py for a
>>>>>>> standard apt-get installation) and comment the following lines like we
>>>>>>> already did on master
>>>>>>> https://github.com/GeoNode/geonode/commit/f2707e64e78931b31a06016a3e04f1ba76021b66 then
>>>>>>> restart the web server.
>>>>>>> We appreciate any comment and feedback.
>>>>>>> Simone
>>>>>>> _______________________________________________
>>>>>>> geonode-devel mailing list
>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>>>>>> Simone
>>>>> Paolo Corti
>>>>> Geospatial software developer
>>>>> web: http://www.paolocorti.net
>>>>> twitter: @capooti
>>>>> skype: capooti
>>>> Simone
>>> Simone
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Davi de O. Custódio
> Davi de O. Custódio
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151009/7a6a5309/attachment.html>
More information about the geonode-users mailing list
