[GeoNode-users] FW: error creating superuser
Francesco Bartoli xbartolone at gmail.com
Sun Oct 11 04:19:44 PDT 2015
Hi Julio,
What version are you trying to setup?
Inviato da Mailbox
On Sun, Oct 11, 2015 at 1:14 PM, Julio Cesar Refosco
<juliorefosco at hotmail.com> wrote:
> Hello,
> Triyng to setup a theme to my geonode on Ubuntu 12.04 <http://geonode.readthedocs.org/en/master/tutorials/admin/customize_admin/setup_admin.html?highlight=setup> it seems that I screwed everthing. After some steps I reinstalled geonode and some other packs but nor everything is in place as I´m having problems creating superuser and setting IP.
> Trying to create superuser I have this:
> -----------------------------------------------------------------------------------------------------------------------------------------------------------geonode at GeoNode:~$ geonode createsuperuserTraceback (most recent call last):  File "/usr/bin/django-admin", line 5, in <module>    management.execute_from_command_line()  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 399, in execute_from_command_line    utility.execute()  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 392, in execute    self.fetch_command(subcommand).run_from_argv(self.argv)  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 272, in fetch_command    klass = load_command_class(app_name, subcommand)  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 76, in load_command_class    return module.Command()  File "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/management/commands/createsuperuser.py", line 26, in __init__    self.UserModel = get_user_model()  File "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/__init__.py", line 127, in get_user_model    user_model = get_model(app_label, model_name)  File "/usr/local/lib/python2.7/dist-packages/django/db/models/loading.py", line 271, in get_model    self._populate()  File "/usr/local/lib/python2.7/dist-packages/django/db/models/loading.py", line 75, in _populate    self.load_app(app_name, True)  File "/usr/local/lib/python2.7/dist-packages/django/db/models/loading.py", line 99, in load_app    models = import_module('%s.models' % app_name)  File "/usr/local/lib/python2.7/dist-packages/django/utils/importlib.py", line 40, in import_module    __import__(name)  File "/usr/local/lib/python2.7/dist-packages/account/models.py", line 24, in <module>    from account.compat import AUTH_USER_MODEL, receiver  File "/usr/local/lib/python2.7/dist-packages/account/compat.py", line 12, in <module>    from account.conf import settings  File "/usr/local/lib/python2.7/dist-packages/account/conf.py", line 38, in <module>    class AccountAppConf(AppConf):  File "/usr/local/lib/python2.7/dist-packages/account/conf.py", line 64, in AccountAppConf    LANGUAGES = get_languages()  File "/usr/local/lib/python2.7/dist-packages/account/conf.py", line 31, in get_languages    if code in settings.EXTRA_LANG_INFO:  File "/usr/local/lib/python2.7/dist-packages/django/conf/__init__.py", line 55, in __getattr__    return getattr(self._wrapped, name)AttributeError: 'Settings' object has no attribute 'EXTRA_LANG_INFO'
> Any ideas to solve?Thanks in advance.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151011/c98c64bb/attachment.html>
More information about the geonode-users mailing list
