[GeoNode-users] error creating superuser
Simone Dalmasso simone.dalmasso at gmail.com
Sun Oct 11 10:09:39 PDT 2015
Julio also consider in install the 2.4  beta on Ubuntu 14.04 using
poa:geonode/testing. The 2.4 is much better tha 2.0.
Il domenica 11 ottobre 2015, Francesco Bartoli <xbartolone at gmail.com> ha
scritto:
> Julio,
> in order to have a custom theme for geonode 2.0 you have to accomplish
> these steps:
> - install from apt-get
> - install the branch 2.0 of the geonode-project
> https://github.com/GeoNode/geonode-project/tree/2.0 and follow the
> instructions in there
> Regarding the error below perhaps it is related to your locale, so what is
> that?
> Francesco
> Il giorno 11/ott/2015, alle ore 13:08, Julio Cesar Refosco <
> refosco at furb.br <javascript:_e(%7B%7D,'cvml','refosco at furb.br');>> ha
> scritto:
> Hello,
> Triyng to setup a theme to my geonode on Ubuntu 12.04 <
> http://geonode.readthedocs.org/en/master/tutorials/admin/customize_admin/setup_admin.html?highlight=setup> it
> seems that I screwed everthing. After some steps I reinstalled geonode and
> some other packs but nor everything is in place as I´m having problems
> creating superuser and setting IP.
> Trying to create superuser I have this:
> geonode at GeoNode:~$ geonode createsuperuser
> Traceback (most recent call last):
>   File "/usr/bin/django-admin", line 5, in <module>
>     management.execute_from_command_line()
>   File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
> line 399, in execute_from_command_line
>     utility.execute()
>   File
> line 392, in execute
>     self.fetch_command(subcommand).run_from_argv(self.argv)
>   File
> line 272, in fetch_command
>     klass = load_command_class(app_name, subcommand)
>   File
> line 76, in load_command_class
>     return module.Command()
>   File
> "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/management/commands/createsuperuser.py",
> line 26, in __init__
>     self.UserModel = get_user_model()
>   File
> "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/__init__.py",
> line 127, in get_user_model
>     user_model = get_model(app_label, model_name)
>   File
> "/usr/local/lib/python2.7/dist-packages/django/db/models/loading.py", line
> 271, in get_model
>     self._populate()
>   File
> 75, in _populate
>     self.load_app(app_name, True)
>   File
> 99, in load_app
>     models = import_module('%s.models' % app_name)
>   File "/usr/local/lib/python2.7/dist-packages/django/utils/importlib.py",
> line 40, in import_module
>     __import__(name)
>   File "/usr/local/lib/python2.7/dist-packages/account/models.py", line
> 24, in <module>
>     from account.compat import AUTH_USER_MODEL, receiver
>   File "/usr/local/lib/python2.7/dist-packages/account/compat.py", line
> 12, in <module>
>     from account.conf import settings
>   File "/usr/local/lib/python2.7/dist-packages/account/conf.py", line 38,
> in <module>
>     class AccountAppConf(AppConf):
>   File "/usr/local/lib/python2.7/dist-packages/account/conf.py", line 64,
> in AccountAppConf
>     LANGUAGES = get_languages()
>   File "/usr/local/lib/python2.7/dist-packages/account/conf.py", line 31,
> in get_languages
>     if code in settings.EXTRA_LANG_INFO:
>   File "/usr/local/lib/python2.7/dist-packages/django/conf/__init__.py",
> line 55, in __getattr__
>     return getattr(self._wrapped, name)
> AttributeError: 'Settings' object has no attribute 'EXTRA_LANG_INFO'
> Any ideas to solve?
> Thanks in advance.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151011/04671a0a/attachment.html>
More information about the geonode-users mailing list
