[GeoNode-users] FW: error creating superuser
Julio Cesar Refosco juliorefosco at hotmail.com
Sun Oct 11 14:56:39 PDT 2015
Francesco,
I will try your sugestion. The locale of my system is:
geonode at GeoNode:~$ localeLANG=pt_BR.UTF-8LANGUAGE=pt_BR:pt:enLC_CTYPE="pt_BR.UTF-8"LC_NUMERIC=pt_BRLC_TIME=pt_BRLC_COLLATE="pt_BR.UTF-8"LC_MONETARY=pt_BRLC_MESSAGES="pt_BR.UTF-8"LC_PAPER=pt_BRLC_NAME=pt_BRLC_ADDRESS=pt_BRLC_TELEPHONE=pt_BRLC_MEASUREMENT=pt_BRLC_IDENTIFICATION=pt_BRLC_ALL=
Thanks,
JulioSubject: Re: [GeoNode-users] FW: error creating superuser
Date: Sun, 11 Oct 2015 17:51:26 +0200
CC: geonode-users at lists.osgeo.org
To: refosco at furb.br
Julio,
in order to have a custom theme for geonode 2.0 you have to accomplish these steps:
	- install from apt-get	- install the branch 2.0 of the geonode-project https://github.com/GeoNode/geonode-project/tree/2.0 and follow the instructions in there
Regarding the error below perhaps it is related to your locale, so what is that?
Francesco
Il giorno 11/ott/2015, alle ore 13:08, Julio Cesar Refosco <refosco at furb.br> ha scritto:
Hello,
Triyng to setup a theme to my geonode on Ubuntu 12.04 <http://geonode.readthedocs.org/en/master/tutorials/admin/customize_admin/setup_admin.html?highlight=setup> it seems that I screwed everthing. After some steps I reinstalled geonode and some other packs but nor everything is in place as I´m having problems creating superuser and setting IP.
Trying to create superuser I have this:
-----------------------------------------------------------------------------------------------------------------------------------------------------------geonode at GeoNode:~$ geonode createsuperuserTraceback (most recent call last):  File "/usr/bin/django-admin", line 5, in <module>    management.execute_from_command_line()  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 399, in execute_from_command_line    utility.execute()  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 392, in execute    self.fetch_command(subcommand).run_from_argv(self.argv)  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 272, in fetch_command    klass = load_command_class(app_name, subcommand)  File "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py", line 76, in load_command_class    return module.Command()  File "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/management/commands/createsuperuser.py", line 26, in __init__    self.UserModel = get_user_model()  File "/usr/local/lib/python2.7/dist-packages/django/contrib/auth/__init__.py", line 127, in get_user_model    user_model = get_model(app_label, model_name)  File "/usr/local/lib/python2.7/dist-packages/django/db/models/loading.py", line 271, in get_model    self._populate()  File "/usr/local/lib/python2.7/dist-packages/django/db/models/loading.py", line 75, in _populate    self.load_app(app_name, True)  File "/usr/local/lib/python2.7/dist-packages/django/db/models/loading.py", line 99, in load_app    models = import_module('%s.models' % app_name)  File "/usr/local/lib/python2.7/dist-packages/django/utils/importlib.py", line 40, in import_module    __import__(name)  File "/usr/local/lib/python2.7/dist-packages/account/models.py", line 24, in <module>    from account.compat import AUTH_USER_MODEL, receiver  File "/usr/local/lib/python2.7/dist-packages/account/compat.py", line 12, in <module>    from account.conf import settings  File "/usr/local/lib/python2.7/dist-packages/account/conf.py", line 38, in <module>    class AccountAppConf(AppConf):  File "/usr/local/lib/python2.7/dist-packages/account/conf.py", line 64, in AccountAppConf    LANGUAGES = get_languages()  File "/usr/local/lib/python2.7/dist-packages/account/conf.py", line 31, in get_languages    if code in settings.EXTRA_LANG_INFO:  File "/usr/local/lib/python2.7/dist-packages/django/conf/__init__.py", line 55, in __getattr__    return getattr(self._wrapped, name)AttributeError: 'Settings' object has no attribute 'EXTRA_LANG_INFO'
Any ideas to solve?Thanks in advance.
geonode-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151011/f1b5c922/attachment.html>
More information about the geonode-users mailing list
